MUM Europe 2020
gcs
Traffic not passing from wan to lan
Fri Mar 14, 2014 10:38 pm
I have a customer with a RB411 running 5.19. They hav ben running fine for months. I can winbox into their cpe on the Wlan interface from my tower. everything looks fine. the arp list shows the ethernet computers ip address. I can't ping it from the cpe. firewall is normal. defaut route is correct.
They can't surf or ping past the cpe. they can ping and winbox the cpe from the lan.
I would appreciate any help.
David
c0d3rSh3ll
Long time Member
Long time Member
Re: Traffic not passing from wan to lan
Fri Mar 14, 2014 11:33 pm
Check the masquerade rule if your cpe is nated
sent from my mobile phone with tapatalk
nothing
gcs
Fri Mar 14, 2014 11:47 pm
Here is my Nat from winbox.
gcs
Re: Traffic not passing from wan to lan FIXED
Tue Mar 18, 2014 7:25 pm
I had to reprogram the settings from scratch. Now it works fine.
Users browsing this forum: Google [Bot] and 22 guests
