nenapop
Unable to connect to AP on different ip rang
Tue Apr 01, 2014 12:25 am
Hi all!!!
I am having the problem connecting to my Routerboard that is set to work as an AP, from my computer. Let me explain the connection.
My computer is connected on simple home router that is further connected to a main routerbord that is also a server/gateway... everything. the router ip address is 192.168.2.x (ether 1) and i need to connect through ether 3 that has ip 192.168.40.254 (witch i can connect over my desktop) to the separate groove ap/routerbord with ip: 192.168.40.1. where i cannot even ping from my desktop. help!
My computer(192.168.2.x)------> routerboard server(192.168.40.254)-----working
My computer(192.168.2.x)------> routerboard server(192.168.40.254)--->AP Groove(192.168.40.1)----not working
routerboard server(192.168.40.254)--->AP Groove(192.168.40.1)----working (ping, terminal, neighbors)
my computer connected over ether 1 to routerboard server
AP Groove connected over ether 3 to routerboard server
SurferTim
Re: Unable to connect to AP on different ip rang
Tue Apr 01, 2014 3:06 pm
Do you have that 192.168.40.x network routed to the routerboard in the "simple home router"?
nenapop
Tue Apr 01, 2014 3:31 pm
I dont think that it is nessesary becouse i can ping from192.168.2.x every other ip rang...(192..168.10.x, 192.168.20.x, 192.168.30.x)... exept 192.168.40.x
SurferTim
Tue Apr 01, 2014 3:41 pm
OK. Then post "/ip address" and "/ip route" from your routerboard server, whatever device that is. Never heard of that model routerboard.
nenapop
Wed Apr 02, 2014 12:12 am
ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.2.1/24 192.168.2.0 ether1
1 192.168.10.254/24 192.168.10.0 srlek.net
2 192.168.20.254/24 192.168.20.0 srlek.net.2
3 192.168.30.254/24 192.168.30.0 srlek.net.3
4 192.168.40.254/24 192.168.40.0 ether3
5 D 10.165.8.114/17 10.165.0.0 ether2
ip route print
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 10.165.0.1 0
1 X S 0.0.0.0/0 82.114.66.81 1
2 ADC 10.165.0.0/17 10.165.8.114 ether2 0
3 ADC 192.168.2.0/24 192.168.2.1 ether1 0
4 ADC 192.168.10.0/24 192.168.10.254 srlek.net 0
5 ADC 192.168.20.0/24 192.168.20.254 srlek.net.2 0
6 ADC 192.168.30.0/24 192.168.30.254 srlek.net.3 0
7 ADC 192.168.40.0/24 192.168.40.254 ether3 0
SurferTim
Wed Apr 02, 2014 12:25 am
How does the Groove get its network settings? Is it static or dhcp? Check the gateway setting on the Groove. Insure it is 192.168.40.254.
nenapop
Wed Apr 02, 2014 2:12 am
Excelent... That has fixed the problem! Thanx a LOOT!
Users browsing this forum: No registered users and 43 guests
