MUM Europe 2020
niamul
installation of ros 6 from usb to hdd
Mon May 12, 2014 2:51 pm
hey guys,
here is the problem. i have a pc and i have a pen drive. i have the netinstall.zip and routeros612.iso
how do i copy or boot from the pen drive and then install the os onto the hard drive? i've been trying for a while by making bootable pen drives but in the end, it installs itself on the pen drive and not on the hard drive.
i need help. suggestions and links would be greatly appreciated.
- waiting for that last laugh
normis
Re: installation of ros 6 from usb to hdd
Mon May 12, 2014 3:38 pm
You don't need the ISO
Netinstall can create a bootable USB drive with the setup files. Run Netinstall, choose the USB drive as your target, then choose RouterOS NPK files of the desired version, and click Install.
Once you boot from that USB, installation tool will start.
Or if you are familiar with the "dd" command line tool, you can use our install image http://download2.mikrotik.com/routeros/ ... e-6.12.zip
niamul
Mon May 12, 2014 6:06 pm
It's installing on the usb drive instead of the hard drive. Doors the drive work in ahci mode? Or will it have to be in legacy?
niamul
Tue May 13, 2014 9:37 am
was finally able to install it with a CD.
Sadly it's only recognising 2gb ram and I've got 4gb installed.
I suppose it's the limitation
jarda
Tue May 13, 2014 3:03 pm
It is not 64 bit. Therefore ram limitation.
Users browsing this forum: seriosha and 88 guests
