npero
RB433 not boot hardware problem any solution ?
Mon Apr 21, 2014 9:52 am
I have two boards with similar symptoms.
First blue led shine led501-504 is also on but no boot, no console output.
Second blue and green led on led501-504 on but no boot, no console output.
It is hardware problem is anyone try to resolve similar failure what can be problem broken processor, ram, nand anyone have experience with this type of failure ?
Thanks.
plisken
Re: RB433 not boot hardware problem any solution ?
Mon Apr 21, 2014 5:18 pm
Hear you the beeps?
Tr netinstall to recover
http://www.wirelessinfo.be/index.php/mi ... etinstalle
npero
Mon Apr 21, 2014 9:19 pm
No beep, no boot, no console output.
Hardware problem is someone have some experience with this type of failure what can be problem ?
BobcatGuy
Wed Aug 06, 2014 8:07 am
I have this same issue, and I also found this youtube video, which I watched and the symptoms are the same, same voltages, same heat on the chip..
https://www.youtube.com/watch?v=rq9c23GUxbk
Just not sure if I want to try and remove an IC off this board.
I think this was an issue before, and maybe MT knows about this issue?
I'm a little pissed because I only used mine in a test environment with a total of about 2 hours use on it, and it sat on a shelf since then, and now this problem.... I am not a happy camper!
Anyone want it? :-)
Ether 2 and 3 lights are lit dimly as well, IE very dim!
Users browsing this forum: No registered users and 66 guests
