Marconet
F50N on 433 router board for AP Bridge
Tue Apr 29, 2014 3:15 pm
I bought an F50N wireless card I mounted it on a 433 board and two OMNI one on each mmcx and hopes to get a better AP performance . any advice ?
n21roadie
Re: F50N on 433 router board for AP Bridge
Tue Apr 29, 2014 4:21 pm
What the performance before using this radio card and two omni's.
N21roadie,
Network 100% MT for Now?
Marconet
Tue Apr 29, 2014 7:53 pm
Using an F50 with one omni was very poor an omnitik gives better performance I just wanted to get wider coverage
Marconet
Tue Apr 29, 2014 7:56 pm
The idea came to me when I saw on the f50 antena mode but on the f50N no antena mode does it works on both omnis by default ?
soulflyhigh
Wed Apr 30, 2014 10:00 am
Those 2 omni antennas should be in different polarization (one horizontal, second vertical),
otherwise it won't be any better than just one antenna.
It's much better to use 3 or 4 sector AP devices like those from SXT series (http://routerboard.com/RBSXTG-5HPnD-SAr2).
If this is too expensive then it's better to use Omnitik (http://routerboard.com/RBOmniTIKU-5HnD) than trying to invent one.
Regards,
M.
p.s. for both mmcx connectors to work you should enable both chains on the card (in winbox wireless wlanx you'll
see tab named "HT" with 4 check-fields, by default only ht-tx-chain0 and ht-rx-chain0 are enabled,
you'll need to enable and other 2 check-fields for chain1).
MTCRE, MTCTCE, MTCSE
Marconet
Sat May 03, 2014 4:07 pm
thnx you are great
CAC
Mon Feb 16, 2015 1:04 am
otherwise it won't be any better than just one antenna...
I have to disagree. Mutual polarization improves channel separation somewhat when both antennas are essentially on top of each other, but you can physically separate two antennas with the same polarization and get equivalent (if not better) multipath benefits. Two antennas also doubles your Rx gain.
Daniel Harling
Principal, Engineering
MT{CNA,RE,WE,TCE,EIEIO}
Cape Ann Communications, Inc.
Gloucester, MA, USA
Users browsing this forum: mbovenka and 18 guests
