aacable
Winbox Security: Password Stored in clear text format
Thu Feb 13, 2014 8:30 am
I know its not recommended to save the password in mikrotik WINBOX (as password are stored in clear text form in winbox.cfg in local pc user profile), But we HUMANS love being lazy enough or with weak memory sometimes prefer to save the password and the management PC and sometimes this PC is also shared by some other co-admins/colleagues dueto lack of resources :p
In my opinion, It could be annoying backdoor / password leak issue by WINBOX.
Mikrotik developer should really focus in this section , and encrypt the password using strong hash algorithm. I used it few months back at a friend’s admin PC to fetch the iD password with all details as showed in the image. Just imagine what will happen if it fall into wrong hands …
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
normis
Re: Winbox Security: Password Stored in clear text format
Thu Feb 13, 2014 8:33 am
Yes, this is true. Do not "save" passwords on a PC where you are not the only user. We are working on a new Winbox where you will be able to set a master password, that will encrypt your passwords.
aacable
Thu Feb 13, 2014 8:49 am
Good news NORMIS, & waiting for new WINBOX ... :)
_____________
Regard's
Syed Jahanzaib
Ibersystems
Sat Feb 15, 2014 12:03 pm
Please, make posible to create subgroups of routers in winbox saved list of routers... We have the administration of hubdred of networks with thousand of routers... ITs very hard to find the correct router to enter..
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
Adam84
Re: Odp: Winbox Security: Password Stored in clear text form
Sat Feb 15, 2014 1:26 pm
Do u plan to add some new features (i.e. storing personal default column selection) to WinBox or just some security improvements? Will the new version work natively on linux distro's? I hope u don't wanna based it on java:)
Wysłane z Nokii 3310
Sob
Sat Feb 15, 2014 4:30 pm
<OT>
Thanks man, that idea will be ruining my sleep every time I'll remember it. ;) But it would not make much sense anyway. Currently WinBox "just works" on Windows and Linux users have to install WINE, which they might not need for anything else, so I agree it's not as cool. With Java WinBox, everyone would have to install huge and otherwise pretty much useless Java. Doesn't sound like a progress to me.
</OT>
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
Users browsing this forum: Bing [Bot] and 56 guests
