paulchops
basic NAT function fail after upgrade to latest ROS 6.9
Tue Feb 04, 2014 10:33 pm
We updated a 433 and a 493 (both non-AH versions). Both of them are doing NAT (src-nat) and both having the same problem. Everything looks 100%, the router can talk through the Internet and the customers (NATd) can talk to the router, but cannot talk through it. Both of these routers were on 4.1.7, and I updated each one to 5.2.6 and ran Routerboard Upgrade, then wen to 6.9
I tried many many things… even called Butch on it. Ended up blowing it out and installed from scratch. Started that process fine, and as I was pasting in some script for the IP addresses it stopped… did another system reset no-default and this time, just adding public and private IP addresses, gateway, and NAT (all done manually) it didn’t work at all.
Swapped to a 493AH, configured from scratch (some of it done through script) and works fine.
Came back to the office to find a 433 that we updated last night have the same problem. Tried downgrading this one on a hunch and still not working.
I even had Butch Evans offer an opinion and came up empty.
Paul
plisken
Re: basic NAT function fail after upgrade to latest ROS 6.9
Thu Feb 06, 2014 6:51 am
Have you reboot the router?
SurferTim
Thu Feb 06, 2014 10:18 am
I'm not saying Butch missed anything, but you should post at a minimum:
And "/ip firewall filter" if anything in there.
Start with the RB433 since you mentioned that first and I have one here.
florianmulatz
Thu Feb 06, 2014 10:24 am
Hey Guys,
Similar Problem on my side. Upgrade to 6.9 Masquerading stopped working.
Have some SRC-NAT Rules before the last masquerading rules - any time a activate the masquerading rule - src-nat stops working.
Masquerading disabled - all ok
BR
The signature of this post is posted on the back for technical reasons.
SurferTim
Thu Feb 06, 2014 10:28 am
Which router are you using? OP reports only non-AH router affected. Maybe a pattern emerging?
What "/ip firewall nat" rules are you using?
florianmulatz
Thu Feb 06, 2014 10:55 am
I'm using an x86-Version (placed on an esxi)
add action=src-nat chain=srcnat dst-address-type="" src-address=192.168.2.99 to-addresses=193.33.11x.xxx
add action=src-nat chain=srcnat dst-address-list=!no-nat dst-address-type=! src-address=192.168.2.0/24 to-addresses=193.33.11x.xxx
add action=dst-nat chain=dstnat dst-address=193.33.11x.xxx dst-port=25 in-interface=OUTSIDE protocol=tcp to-addresses=192.168.2.99 to-ports=25
add action=dst-nat chain=dstnat dst-address=193.33.11x.xxx dst-port=22 in-interface=OUTSIDE protocol=tcp to-addresses=192.168.2.99 to-ports=22
add action=dst-nat chain=dstnat dst-address=193.33.11x.xxx dst-port=3389 in-interface=OUTSIDE protocol=tcp to-addresses=192.168.2.92 to-ports=3389
add action=dst-nat chain=dstnat dst-address=193.33.11x.xxx dst-port=8080 in-interface=OUTSIDE protocol=tcp to-addresses=192.168.2.92 to-ports=8080
add action=dst-nat chain=dstnat dst-address=193.33.11x.xxx dst-port=443 in-interface=OUTSIDE protocol=tcp to-addresses=192.168.2.92 to-ports=443
add action=dst-nat chain=dstnat dst-address=193.33.11x.xxx dst-port=3389 in-interface=OUTSIDE protocol=tcp to-addresses=192.168.100.201 to-ports=3389
add action=masquerade chain=srcnat disabled=yes src-address=192.168.2.0/24
When i enable last rule (masquerade) src-nat from first and second rule is dead.
BR
SurferTim
Thu Feb 06, 2014 11:44 am
Since you have your public ip(s) obfuscated, do you have more than one ip assigned to interface OUTSIDE?
BTW, I'm posting this on a RB433 ROS v6.9 localnet with this rule:
add chain=srcnat action=masquerade out-interface=ether1
So the masquerade rule generally works with v6.9.
florianmulatz
Thu Feb 06, 2014 3:17 pm
Hey,
Yes, in sum i have assigned 3 public ip's to the outside interface.
In normal the masquerading is working right - but when I have to ensure that the package is sent out on the same IP it comes in (for example my mailrelay) then I have to use SRC-NAT.
SurferTim
Thu Feb 06, 2014 3:22 pm
The mail relay connections will "go back out" the ip it came in on. That is covered by the dst-nat. At least it is on my systems.
Change the masquerade to a src-nat and specify which ip you want to use as the default.
florianmulatz
Fri Feb 07, 2014 7:20 am
Hey Surfertim,
No, that's one of the problems ... it does NOT! When i do no SRC-NAT for my mailrelay it replys with the INSIDE-IP from the router?
Little bit confusing hm?
BR
macgaiver
Fri Feb 07, 2014 8:57 am
I have a lot of NAT configuration without any problems on 6.9 so from my perspective looks like configuration.
We need more configuration to help you - what is the tasks of te steup and what is /ip address /ip route, /ip firewall masquerade config and connection tracking status.
