lamersons
is it safe to upgrade RB500 from 4.7 to 6.9
Mon Feb 03, 2014 5:24 pm
Hey guys
Is it safe to upgrade RB500 from 4.7 to 6.9 ? Or do i have to leapfrog ?
Router is running few IP-SEC tunnels.
MTCRE, HuaweiCNP, CCNP RS, CEHv7
plisken
Re: is it safe to upgrade RB500 from 4.7 to 6.9
Thu Feb 06, 2014 7:42 pm
Upgrade is not danger butt if IPSec is changed can you loose your connection and reconfiguration mayby possible.
jandafields
Fri Feb 07, 2014 12:28 am
A lot of PPP stuff is broken in 6.9. If you don't use pptp/sstp, then everything else (non-ppp stuff) appears to be working fine.
plisken
Fri Feb 07, 2014 8:31 pm
Not upgrading is the massage i think.
JanezFord
Sat Feb 08, 2014 10:48 am
Try for yourself ... make a backup of your router and upgrade it to latest version, you can still downgrade if you find issues that affect your system. There are some changes in configurations that you may need to reconfigure, like simple queues but this is not a bug. I have read many bad things about v6.9 but for me it works well and I don't have issues other people are experiencing like high cpu usage on 711, dhcp not working on vlans, ipsec broken ... all of those things work fine with my stuff, so if you are thinking about upgrade and would like to try features new versions have I say go for it ... you can still downgrade if it doesn't work out well for you.
JF.
Users browsing this forum: Baidu [Spider], sindy, tdw, upholder and 211 guests
