1001001
transparent bridging over VPN / central NAT
Tue Mar 04, 2014 7:40 pm
Hello everybody,
is there a 'simple' solution to the following problem?
Consider a szenario where you have 10 site that have to be in the same broadcast domain / the same local network, getting servered by the same dhcp server and getting internet access through the same NAS.
Which combination is the most stable for use with heterogenous hardware on the clientside?
EoIP and OVPN is not an option and as far as the current research goes ipsec doesn't do out of the box, which combination of standard protocols can be used ?
Best regards
1001001
efaden
Re: transparent bridging over VPN / central NAT
Tue Mar 04, 2014 7:42 pm
Hello everybody,
Best regards
1001001
That sounds horrible. The best solution is to split it up into separate networks.
If you really want to do it transparently you can use something like EOIP over IPSec which lets you bridge them on Layer2.
1001001
Tue Mar 04, 2014 8:02 pm
Hello everybody,
Best regards
1001001
Yeah it probably is. But still the NAS at the central site has to be able to authenticate all clients coming from the remote sites. EoIP ist no solution because it is not available on the remotesite devices, IPsec is but its only layer three and that alone doesn't do.
efaden
Tue Mar 04, 2014 8:04 pm
Hello everybody,
Best regards
1001001
You can use GRE or IPIP also... Beyond that I don't have a good suggestion.
Users browsing this forum: ariosvelez, CoUL, Google Feedfetcher, jaceqp123, portwolf1982 and 69 guests
