ste
QRT-5
Wed Apr 23, 2014 9:51 am
Is new on routerboard.com. CPU speed is wrong. Should be 600 instead of 400MHz.
Should give good short to mid-Range Links. Now waiting for the Dish for longer ranges
and some tweaks to make nv2 better than nstreme on these links.
soulflyhigh
Re: QRT-5
Wed Apr 23, 2014 10:03 am
Cheaper CPE-only version would be very interesting for us.
MTCRE, MTCTCE, MTCSE
ste
Re: QRT-5
Wed Apr 23, 2014 10:11 am
It's quite affordable for a 23db CPE with GE.
There is SXT Lite, SXT HG, Sextant and QRT-5.
normis
Re: QRT-5
Wed Apr 23, 2014 10:16 am
ste is right, for each category we have a product. For 5GHz (recommended retail price, lower at some distributors):
$59 = SXT Lite
$95 = SXT HG (Gigabit and Higher Gain)
$110 = SEXTANT (more gain)
$169 = QRT 5 (even more gain and power)
soulflyhigh
Re: QRT-5
Wed Apr 23, 2014 1:36 pm
I do recognize that QRT-5 will probably be an excellent device with good antenna,
high throughput, powerful CPU, gigabit ether port and good build quality.
But, it has about 50% higher price than custom made CPE with RB911 + 23dBi single polarization antenna.
We need something like that (single polarization 23+ dBi antenna and 100mbps ether port would be perfectly fine)
to connect customers in low populated areas where distance can be more than 5 or 10km.
We will start buying QRT-5 ASAP for short-to-mid p2p links but at this price point it is simply too expensive (for us) as a plain CPE unit.
Take a look what U*** company has to offer for CPE market even at SXT Lite5 price point.
Our competitors use them and they're doing just fine.
Instead of additional 50-100 QRT-5 units per month we'll be buying maybe 10-20 of them and continue
to make those CPEs with 23dBi antennas.
That's all.
Regards,
M.
ste
Re: QRT-5
Wed Apr 23, 2014 3:14 pm
That's all.
Regards,
M.
Single pol Antennas are *outdated*. We replace them where possible. You should look at your calculation and take the available spectrum into account. A user with singlepol antenna use up to double the airtime.
cjohnson0692
Re: QRT-5
Thu Apr 24, 2014 6:09 am
Seriously, Mikrotik comes out with nice new products and all people do is complain, it's sad! Everything Mikrotik has isn't for my company but we are happy they continue to develop new products and we are happy to see the new ones. As Mikrotik covers such a broad range of customers.
soulflyhigh
Re: QRT-5
Thu Apr 24, 2014 11:30 am
That is, technically speaking, completely correct. Sadly, that comes at a much higher price.
Now, just take it easy, I'm not complaining about QRT-5 for what it is and how much it costs.
What I'm saying is it's just an overkill to use it as CPE for domestic/home users at that price point
(please note that "cheap" may have slightly different meaning in Bosnia where we live and work and let's say Germany or Sweden).
As I can see it, QRT-5 is an excellent (and probably the best) choice for ~100mbps p2p links in <10km range for 169$.
But "the other company" has a 27dBi CPE for 69$ with free shipping :( .
You really don't have to put it on paper to calculate how much this is an advantage (in terms of money
and effective range of base stations) for our competitors at the start per user.
Actually, they are giving them away for free to their new costumers.
We could hardly afford that kind of practice with QRT-5. Believe me, this is a really big problem for us.
So, am I the only one around here who sees an empty place in Mikrotik product line?
Just one idea > Groove52HPn or RB911 "compactly combined" with some 23-27dBi antenna
and L3 license under 90-100$ price tag would be a game-changer for us.
Mikrotik guys, could you please reconsider this idea?
Regards,
M.
normis
Re: QRT-5
Thu Apr 24, 2014 11:35 am
QRT has two chains and Gigabit, "other brand" is single chain 100Mbit. Not a fair comparison
soulflyhigh
Re: QRT-5
Thu Apr 24, 2014 1:14 pm
Yes, correct again. But, again, that's not the point.
If some other ISP can offer a similar or the same service at lower price
then one can easily imagine the end result as loss of market share for us.
For shorter range we're using SXT Lite5 (which is a great piece of hardware at great price) but for longer range we
just don't have anything to "fight" with that "inferior-27dBi-single-polarization-100mbps-69$ device".
