Hammy
Forum Veteran
Forum Veteran
CRS226
Fri Feb 21, 2014 9:08 am
The slides I saw online were hard to read. What's this CRS226?
Mike Hammett
The Brothers WISP
normis
Re: CRS226
Fri Feb 21, 2014 9:09 am
Two SFP+ 10G ports and 24 Gigabit copper ports
Desktop version $289, available April
Rackmount version $299, available May
ATG
Re: CRS226
Fri Feb 21, 2014 9:48 am
Sound promising!
What CPU and speed is used? (Fanless?)
Best Regards
Joakim
normis
Re: CRS226
Fri Feb 21, 2014 10:42 am
400MHz CPU and 64MB RAM.
ATG
Re: CRS226
Fri Feb 21, 2014 10:57 am
PPC CPU? HW Encryption?
This looks like ideal product for our remote offices! :)
normis
Re: CRS226
Fri Feb 21, 2014 2:43 pm
Atheros CPU, no HW acceleration. But remember, it is still mostly a Switch.
efaden
Re: CRS226
Fri Feb 21, 2014 3:30 pm
Normis - It's a 400 Mhz?... its slower than the CRS125? Also any updates on the finished feature set for the CRS?
Raf
Re: CRS226
Fri Feb 21, 2014 4:32 pm
Looks like mistake. I guess it should be 600 MHz.
Rafał Wójcik from AWB-NET
High Definition enthusiast
honzam
Re: CRS226
Sat Feb 22, 2014 12:22 pm
Why only 400Mhz? Old CRS have 600Mhz
LAN, FTTx, Wireless. ISP operator
efaden
Re: CRS226
Sat Feb 22, 2014 2:35 pm
+1... thats odd.
ditonet
Forum Veteran
Forum Veteran
Re: CRS226
Sat Feb 22, 2014 2:41 pm
Probably MT decided that it's mainly switch and router functionality is 'additional feature' :)
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
JanezFord
Re: CRS226
Sat Feb 22, 2014 9:47 pm
Any info on MTU? Does it support jumbo frames of 9000 bytes ?
JF.
vortex
Re: CRS226
Mon Feb 24, 2014 10:45 am
Would it be possible to build a CRS217-14G-3S+IN with the QCA8519 ?
I'm not sure the QCA8719 would allow 52ac or even 52n.
There's barely any info on these chips.
normis
Re: CRS226
Mon Feb 24, 2014 10:50 am
It is mainly a switch, so MHz don't matter.
efaden
Re: CRS226
Mon Feb 24, 2014 7:59 pm
True... but its a cloud ROUTER switch... I am actually using it for both. And technically the switch isn't fully implemented yet..
keefe007
Re: CRS226
Mon Feb 24, 2014 11:18 pm
Any plans for a full 10gig switch?
ropeba
Re: CRS226
Tue Feb 25, 2014 12:01 am
CRS is ok for FTTB instalation, but it would be ok that CPU is litle bit stronger.
normis
Re: CRS226
Tue Feb 25, 2014 10:10 am
And 400Mhz is OK for running some ports in routing mode. Let us know which Switch features you find missing.
efaden
Re: CRS226
Tue Feb 25, 2014 1:43 pm
I have emailed support. All I have been told is that there are bugs with the CPU and vlan. Your going to fix it at some point, but there is no Eta and more documentation and examples will come also. So I am left just waiting....
Sent from my SCH-I545 using Tapatalk
THG
Re: CRS226
Tue Feb 25, 2014 9:53 pm
If I connect two switches through their 10 Gigabit interface, what speed can I expect (no routing, just bridging)?
If I have multiple VLANs, do I need a Cloud Core Router to get decent speed?
nz_monkey
Re: CRS226
Wed Feb 26, 2014 2:30 am
Hurry up and make a 802.3af/at POE out model :)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
skibi82
Re: CRS226
Fri Mar 07, 2014 3:22 pm
Will have xSTP, LACP,VoisVLAN and other solutions?
If not, please do not tell anyone that this switch.
It will be like CRS125 on network switch is not suitable.
In this case we get 10Gbps switch with a capacity of 40 Mbps
How predator said s h i t happen
normis
Re: CRS226
Fri Mar 07, 2014 3:23 pm
it works at wire speed in switch mode. As a router, CPU is limit like you observed.
skibi82
Re: CRS226
Fri Mar 07, 2014 3:35 pm
There is no basic functions of a managed switch.
I'm talking here about what any other.
I make the connection port 1 and 2, and then the machine dies.
And what I such that the loop switch can not determine
janisk
Re: CRS226
Fri Mar 07, 2014 5:07 pm
what was the last time you checked on what is available?
http://wiki.mikrotik.com/wiki/Manual:CRS_features
netmaster
Re: CRS226
Fri Mar 07, 2014 6:13 pm
I finished wiki page.
Not a word about IGMP support?
It is basically cheap RB, attached to cheap manageable switch and that's it.
Is hard to understand for whom that device is made...
Most homes or offices do not have anything to connect to SFP+, but they forced to pay for it.
ISP's who maybe have use of SFP+, need full featured smart switch for sure, including IGMP support.
Actually I am little disappointed, that none of the MT switches (including those integrated into routers) do not have IGMP support. Even 30$ switches have it, but not from Mikrotik. Why?
skibi82
Re: CRS226
Sun Mar 09, 2014 4:34 pm
Request basic smart switch functionality
LACP dynamic
STP
RSTP
MSTP
VOICE VLAN by mask
efaden
Re: CRS226
Sun Mar 09, 2014 5:22 pm
LACP dynamic
STP
RSTP
MSTP
VOICE VLAN by mask
How about switch chip based LAG/Bonding.
docmarius
Re: CRS226
Sun Mar 09, 2014 7:31 pm
I miss a basic feature in CRS switch. Port forwarding based on IP/TCP and IP/UDP port, like in the switching rules of the older 450 and 750 switch chips.
I know that taking the port in account is L4 and this is a L3 switch, but since you can e.g. do exceptions for DHCP, RIP and ND, that means the switch chip is able to manage L4, too.
An usecase would be to drop DHCP and UPNP requests on a certain port linking to a network segment managed by another router.
And I don't think bridging just to do L3/L4 filtering is feasible for multiple gigabit ports on a 400 or 600 MHz cpu.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
JanezFord
Re: CRS226
Sun Mar 09, 2014 8:04 pm
I agree with docmarius. A device like CRS should be able to prevent DHCP requests coming from certain ports ..
http://en.wikipedia.org/wiki/DHCP_snooping
JF.
odge
Re: CRS226
Fri Jun 20, 2014 1:43 am
I've only realised now, that MT does not have MTSP support .... WHAT?
This is insane! Its basic managed switch functionality. Not being able to load balance on layer2 using MSTP compared to switches that are actually cheaper just doesnt make sense as a core component of any of the devices that gigabit ports, and especially those that have SFP and SFP+
jober
Long time Member
Long time Member
Re: CRS226
Tue Jul 29, 2014 9:56 am
I thought these would have been good vlan switches and NAT gateway router. I'm afraid I would have been better off with a managed D-Link switch :( and a 951G.
oreggin
Re: CRS226
Wed Jan 28, 2015 11:55 pm
If i'm right, CRS is a Layer2 ASIC with CPU Layer3 support. So it can't NAT or routing in ASIC but in CPU?
Do you plan make real Layer3 switches? I mean what can does simple routing or NAT functions with TCAM or similar.
vortex
Re: CRS226
Sat Feb 21, 2015 5:13 pm
The product that seems to be obviously missing now is CRS217-16G-1S+IN
Users browsing this forum: Narngfa and 23 guests
