airstream
PPPoE dynamic interfaces and UPnP
Fri May 05, 2006 10:22 am
Hi all, Just after a little advice on how to place the UPnP feature to a dynamically created PPPoE interface.
I have MT with 2 ethernet cards, one WAN one LAN. WAN is internet IP and LAN is 10.19.72.1/24. PPPoE customers get assiged an ip from a 10.0.0.0/24 pool on the LAN interface.
All PPPoE clients gateway assigned is 10.0.0.1 (becomes MT gateway for client)
UPnP works perfectly if you are on the LAN and have an IP within the LAN segment (WAN=external LAN=internal). You cannot add a pppoe client interface here as it dissapers with the client disconnecting.
Is there a way around this? VLAN's perhaps?
Many thanks for any pointers.
Geoff
Keep tryin' its bound to work!!
ROOT@COSMOS> Reality.sys corrupted -- Reboot Universe (Y/N)?
>_
airstream
Sun Jul 16, 2006 12:12 am
Has anybody got any ideas on this? I have tried Vlan's as well as many other configurations.
Some tips/pointers would be much appreciated.
Cheers
Geoff
>_
balimore
Forum Veteran
Forum Veteran
Sun Jul 16, 2006 7:14 am
Cheers
Geoff
hi, airsteam
no ideas, my dynamic[tranparant network], dhcp[hotspot], pppoe, and webserver with ip local one on one NIC with different subnet over lan and wireless is work fine....
peace all
BalimoreDOTcom
jdejansb
Thu Oct 05, 2006 3:56 am
Cheers
Geoff
Any ideas up till now? I guess that I have the same problem.... PPPoE users and UPnP just don't go together :(
D.
sten
Forum Veteran
Forum Veteran
Thu Oct 05, 2006 6:41 pm
try adding static pppoe-server interfaces for each user?
either way it really does sound like something that you dont want to do for more than a couple of users.
Move along. Nothing to see here.
Users browsing this forum: BlanketyBlank, Google [Bot], satspy, xtask67 and 126 guests