I simply don't know how to put that fact to be more obvious :(
Regards,
M.
normis
Re: QRT-5
Thu Apr 24, 2014 1:17 pm
It is not similar at all. The added features add the price.
If you want, you can have the 50$ Groove added to a grid antenna http://routerboard.com/RBGroove52HPn and it will be comparable.
We don't offer grid antennas now, so you must look in Distributor pages for prices.
ste
Re: QRT-5
Thu Apr 24, 2014 1:32 pm
Regards,
M.
You should do a calculation which contains scalability and installation/replacement cost. Putting a low end single chain device to the customer now increases the probability to replace it very soon. As said we consider this devices as trash and drop them to the bin. Buying and installing them is your problem not the price. CPE prices are so low compared to backhaul and service/installation cost that it is not worth to buy the cheapest cpe with lower functionality.
ste
Re: QRT-5
Fri May 02, 2014 1:04 pm
Got my first QRT-5. Suprised it is quite small for a 23db dual pol Antenna.
Our old Mars singlepol are the same size and have only 21db.
Our other 23db dual pol Antennas are 37x37cm.
Any special antenna magical sauce ?
n21roadie
Re: QRT-5
Fri May 02, 2014 1:39 pm
More important is performance, have you tested!
N21roadie,
Network 100% MT for Now?
ste
Re: QRT-5
Fri May 02, 2014 3:34 pm
Only on a non clean link to an omnitik. There it performes quite good for the conditions.
I'll do some more links to see how it does.
The HW looks good. Mounts are stable the door fits and there is enough room for
the cable.
n21roadie
Re: QRT-5
Fri May 02, 2014 5:22 pm
the cable.
Can you post some photos if possible of the underside of unit, cable entry point and with Ethernet cable connected,
we always have to check for water ingress points with any outdoor device.
N21roadie,
HaQs
Re: QRT-5
Fri May 02, 2014 11:07 pm
RB mount in the middle of a tragic To replace the RB need to dismantle each screw
Ground screw is screwed on from the inside is really imaginary patent.
It should be movable so as not to have to pull the front cover and unscrew it. Who invented it?
It should also be on sale with the cheapest version of the CPE RB911 L3 and 100mbit lan
ste
Re: QRT-5
Sat May 03, 2014 12:15 am
3 Screws to remove the Antenna. Hang in new one and fasten 3 screws.
soulflyhigh
Re: QRT-5
Sat May 03, 2014 9:40 am
+1
vmnx
Re: QRT-5
Sat May 03, 2014 5:57 pm
ste, can you run p2p link test? I'm considering to use theese for ptp but affraid that it wont work properly with nv2 (like current p2p link, two sextants, nv2 and nstreme not working with both chains, only with one chain working not bad...)
wildbill442
Re: QRT-5
Tue May 13, 2014 10:20 pm
ste:
Whose your distributor?
Non of the US based distributors seem to have them yet.
As for the debate on cost... Compare it to a dual pol ARC Integrator series 23dBi gain RB911 board w/ pigtails and all and you're coming out ahead...
I would have liked to slap the ARC ABS mounts on these units...
William Burnett
Network Engineer
Lupin
Re: QRT-5
Tue May 13, 2014 11:56 pm
Why this difference between QRT 2Ghz and 5Ghz?
Price examples of other product in 2Ghz and 5Ghz version:
Metal 2SHPn 99$
Metal 5SHPn 99$
BaseBox2 89$
BaseBox5 89$
QRT-2 149$
QRT-5 169$
avantwireless
Re: QRT-5
Sat May 24, 2014 2:56 am
A few things... One. The pole mounting nuts (10mm) are perfectly sized with the slot in the bracket so that you can put a 10 mm speed (ratching) wrench on the nuts and tighten them down and as they get tightened up they will TRAP the speed wrench. ( some speed wrenches have to flip over to reverse and so can not be backed off! )...
TWO what is going on with the voltage readings. Know 23.5 Volt input is reading as 31 volts... Kinda scary!!! I hope this doesn't get close to voltage shutdown values...
Three, we are seeing excellent performance out of this small antenna very similar to 24db panels ... Way to go!...
janisk
Re: QRT-5
Mon May 26, 2014 3:58 pm
can you provide S/N of the router (to support@mikrotik.com) reading should be approximately correct (within 1V boundaries for sure)
Users browsing this forum: No registered users and 20 guests
