CPromper
OVPN:require client certificate not working anymore [SOLVED]
Fri Mar 21, 2014 2:51 pm
I've updated from v6.10 to v6.11 and the OVPN option "require client certificate" doesn't work anymore!
If I remove the option I can login again with OpenVPN client on iPhone.
But with this option set I can't login (in 6.10 it worked).
Can anyone confirm it?
Best regards
Carsten
mrz
Re: OVPN: require client certificate not working anymore
Fri Mar 21, 2014 2:56 pm
Is client certificate from the same CA chain?
revizor
Fri Mar 21, 2014 4:43 pm
Confirming, after updating to 6,11 i have the same problem.
elgrandiegote
Fri Mar 21, 2014 11:19 pm
I have exactly the same problem
Downgrade to 6.10
bramfm
Sat Mar 22, 2014 5:54 pm
Same problem here..... :(
yozz
Sat Mar 22, 2014 8:33 pm
yes.. problems is it.
CPromper
Mon Mar 24, 2014 6:09 pm
Hello mrz,
yes, I only have one CA installed, and the client certificate is signed by this CA.
Downgraded to 6.10 and it works again.
I have seen that there was an issue with the client certificate option (that I did not have)
because the changelog of 6.11 says:
*) ovpn - fixed require-client-certificate
Regards
Carsten
patrickmkt
Mon Mar 24, 2014 8:46 pm
Same problem for me.
I have CA and intermediate CA with LT status in ROS.
emuell
Thu Mar 27, 2014 3:38 pm
i can also confirm that since v6.11 "require-client-certificate" option does not work anymore!
mrz
Thu Mar 27, 2014 4:22 pm
Will be fixed in next version. It is related to CRL.
fievel
Wed Apr 02, 2014 3:14 pm
When is planned the next version ?
CPromper
Wed Apr 16, 2014 1:06 pm
Hi folks,
today I upgraded to version 6.12 and openvpn didn't work.
The flags of the CA and the router certificate after updating was only a big "T"
After I deleted the certificates (CA and signed certificate for router) and imported them again everythings works as expected. <== (I didn't do this step in 6.11, maybe it works also here???)
The flags are: for CA = "AT" and for the router cert = "KT"
So, the option "Require Client Certificate" in version 6.12 works.
Best regards
Users browsing this forum: andlil, Baidu [Spider], biomesh, Google [Bot], Kazek, maxsaf, vikinggeek and 194 guests
