MUM Europe 2020
metabaron
No idea how this is event possible
Fri Mar 28, 2014 5:25 am
Hello all, brand new French guy here.
So, I have a 1Gbps connection at home (yep, living in Singapore where my Internet Provider recently released a 1Gbps for below S$50).
When I connect my computer directly behind the ONT (Alcatel Lucent I-010G-U), I have a download speed of 950Mbs or so with cable A or B (tested the 2 cables to be sure they have no problem at all)
When I connect my computer to my Mikrotik using cable A, the speed negotiated is 1Gbps.
The connection between ONT and Mikrotik with cable B is also 1Gbps.
So far so good.
But when I run the same download test speed, my speed is only 270Mbs instead of the previous 950Mbs when directly connected to the ONT.
Any idea where I could look to get a full speed from my Mikrotik please?
dog
Re: No idea how this is event possible
Fri Mar 28, 2014 12:20 pm
What Routerboard do you have?
Most likely you are simply maxing out the CPU.
metabaron
Fri Mar 28, 2014 1:02 pm
I'm owning a RB2011UAS
noib
Fri Mar 28, 2014 1:41 pm
Tools->profile , check CPU when doing your bandwidth test.
You gave no details about what the 2011 is doing; if it is just switching, make sure that your ethernet cables are on the same switch chipset (eth1-5 and eth6-10 if i remember well)
metabaron
Fri Mar 28, 2014 2:25 pm
Ok, this is a newly re installed Mikrotik and I realized that Firewall is kicking 50% or more of the CPU with networking at 20% and same for Ethernet...
The default firewall is 50%? That huge isn't it?
EDIT: the router is doing only one things: give internet access, with currently only one computer connected to it.
EDIT2: When I mean re-install: hard reset, restart with factory default, plugged in internet, computer. Default firewall rules
metabaron
Sat Mar 29, 2014 2:51 am
So, I don't get it, both 1Gbps system are on the same switch (the 5 1Gbps one), firewall rules are at minimum (the default ones) and still, I reach 100% CPU usage (firewall being more than 50% of it)?
dog
Sat Mar 29, 2014 6:27 am
The RB2011 is "rated" at about 700Mbit/s: http://routerboard.com/RB2011UiAS-IN (the value in the lower right corner is closest to real-world) so it is unlikely that you will get 1 Gbit out of it anyway.
Please post a configuration export.
To test for a bottleneck first clear the router configuration:
sys reset-configuration skip-backup=yes no-defaults=yes
Then configure the router as a simple switch:
/int eth
set ether1 comment="WAN"
set ether2 master-port=ether1 comment="LAN"
That should behave the same as connecting your PC directly to the modem.
After testing reset the router again and configure it as a software switch:
/int bri
add name=bri1
/int bri po
add int=ether1 bridge=bri1
add int=ether2 bridge=bri1
That should still behave the same way as above (but with higher CPU load).
metabaron
Sat Mar 29, 2014 8:21 am
Thank you, will post the request file tomorrow night I think (I'm in SG) and will run the tests you gave me.
metabaron
Sat Apr 05, 2014 7:55 am
I did what you ask. First connection, without bridge, I cap at my max speed, like behind ONT (about 950Mbps).
When doing the second connection (so just a bridge with the two ethernet, my CPU raise at 20-25 max when my speed is down to 95Mbps... (so, reset of the router, create a bridge, connect eth1 and eth2 to the bridge.
I just noticed that my eth0, connected to the ONT is now 100Mbps because, suddenly, the ONT is advertising 100Mbps max ... I might have the culprit ....
metabaron
Sat Apr 05, 2014 8:06 am
When the ONT announce 1Gbps, I have a download speed at 857Mbps which is much more what I'm expecting
metabaron
Sat Apr 05, 2014 8:39 am
Once I started DHCP server and NAT, back to 250Mbps with almost 100% CPU (through pre-defined Home AP).
I'm really disappointed that you cannot have a CPU able to suspend much faster speed (for this, I thought, was a high end router)
JanezFord
Sat Apr 05, 2014 11:36 am
Of course you can have a better CPU, you can even have CPU that handles 10Gbit/s with millions of packets/s if you want ... but it will cost you more money ... take a look a powerPC or Tilera based Mikrotiks if you want to make full use of your 1Gbit/s internet line. I bet your cheap car can't do 320km/h either ... so why expect that you can spend less than 100$ and get performance of a few 1000$ machine? RB2011 is a high-end router, it allows you way more control of your traffic than anything in this price range but 1gbit/s is just too big task for such small CPU.
JF.
jaykay2342
Location: /Vigor/LocalGroup/Milky Way/Earth/Europe/Germany
Sun Apr 06, 2014 4:00 pm
RB2011 is not doing 1Gbit/s if you doing firewalling and natting on that box, it just not powerful enough. It was never a high-end router.
9-5 Job: Securityanalyst at a major MSSP.
Free time volunteer: Networkadmin and founder at a small non-profit WISP.
Certifications: ITILv3, GCIA
barkas
Re: AW: No idea how this is event possible
Sun Apr 06, 2014 9:44 pm
that's a realistic speed with connection tracking enabled. There is nothing wrong with your setup, the device just isn't any faster.
Rb2011 is a low cost device. If you want wirespeed, I suggest a Mt device with PPC or possibly an edgerouter by ubiquiti.
That does put a damper on our relationship.
metabaron
Mon Apr 07, 2014 2:07 pm
Thank you, I thought I bought a medium to high end device :( So, my Asus (like half the price), can deliver almost full speed but with less features ... Sad for me.
Thank you all for your help
Users browsing this forum: eworm, ferastemimi, jebz, memphisgd and 83 guests
