MUM Europe 2020
mcoferra
rb951G-2HnD PoE
Mon May 12, 2014 4:11 pm
Hi, is it possible to power on the rb951G-2HnD with PoE on Lan 1 ?
Can I use a PoE Switch or i need a iniector like this http://routerboard.com/RBGPOE ?
Marco
honzam
Re: rb951G-2HnD PoE
Mon May 12, 2014 4:19 pm
You need poe injector - as link above. Or poe switch http://routerboard.com/RB260GSP
LAN, FTTx, Wireless. ISP operator
mcoferra
Re: rb951G-2HnD PoE
Mon May 12, 2014 4:25 pm
Thank's for the answer.
If I use the power supply included I can only have PoE output power on LAN 5 to power on another PoE device, is it correct ?
honzam
Re: rb951G-2HnD PoE
Mon May 12, 2014 5:59 pm
rb951 dont have POE output on port5. Rb951G have only poe Input on port1.
POE output on port5 have http://routerboard.com/RB951Ui-2HnD
InoX
Re: rb951G-2HnD PoE
Tue May 13, 2014 6:55 pm
RB951Ui-2HnD PoE output function for port #5
http://wifimag.ro/pdf/RB951Ui-2HnD.pdf
raktim
Re: rb951G-2HnD PoE
Thu May 22, 2014 12:10 pm
Does RB951Ui-2HnD has input power in ether1 & output power in ether 5???
honzam
Re: rb951G-2HnD PoE
Thu May 22, 2014 1:50 pm
Yes
javierc
Re: rb951G-2HnD PoE
Mon Jun 13, 2016 5:39 am
Hi, wich is the part naumber and where can I buy this POE Adapter for RB951G in Spair or web page international?
Regards
Users browsing this forum: MSN [Bot] and 29 guests
