normis
Newsletter 55 - new products!
Fri Mar 07, 2014 9:32 am
This newsletter introduces some new products, and shows what happened at the MUM in Italy:
http://download2.mikrotik.com/news55.pdf
sashavl
Re: Newsletter 55 - new products!
Fri Mar 07, 2014 10:20 am
Finnaly wireless controller.
jarda
Sat Mar 08, 2014 7:26 am
Why is mAP still without price?
Sent from Android by Tapatalk.
jaykay2342
Location: /Vigor/LocalGroup/Milky Way/Earth/Europe/Germany
Sat Mar 08, 2014 10:15 am
I'm sill wondering whether RB260GSp will have an SPF slot or not?
9-5 Job: Securityanalyst at a major MSSP.
Free time volunteer: Networkadmin and founder at a small non-profit WISP.
Certifications: ITILv3, GCIA
honzam
Sat Mar 08, 2014 10:25 am
have
LAN, FTTx, Wireless. ISP operator
payday
Sat Mar 08, 2014 1:17 pm
And availability? :)
cheeze
Sun Mar 09, 2014 2:23 am
Is the RB850x2 similar to the Ubiquiti Edgerouter?
Also is availability for that model supposed to be May?
snons
Sun Mar 09, 2014 9:24 pm
 CCR1072 (72 core Tilera CPU, 8x 10GBit SFP+, dual PSU and more, coming Q4, 2014)
it will be mine :D :D :D
RabbitAtNet
Mon Mar 10, 2014 2:26 pm
Hi there,
I am curious about the suggest sales prices and the general availability of the new devices. Can you provide me with a rough estimate for the new products? Which quarter are they shipping?
I am especially interested in the mAP, as it might solve a couple of issues I have ...
timberwolf
Any more details about the RB850Gx2?
I started a thread here: http://forum.mikrotik.com/viewtopic.php?f=3&t=82684
saloustrosm
Mon Mar 10, 2014 11:23 pm
Normis,
Any thoughts for adding the mAP in the RouterBoard section without case, wlan and the power adapter in a more convenient place for OEM applications?
I am saying that because as it looks like, the mAP is going to be the ultimate VPN solution for OEM and i think it worth it because it will be
a new kind in the RouterBoard family without too much effort.
I am renting machines to my customers and i need to monitor them for providing SLA, cost etc and i am struggling to fit the RB750 inside but all i want is 2 ports (one for the machine and the second for the VPN)
Also doubling the disk size? :D
normis
Tue Mar 11, 2014 9:06 am
Hi there,
It's all in the PDF document
leonet45
Tue Mar 11, 2014 4:17 pm
are you planning good-looking indoor case for mAP? Something like Unifi o Ruckus?
normis
mAP is already in an indoor case.
saloustrosm
Tue Mar 11, 2014 4:29 pm
Any answer to my question?
leonet45
Tue Mar 11, 2014 4:35 pm
I can not imagine this case in the lobby of the Sheraton Hotel. Some places need a prettier case and that is why I refer a ruckus or unifi.
See this, http://www.rfelements.com/en/products/e ... ox-inspot/
They have the solution to products that are missing. Why do you not manufacture directly? a simple plastic housing can make a difference
normis
Tue Mar 11, 2014 4:45 pm
It is very small, 6x6 cm! And why would you place it in a visible location?
normis
Tue Mar 11, 2014 4:46 pm
Currently we have no plan to offer it without case and PSU. Maybe if there will be significant demand.
dhanamnetworks
Tue Mar 11, 2014 9:24 pm
I need new product for 12x1G Ethernet and 12 SFP and 2 SFP+ Switch for campus use
another one 20 SFP and 4x1G Ethernet 2 SFP+ Switch Fiber to home (Plots, Hotels)
Small Router with 1 SFP and 5x1G Ethernet with 1600mw 5 to 10 dbi mimo (Rooms, Office, Hostel)
JanezFord
Tue Mar 11, 2014 9:56 pm
You don't need 1600mw wireless for Rooms, Office, Hostel ... keep in mind it is not only how far can your signal go, but also if signal from your clients will get back ... in this kind of setup you will be dealing with laptops (100mw), tablets (80mw) and phones (50mw) ... what use is to get your signal kilometers away if devices you are targeting can respond only about a fraction of that distance ... boosting power on your AP will not increase power on your clients devices. Solution is to place more devices with LOWER power and nonoverlaping channels.
