plisken
bgp peer switch script
Thu May 08, 2014 7:42 pm
Hello, I have nodes with 2 uplinks for redundantie
I have two bgp peers on the node peer 1 is enabled peer 2 is disabeld
Now a want a script that if bgp peer 1 go down peer 2 would be enabled
And vice versa if bgp peer go's back online that bgp peer2 becomes disable
Any a idee?
c0d3rSh3ll
Long time Member
Long time Member
Re: bgp peer switch script
Thu May 08, 2014 9:21 pm
how are you enabling and disabling each peer?
nothing
plisken
Thu May 08, 2014 9:27 pm
I want a script at failure of the bgp peer.I don't want it self off
Thanks for reply
plisken
Fri May 09, 2014 2:18 pm
with command in script
/routing bgp peer enable
/routing bgp peer disable
But i want that the script see that peer1 is down and enable automatic peer2
and vice versa if peer1 back online that peer2 disable
Something with netwatch ore so
plisken
Fri May 09, 2014 6:01 pm
:if ([/routing bgp peer get [find name="xxx"] state] != "established") do={ .. send email here...}
In the place of email I would like to enable bgp peer2.
I want also in place of establisched that bgp peer is down
How write te script
plisken
Mon Sep 15, 2014 12:37 pm
Anybody can help?
plisken
Fri Sep 26, 2014 3:53 pm
Nowbody has a idee :(
psamsig
Fri Sep 26, 2014 5:23 pm
I have no experience with BGP, but here is a go:
/routing bgp peer {
    :local priPeerState [get [:pick [find name="Primary"] 0] state]
    :local secPeer [:pick [find name="Secondary"] 0]
    :local secPeerDisabled [get $secPeer disabled]
    :if ($priPeerState != "established") do={
        :if ($secPeerDisabled = true) do={
            enable $secPeer
    } else={
        :if ($secPeerDisabled = false) do={
            disable $secPeer
plisken
Fri Sep 26, 2014 5:29 pm
Thanks, i try this and let you know if this works.
Users browsing this forum: nafees88 and 23 guests
