KarimD
winbox problem
Wed Mar 26, 2014 8:16 pm
I've the winbox.exe on the win desktop
when I connecto to any of ours mikrotik routers, on the win desktop appears a lot of .dll and .crc files
If I move winbox.exe to another folder, when connect to router, the files are created on this folder
Another problem, if I save the router data to connect directly, when I exit from winbox and input again
the data salved of other routers is no there
thanks and regards
rextended
Re: winbox problem
Fri Mar 28, 2014 2:32 am
Use last version of winbox available at:
http://download2.mikrotik.com/winbox.exe
Your problem IS NOT A WINBOX BUG ,but is your PC.
I have used all version of Winbox from 2007 to now, and I have used it in those OS:
Windows XP, Vista, 7, 8, 8.1, Server 2003, Server 2008 (also R2),
Ubuntu from 11.04 to 13.10,
Mac OS X Snow Leopard, Lion, Mountain Lion, Maverick.
never one single problem as you described.
I'm Italian, not English. Sorry for my imperfect grammar.
skik009
Re: winbox problem
Fri Mar 28, 2014 2:43 am
thanks and regards
The problem is on your PC. First re install your pc's operating system and try.
_________________
MTCNA
If I helped you give me karma please I appreciate this
KarimD
Re: winbox problem
Fri Mar 28, 2014 2:01 pm
i've the last version of winbox
this notebook has a week working
I can't re-install OS for this problem, may be another solution
rextended
Re: winbox problem
Sat Mar 29, 2014 1:24 am
Try to run Winbox (download from official site), as Administrator or disable the antivirus
Zavi
Re: winbox problem
Sat Mar 29, 2014 12:20 pm
Winbox stores it's data in %AppData%\Mikrotik folder, if can't write here it stores data in current working directory. Check permissions settings of that folder.
RB751G-2HnD & RB2011UiAS-2HnD-IN at home
Users browsing this forum: dawe4444, rsaeon, terrybuk and 44 guests
