azurtem
Trainer
Trainer
RB2011UAS running gigabit at 100mbps
Thu Apr 24, 2014 5:51 pm
hi
I now have high bandwidth with my livebox fibre link (500mbps/200mbps)
When I connect my notebook directly to the livebox I reach 483mbps/183mbps which is awesome. http://testdebit.info/
When I plug the RB2011(6.7) to the livebox, using eth1 (WAN), and plug my notebook into eth3 (LAN) I can't get beyond 95mbps/170mbps
Do I need to do something special to get the gigabit ports to operate at gigabit throughput speeds ?
Both eth1 and eth3 interfaces indicate a rate of 1Gbps on their status tabs
Ports 3-5 have eth2 as Master
Ports 7-10 have eth6 as Master
Eth2, Eth6 and Wlan1 are members of bridge1
Could it this throughput limitation be due to eth3 (Giga) and eth6 (Fast) both being in the same bridge ?
thanks
yann
jarda
Re: RB2011UAS running gigabit at 100mbps
Thu Apr 24, 2014 6:18 pm
It corresponds to fastpath bridging with small packets. See the chart here: http://routerboard.com/RB2011UiAS-RM . Try to use bigger packets in your test or use switching instead bridging.
jarda
Thu Apr 24, 2014 6:20 pm
Oh, wan-lan translation is affected by amount of rules, queues and other stuff.
azurtem
Trainer
Trainer
Thu Apr 24, 2014 8:14 pm
Thanks for your response
All I have are firewall rules controlling traffic between ports eth1 and eth3
Traffic between eth1 and eth3 is not bridged or switched, but routed
I removed my firewall rules and the bandwidth went up : 320Mbps/180Mbps
Still a little short, but much better
Is it the NATing that's costing me 150Mbps ?
jarda
Fri Apr 25, 2014 4:04 pm
Can be. You can look at tools-profile to check cpu utilization under high traffic stress. It should give you a clue.
azurtem
Trainer
Trainer
Sat Apr 26, 2014 8:21 am
In effect, the cpu was at 100% for several seconds during the bandwidth test
thanks Jarda
Users browsing this forum: anav, Baidu [Spider], Delid4ve, Google [Bot], mbovenka and 104 guests
