omidkosari
Trainer
Trainer
Cloud Router Switch CRS125 Port Based VLAN
Sat Feb 08, 2014 6:23 pm
According to "Port Based VLAN" in http://wiki.mikrotik.com/wiki/Manual:CR ... Based_VLAN
I want to all vlans go through egress tagged vlan 500 (on ether2) but vlan200 , vlan300 , vlan400 may not access each other .
Any idea ?
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
omidkosari
Trainer
Trainer
Re: Cloud Router Switch CRS125 Port Based VLAN
Mon Feb 10, 2014 4:52 pm
Is this problem related to port/vlan isolation bug ?
efaden
Mon Feb 10, 2014 6:33 pm
Ask support. There is a lack of documentation so it's hard to help.
Sent from my SCH-I545 using Tapatalk
omidkosari
Trainer
Trainer
Sun Feb 23, 2014 3:07 pm
This configuration will be possible when port isolation is completely fixed.
We have planned to do it in one of the upcoming RouterOS versions.
Regards,
Janis Becs
efaden
Sun Feb 23, 2014 3:20 pm
Regards,
Janis Becs
Yeah... my question is just "when"... this is a released product that doesn't have a major part of its feature set working...
omidkosari
Trainer
Trainer
Wed Mar 05, 2014 10:06 am
I have followed instruction from http://wiki.mikrotik.com/wiki/Manual:CR ... Based_VLAN but still leak happens in v6.9 :(
Playing with the configs makes switch crash so i could not try and false .
Anybody found a workaround ?
omidkosari
Trainer
Trainer
Sun Apr 20, 2014 10:37 am
Edit .
v6.12 still has port isolation bug :(
Users browsing this forum: Bing [Bot], Google [Bot] and 89 guests