P.S. Alternative - just write to support@mikrotik.com
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
SurferTim
Fri Feb 07, 2014 12:18 pm
Post "/ip firewall nat print". I need to see the order of the rules and every parameter in those rules.
florianmulatz
Fri Feb 07, 2014 1:33 pm
 0   chain=srcnat action=src-nat to-addresses=193.33.123.123 src-address=192.168.2.99 dst-address-type=""
 1   chain=srcnat action=src-nat to-addresses=193.33.123.124 src-address=10.255.255.4 dst-address-type=""
 2   chain=srcnat action=src-nat to-addresses=193.33.123.124 src-address=192.168.2.0/24 dst-address-list=!local-addr
 3   chain=dstnat action=dst-nat to-addresses=192.168.2.99 to-ports=25 protocol=tcp dst-address=193.33.123.123 in-interface=OUTSIDE dst-port=25
 4   chain=dstnat action=dst-nat to-addresses=192.168.2.99 to-ports=22 protocol=tcp dst-address=193.33.123.123 in-interface=OUTSIDE dst-port=22
 5   chain=dstnat action=dst-nat to-addresses=192.168.2.92 to-ports=3389 protocol=tcp dst-address=193.33.123.124 in-interface=OUTSIDE dst-port=3389
 6   chain=dstnat action=dst-nat to-addresses=192.168.2.92 to-ports=8080 protocol=tcp dst-address=193.33.123.124 in-interface=OUTSIDE dst-port=8080
 7   chain=dstnat action=dst-nat to-addresses=192.168.2.92 to-ports=443 protocol=tcp dst-address=193.33.123.125 in-interface=OUTSIDE dst-port=443
 8   chain=dstnat action=dst-nat to-addresses=192.168.100.201 to-ports=3389 protocol=tcp dst-address=193.33.123.125 in-interface=OUTSIDE dst-port=3389
 9 X chain=srcnat action=masquerade src-address=192.168.2.0/24
The Router is my core-router in the datacenter for my personal mailserver-system.
This is my complete NAT-Configuration. (Only the public ip's have been obfuscated - don't want to post the real one's)
SurferTim
Fri Feb 07, 2014 1:49 pm
I use an out-interface parameter on srcnat rules, and no dst-address-type. I don't know what the dst-address-type does to your rule.
If I have localnet ips that use specific public ips,
add chain=srcnat action=src-nat src-address=192.168.2.99 to-addresses=193.33.123.123 out-interface=OUTSIDE
I do not use a masquerade on the OUTSIDE interface srcnat chain if more than one ip is assigned to that interface. I use a src-nat to one specific ip.
add chain=srcnat action=src-nat to-addresses=193.33.123.123 out-interface=OUTSIDE
And when I do use a masquerade, I specify an out-interface instead of a src-address as above.
add chain=srcnat action=masquerade out-interface=OUTSIDE
florianmulatz
Fri Feb 07, 2014 1:59 pm
Hey Surfertim,
Seems, that _that_ was really the trick. Specified the OUTSIDE interface for the masquerading as Out.Interface - all is working like before.
But the same rule (without the specified out-interface) worked before with 6.7 (i've skipped 6.8 )
BR
Last edited by florianmulatz on Mon Feb 10, 2014 11:36 am, edited 1 time in total.
SurferTim
Fri Feb 07, 2014 2:02 pm
I have found that some older ROS versions allow "mistakes" in firewall filter and nat rules that newer versions don't. I found over the years that it is best to use correct rules and stick to them.
karina
Fri Feb 07, 2014 2:49 pm
I Believe this is the prime cause of upgrade issues. Not just firewall but all kinds of things like VPNs Vlans etc when I look through the posts complaining on the "v6.9 released" thread I suspect a high percentage are down to this fact. I have now upgraded an entire network with all types of devices including CCR's and no issues to report that were not down to mistakes in configs that previous versions forgave.
For example I have an Eoip interface and when I upgraded to V6.9 it stopped working. Turns out I had forgotten to specify the local address at one end. ver 5.25 didn't care about the mistake however 6.9 required the config to be correct
florianmulatz
Thanks for helping @ all!
paulchops
Sun Feb 16, 2014 6:46 pm
To follow up on our situation - I was the original poster. I had upset customers - this was a MDU - 6 customers affected, I had to upgrade to an 493AH (from the 493) and solve the problem. I had tried to re-setup the 493 router from scratch - adding bits and pieces at a time, and it would sometimes work for a while and stop, but at any consistent spot at building the config. All on a router that had run on 4.1.7 since it came out without any problems. I had upgraded to 5.26 then to 6.9, then all the problems came. Like I said, after jerking around with it for 2 hours, I had to swap it out.
On the OTHER customer - who is still having issues (433 -non AH) - same thing... though this is customer is very simple setup. One NAT rule.. I upgrade this customer from 4.17 (had been working great) to 5.26 to 6.9. Same problem NAT just stopped "flowing". I wiped config reloaded and it worked for 2 days. It stopped again, and I repeated - wiped, reloaded - was fine for an hour - did one more time - worked 3 days and stopped flowing.
I downgraded to 5.26 and the customer still has issues - but intermittently .. same as above... uggggh... It was rebooted at Friday at 4pm. Not working at all. I told customer to wait until Monday (coming up) as I would swap out the unit.
I just checked on it (Sunday) and its flowing data... what the heck?
add action=src-nat chain=srcnat disabled=no out-interface="WAN Bridge" src-address=10.10.200.0/24 to-addresses=198.172.215.244
How much more simple can you get ? And, no, changing the rule to masquerade didn't help
Users browsing this forum: dioeyandika and 125 guests
