plisken
winbox in linux mint
Tue Mar 18, 2014 11:23 am
Winbox is running and installed.
If i click on the tree dots comes not Mac-address ore IP-address
Sometimes well.
Ik can't not connect to the device with Mac-address and IP_address
What must i do?
In windows works it fine
nerdtron
Re: winbox in linux mint
Tue Mar 18, 2014 11:45 am
It does work fine on mine, but I didn't installed wine using the default installation. I customized a lot of settings on wine.
Anyway, I am successful on using the default wine install to use winbox by setting the IP address of the computer on the same subnet of the mikrotik router. Then try connecting to IP address or MAC and you'll be connected.
rextended
Tue Mar 18, 2014 11:47 am
On last ubuntu, just download & run winbox (by "Wine 1.4") and all is working...
I'm Italian, not English. Sorry for my imperfect grammar.
nerdtron
Tue Mar 18, 2014 11:54 am
13.10? How's the terminal font on yours?
rextended
Tue Mar 18, 2014 11:59 am
Yes, 13.10
I have one ASUS EEEPC 1000H, the font on terminal inside winbox are clearly readable.
plisken
Tue Mar 18, 2014 12:07 pm
@nerdtron What do you mean exactly?
nerdtron
Tue Mar 18, 2014 12:17 pm
In windows, if your computer has IP 192.168.1.2 and the port you are connected on mikrotik has IP address 192.168.88.1, you won't be able to connect using MAC.
Try settings your computer IP to 192.168.88.2 and you'll be able to connect. I know it defeats the purpose on connecting via MAC but that's how it worked on mine.
plisken
Tue Mar 18, 2014 12:29 pm
I have wine 1.4.1 winbox works but sometimes can't connect with routerboard.
RouterOs 6.10
plisken
Tue Mar 18, 2014 12:31 pm
I will connect with MAC but sometimes don't work.
Users browsing this forum: bahman and 127 guests