JF.
raz
Wed Mar 12, 2014 8:17 am
What about the new Routing Engine?
nz_monkey
Wed Mar 12, 2014 10:19 am
+1 :)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
MarcB
Fri Mar 21, 2014 3:16 pm
Hi Guys,
The new products look great and I can't wait to et my hands on the CCR1072 as this looks like it has the ports that we need.
Its great that MikroTik have models with multicore processors, but none of the firmware can use more than a single thread at the moment!
We have a few CCR1036 routers which work great, but we run BGP on them with full routing tables and the BGP process is only using 1 core which is constantly running at 100%.
We have just installed the new v6.11 firmware which has reduced the CP usage slightly, but it is still only using 1 ore at a time for BGP.
One of the routers took 7 minutes to load the full routing table from 1 BGP peer which is quite a long time.
When are MikroTik going to get multithread support on the firmware so that we can make full use f the powerful multicore processors?
Kind regards,
Marc
normis
Fri Mar 21, 2014 3:39 pm
but none of the firmware can use more than single thread at the moment!
this is most certainly not true
only loading of the table works on one core. all routing itself works on all cores, as do most other features. you have basically stumbled on one of the last remaining single threaded processes
MarcB
Fri Mar 21, 2014 4:09 pm
Hi Guys,
Once the routing is received we are still seeing high individual core usage.
Once BGP has processed all of the routes it generally doesn't have to process many routes as the only change a little.
We have been asking for BGP to be made multithreaded for quite some time as we are desperate to be able to make full use of the multicore processors.
It would be nice if we could actually set a maximum number of cores that BGP could use.
If we could also set this for OSPF as well it would make the routers very powerful.
Please let us know when the BGP process will be multicore capable and if we will be able to set the maximum number of cores that we want it to run on.
Kind regards,
Marc
normis
Fri Mar 21, 2014 4:18 pm
Our whole routing subsystem will have to be made again. We are working on new routing engine for the future v7, but I can't make promises about that, too early to tell.
MarcB
Fri Mar 21, 2014 4:34 pm
Hi Guys,
It would be useful for us (and other MikroTik uses) to know exactly what processes or features are multithread supported.
Could you post a complete list of what features / modules or processes will work with multiple cores and how many cores they will work with maximum?
If you could ask you development team to see how easy (or how hard) it would be t make the routing subsystem work with at least half the number of cores in the CCR series of routers as this would be a vast improvement on speed f the device and BGP loading times.
Kind regards,
Marc
pdf
Tue Mar 25, 2014 9:17 pm
hi normis
1) is the p2p parabolic antenna only dual polarization or there is a 3 pol antenna (I never saw a tripol parabolic dish but but curious to hear about that... who knows)
2) any indoor/outdoor case for the RB953GS-5HnT ?
Thank you
normis
Wed Mar 26, 2014 9:13 am
pdf:
1. no tripple polarization
2. not yet
angboontiong
Wed Mar 26, 2014 9:35 am
when RB953GS-5HnT available ???
infused
Wed Apr 02, 2014 8:44 am
Dual power supplies... thank god. I'd buy it just for that. Now we are getting to enterprise level (please no adapters).
Any idea on pricing for that beast? (CCR)
samjan
Mon Oct 20, 2014 8:32 pm
To Mikrotik staff
How can we use MIKROTIK mANT30 PA with MIKROTIK NetMetal 5 (RB922UAGS-5HPacT-NM) triple version?
is it really use tree pol together eith one dish?
Экономьте буквы, трафик стоит денег.
jarda
Mon Oct 20, 2014 10:35 pm
You can also switch off one chain...
Users browsing this forum: Google [Bot] and 104 guests
