MUM Europe 2020
adilmehmoodbutt
Mikrotik BGP Protocol configuration
Fri Feb 21, 2014 11:56 am
HI,
I have an issue with mikrotik Rb-750 gigabyte, 5.11 v router board BGP configuration. My router using my both ISP connection for download and upload bandwidth while i monitor in interface but i want to use my 1st connection as primary cnnection and secondary mean 2nd isp connection as backup connection how can i prioritize my primary connection for upload/download traffic in my router and keep my 2nd ISP connection as backup.
dasiu
Trainer
Trainer
Re: Mikrotik BGP Protocol configuration
Sun Feb 23, 2014 2:26 pm
HI,
You should:
1. Use DIFFERENT in- and out-filters for the peer1 and peer2
2. Add a rule in peer2 in-filter lowering local-preference (for example - to 50)
3. Add a rule in peer2 out-filter setting bgp-prepending (or, if the AS doesn't accept the prepending, a special community that is accepted by the operator)
(edit: ach, now I see that the peers belong to the same AS... Then you can try setting a MED in out-filter for peer2)
If you have 2 BGP sessions and you want to be the administrator and manage them - it would be nice to get some knowledge about BGP :).
garthvs
Mon Feb 24, 2014 11:38 am
I found this really helpful. It explains how to manipulate BGP based traffic:
https://ftp.apnic.net/meetings/22/docs/ ... gp-bcp.pdf
Users browsing this forum: MSN [Bot] and 134 guests
