tfn220189
Support request, How to reset if the only ether is disabled
Sun Feb 09, 2014 1:10 am
Hi all!
I have a little problem, I accidentaly disabled ether1 (the only ethernet interface of my RB711-5Hn board). so now I can't access to the routerboard, I won't like to climb on the roof, unmount the antenna shield and manually reset the board, so I'm asking you if ther is a way to enable the ether1 or reset configurations directly from the disabled ether1 interface!
nick3dos
Re: Support request, How to reset if the only ether is disab
Mon Feb 10, 2014 11:46 am
try to connect from the wireless interface (if it was enabled)
tfn220189
Mon Feb 10, 2014 11:48 pm
Well this could be a solution but the wlan interface is managed by ma WISP and they won't be happy to know that I know their password.
nick3dos
Tue Feb 11, 2014 3:06 pm
You have access to the mikrotik device and not in the wireless interface???
!!! strange !!!
tfn220189
Tue Feb 11, 2014 7:33 pm
What's strange? I'm not the admin of the AP, I don't have credentials to access the AP and my RB is set as station, so no, sorry but I repeat that I don't have access to the Wireless interface :)
jwcn
Tue Feb 11, 2014 7:49 pm
Sounds like you have a problem with your WISP, they have disabled the Ethernet interface and now you are trying to circumvent then. Call your WISP and work out your problems with them, stop trying to do things you aren't supposed to be doing.
tfn220189
Thu Feb 13, 2014 8:17 am
ok, factory reset the RB, everything is working again, thank you for your support
