MUM Europe 2020
alexburke
NTP client using FQDN?
Sun Feb 23, 2014 10:33 pm
Hello!
My RB450G (RouterOS v6.10) is configured as an NTP client. I would like to use an FQDN (pool.ntp.org, europe.pool.ntp.org, etc) to respect load-balancing. How can I do this?
Thanks in advance!
nerdtron
Re: NTP client using FQDN?
Mon Feb 24, 2014 2:59 pm
Just input the FQDN in the /system ntp
The FQDN will be converted to IP addresses once the router does nslookup.
alexburke
Mon Feb 24, 2014 4:27 pm
It performs the DNS resolution precisely once: the moment you configure it, and then never again. Load balancing (the whole point of pool.ntp.org) is lost. This is not a solution, unfortunately. :(
lunchboxrts
Mon Feb 24, 2014 4:32 pm
I wish ros would save the fqdn instead of the ip. I use a script set to run every 30 min to update the settings with the new addresses to respect the load balancing.
#get ntp ip's
:local ntpipa [:resolve 0.us.pool.ntp.org];
:local ntpipb [:resolve 1.us.pool.ntp.org];
:local cn;
#get current ip's
:local ntpcura [/system ntp client get primary-ntp];
:local ntpcurb [/system ntp client get secondary-ntp];
#change primary if needed
:if  ($ntpipa != $ntpcura) do={
#:log info "Changing primary NTP ($ntpcura --> $ntpipa)";
/system ntp client set primary-ntp="$ntpipa";
:set cn "1";
#change secondary if needed
:if  ($ntpipb != $ntpcurb) do={
#:log info "Changing secondary NTP ($ntpcurb --> $ntpipb)";
/system ntp client set secondary-ntp="$ntpipb";
:set cn "1";
:if ($cn != "1") do={
#:log info "No NTP updates required";
#:log info "Finished updating NTP IP's";
alexburke
Mon Feb 24, 2014 7:10 pm
What a hack, but if need be, I'll do it. Please excuse the ignorance; how exactly is this added and scheduled?
nerdtron
Tue Feb 25, 2014 4:27 am
You can include 2 ntp pools for time sync. Isn't that enough?
In creating scripts and schedules, go to System>Scripts. Click the plus sign to add an entry. Give it a name (ex: check-time) and then paste your whole script in the Sorce box.Click OK to save.
Then go to System>Scheduler. Click the plus sign to add an entry. Give it a name (ex:check-time). Set Start Time to “startup”, set Interval to “00:30:00” to run it every 30 minutes. Put the following in the On Event box:
/system script run check-time
Click OK to save it.
alexburke
Fri Feb 28, 2014 12:37 am
Brilliant. Thanks so much!
alexburke
Mon Mar 17, 2014 5:47 pm
This doesn't seem to work; here's the script:
:log info "NTP IP update script triggered.";
       #Get NTP IPs
       :local ntpipa [:resolve 0.europe.pool.ntp.org];
       :local ntpipb [:resolve 1.europe.pool.ntp.org];
       :local cn;
       #Get Current IPs
       :log info "Changing primary NTP IP ($ntpcura --> $ntpipa)";
       :set cn "1";
       :log info "Changing secondary NTP IP ($ntpcurb --> $ntpipb)";
       :set cn "1";
       :log info "Finished updating NTP IP addresses";
The only output I get is
echo: script,info NTP IP update script triggered.
rextended
Mon Mar 17, 2014 5:57 pm
Why complicate all????
You just need this:
/system scheduler
add interval=30m name=check_time_servers on-event="/system ntp client set enabled=yes mode=unicast primary-ntp=[:resolve 0.europe.pool.ntp.org] secondary-ntp=[:resolve 1.europe.pool.ntp.org];" policy=read,write start-date=jan/02/1970 start-time=00:02:00
this update ntp servers each 30 min [and start to do it after 2 min from RB is powered].
I'm Italian, not English. Sorry for my imperfect grammar.
alexburke
Mon Mar 17, 2014 7:06 pm
You just need this:
/system scheduler
A nice clean solution. Thank you!
rextended
Mon Mar 17, 2014 7:43 pm
If you have liked the solution, please add Karma
Users browsing this forum: akosikazim, najmul92, saibarker and 103 guests
