chrismarine
rb 600 "No buffer space available"
Fri Apr 04, 2014 12:43 pm
rb 600 with 6.11 ppc I lose the access with [ip] about after 1 or 2 days , I have access only with [mac address ] and observe in [log] "failed to open TCP connection :No buffer space available "
so that the bgp connections have no routes !!!
the dhcp server working normal and send ip addresses to the local machines
afterwards from reboot the router all come back in the normal situation until is redisplayed the problem !!!
rextended
Re: rb 600 "No buffer space available"
Fri Apr 04, 2014 1:04 pm
I solve similar problem in this old routerboard wih netinstall (6.7!) and RouterOS 6.7 with 2.27 BIOS [firmware]
http://i.mt.lv/routerboard/files/mpc8343_2.27.fwf
http://download2.mikrotik.com/routeros/ ... ll-6.7.zip
http://download2.mikrotik.com/routeros/ ... pc-6.7.npk
Do not reimport .backup or you reimport the problems!
Use
/export compact file=backup
first and after install reimport line-by line on terminal (for catch errors) the backup.rsc
I'm Italian, not English. Sorry for my imperfect grammar.
honzam
Fri Apr 04, 2014 3:04 pm
rb600 is powerpc - there is link http://download2.mikrotik.com/routeros/ ... pc-6.7.npk
LAN, FTTx, Wireless. ISP operator
shed
Mon Apr 07, 2014 7:16 am
I have the same problem in ROS 6.11.(x86, CCR1016)
ROS 6.10....OK
chimaster
Mon Apr 07, 2014 10:11 pm
Same Problem, ROS 6.11, FW 3.12, CCR 1016-12G. Two routers, Primary or Secondary, whichever seems to be doing the most BGP discussion, runs about 8 - 12 hours before halting any IP connectivity.
apr/08 06:46:01 route,bgp,info RemoteAddress=10.1.1.1
apr/08 06:46:07 route,bgp,info Failed to open TCP connection: No buffer space available
apr/08 06:46:07 route,bgp,info RemoteAddress=112.68.40.192
apr/08 06:46:21 route,bgp,info Failed to open TCP connection: No buffer space available
apr/08 06:46:21 route,bgp,info RemoteAddress=112.68.40.192
apr/08 06:46:59 route,bgp,info Failed to open TCP connection: No buffer space available
apr/08 06:46:59 route,bgp,info RemoteAddress=112.68.40.192
Have submitted supout. xpost http://forum.mikrotik.com/viewtopic.php ... 43#p420143
MTCNA - MTCWE - MTCRE - MTCINE - All round good guy and Linux nut
<plug>
HQWiFi making http://www.queenstown.com Wireless since 2001.
</plug>
Users browsing this forum: eworm, Google [Bot], Google Feedfetcher, Majestic-12 [Bot], N2B, svmk, Znevna and 126 guests
