MUM Europe 2020
altazpremji
Routerboard 1100 Webfig
Tue Mar 11, 2014 7:03 pm
Hello All,
I have a routerboard 1100. This had OS 4.11 by default.
I upgraded the routerboard to OS 6.10 from 4.11
Now when i go to the web interface I see the old Interface pre-Webfig era but with broken images. Is there any way I can make the new Web interface the default web interface.
Please advice.
many thanks for the assistance.
NAB
Trainer
Trainer
Re: Routerboard 1100 Webfig
Wed Mar 12, 2014 11:14 am
1 - Don't use webfig. It will break things in strange ways.
2 - If you must use webfig, try:
/system routerboard upgrade
/file remove [find]
/system reset-configuration no-defaults=yes
which should ensure you're on the latest firmware (not ROS version), that all the old files are removed (care, make sure to back any files you may need up) and that everything in ROS is reset to base configuration (again, make sure you export anything you want to keep).
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
Users browsing this forum: No registered users and 24 guests
