wtw
PtP 5.8 Bridge and MAS90
Mon May 08, 2006 3:42 am
Greetings
I have a PtP 5.8 link that is solid at 36 Mbps. I have one program MAS90 that runs dog slow across the PtP bridge. Any help would be appreciated.
Specs:
CM9 Cards, Both set to bridge at 5805 and one -70 the other -80 signal.
2K AD connections for DHCP, DNS, File and Printer server just fine.
MAS90, Best Software accounting package very slow.
Thank you in advance.
philjo
Fri Aug 18, 2006 4:02 pm
hey,
thats really nice. how r using the cards? Which boards are you using with them, nd r they indoors or outdoors. Is it possible i do the same with SR5 cards indoors using 35m cable to antenna?
e2346437
Re: PtP 5.8 Bridge and MAS90
Fri Sep 01, 2006 2:43 am
Greetings
Specs:
MAS90 runs slow even on 100 Megabit Fast Ethernet, and you want to run it on 36 Megabits, half duplex? Which equates to 18 megabits? Which is 5 times slower than Fast Ethernet?
If you are already running Windows 2000 server, why are you not using Terminal Services?
dbostrom
Fri Sep 01, 2006 4:15 am
As e2346437 suggests, there might be a better way to skin this cat, though it's odd and intriguing that your app should be so dog-slow. VNC will run blindingly fast over 36mbps...
Users browsing this forum: No registered users and 6 guests
