ksswd
Mikrotik still chokes on full bgp routing table
Thu Apr 27, 2006 12:32 pm
Mikrotik is still unable to work properly after downloading full routing table (over 180000 prefixes). This was on MT 2.9.22 with routing and routing-test packages, 512MB memory, PIII 2.4GHz. Both BGP and OSPF while loading full routing table caused mt to go 100% CPU.
Has anybody successfuly tried to use mt as bgp router?
Piotr
macgaiver
Thu Apr 27, 2006 7:32 pm
I think that routing table of 180000 prefixes takes lots and lots of calculation and it is just normal to have 100% CPU load on week CPUs
You should try Athlon64 3xxx+
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
sten
Forum Veteran
Forum Veteran
Re: Mikrotik still chokes on full bgp routing table
Fri Apr 28, 2006 12:51 am
Piotr
Your spec's are way too low for said job.
Move along. Nothing to see here.
changeip
Fri Apr 28, 2006 1:16 am
I think he meant to say P4 2.4 ... not PIII. I don't think they even have p3s above 1.7 or so. A p4 2.4 is enough for bgp i would think. CPU will hit 100% for about 5 minutes but it should not affect packet routing during this time. Is it?
Sam
jp
Long time Member
Long time Member
Fri Apr 28, 2006 3:55 am
Ciscos, known for the bloat, can handle 2 full tables pretty easy. The 7500's RSP4 has a R5000 CPU at 200Mhz, and can load both tables in probably less than 2 minutes, which is probably as fast as my peers can dish them out. It's old technology too. I would expect any gigahertz PC to do it in a fraction of the time.
normis
Fri Apr 28, 2006 8:52 am
Developers will consider it a bug if it will not use 100% of CPU resources. If it is 100% then it means that cpu is working at it's full potential, and it does not mean that it is at it's limit. Even at 100% it will still work great, it just means that CPU does what it can.
sten
Forum Veteran
Forum Veteran
Fri Apr 28, 2006 9:20 am
Cisco, also known for their 20 odd years (if not more) of developing their IOS have picked up a thing or two during all those years of development. I wouldn't be so quicky to assume such things as;
They have the same architectural challanges, bottlenecks and strengths as a x86 consumer platform. That their code is equally efficient. That the overhead is the same.
Anything zebra bgpd based is, my opinion, a good example in bad programming and inefficient design.
normis
Fri Apr 28, 2006 9:35 am
good thing that we don't use zebra :)
rkj
Mon Jun 19, 2006 3:32 am
2.9.25+ routing-test is based on Quagga, OpenBGPD, XORP or something else ?
BGP code on 2.9.25 seems very good, but it failed to do an export:
"#error exporting /routing rip interface". Will test 2.9.26/routing-test soon to check this out.
Beccara
Long time Member
Long time Member
Mon Jun 19, 2006 3:52 am
routing-test is a ground-up rebuild and is not based on anything like quagga IIRC
heimdal
about BGP
Mon Jun 19, 2006 9:27 am
I have 2.9.25 with routing-test, works for me but have strange "reload"
on BGP sessions once for last 48 hours. For now this is not a problem,
router with P4 3GHz, 1 G RAM, 4 Intel giga ethernet (one dual + two integrated on Intel Server Board). Load 2x 185 000 routes from two ISPs for about 2 minutes. Works ...except this "reload" ...
grzesjan
Mon Jun 19, 2006 11:12 am
Still one thing is not corrected. Mikrotik show status=connect and the other side shows status=established. Session is OK, prefixes are being sent both ways.
Gregor
nikhil
Mon Jun 19, 2006 2:46 pm
Gregor
Yes even the uptime in winbox is wrong because uptime should show the connection uptime and not just plain uptime
spirosco
Re: about BGP
Mon Jun 19, 2006 4:30 pm
I have 2.9.25 with routing-test, works for me but have strange "reload" on BGP sessions once for last 48 hours.
I was having the same problem with 2.9.25 r-t.
My routing table is not so big as of the guys above :) , its about 300 routes.
With 2.9.26 r-t and with increased hold timers (from 10 to 90) i have 2 days+ without a glitch.
What i have not been able so far to test on 2.9.26, is the correct removal of the routes.
I hope tomorrow to give it a try and hopefully come back with positive results :)
Users browsing this forum: Google [Bot] and 65 guests
