WildWurger
Multiple scripts with 1 scheduler
Fri Feb 21, 2014 4:32 pm
Hi all,
Is that possible that I want to run a few scripts with only 1 scheduler?
If so, may I know how it can be done?
Thank you very much in advance
boen_robot
Re: Multiple scripts with 1 scheduler
Fri Feb 21, 2014 4:36 pm
If you want to run them one after the other, you could simply store each script in "/system script", and then at the scheduler, do
ros code
/system script run script1
/system script run script2
# etc.
If you want to execute them concurrently... AFAIK, yeah, you can't do that from a single scheduler item, but you CAN create multiple scheduler items that all activate at the same time, which in effect runs several scripts at once.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
WildWurger
Fri Feb 21, 2014 4:47 pm
wow this is exactly what i want
thanks :D
Users browsing this forum: No registered users and 10 guests
