hendry
Bandwidth monitoring
Wed Jan 22, 2014 5:34 am
I'm keen to monitor/graph bandwidth on my network. I was told to use Queues. First problem is that I can't find "queues" in the CLI, only in WebFig.
I think I correctly setup a queue to monitor my laptop.
(Ideally I would monitor ALL clients, not just my laptop)
The graph is very disappointing and practically tells me nothing. I want to see exactly how many bytes are coming in and out.
What am I doing wrong? Thanks!
RouterBOARD 4xRB952Ui-5ac2nD & 1xRB952Ui-5ac2nD
https://natalian.org/2017/08/20/Choosin ... _Ubiquiti/
hendry
Re: Bandwidth monitoring
Sun Jan 26, 2014 11:26 am
I've discovered if I change the queue type from default-small (the default which doesn't work) to default, it works. Terrible UI/UX guys.
jt2048
Sun Jan 26, 2014 8:58 pm
There are 2 ways that I know of to do this, for real time, click on the interface in webfig and open it up, scroll to the bottom and you should have both a real time byte graph and a real time packet graph.
For non-volatile samples, set up graphing (webfig->tools-graphing) add all interfaces. Can be accesses from the interface graph on that page or best from webfig-> graphing (will pop a new window with a menu for all available graphs). Since the sample time defaults to 5 minutes it will take a while to populate.
Hope this helps!
JT
PS: And of course you can always set up MRTG and monitor all interfaces remotely via SMNP.
hendry
Mon Jan 27, 2014 8:52 am
I need it more granular than interfaces. Preferably by MAC/IP address.
Thanks!
deejayq
Mon Jan 27, 2014 10:46 am
you could enable snmp and use a third party site for monitoring ex www.odmon.com
it gives you a more granular graphic Hourly (1 Minute Average), Daily (5 Minute Average), Weekly (30 Minute Average), Monthly (2 Hour Average) and Yearly (1 Day Average)
i use this site because i don't want to write graphic data to the nand flash, and if i get power failures then the information is lost.
hendry
Mon Jan 27, 2014 10:55 am
you could enable snmp and use a third party site for monitoring ex http://www.odmon.com
Does it have a per IP break down though?
aacable
Wed Jan 29, 2014 4:11 pm
If you want some free solution, then design your own using Linux base MRTG, but it do requires Manual handwork, or more suitably it should be called artwork ;)
Try this.
http://aacable.wordpress.com/2013/10/31 ... base-mrtg/
another but wordpress coding ruined it a lot :(
http://aacable.wordpress.com/tag/mrtg-i ... on-ubuntu/
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
Users browsing this forum: lasjak, MSN [Bot], robibert and 105 guests
