sergejs
v6.13 released!
Fri May 16, 2014 10:18 am
What is new at 6.13
What's new in 6.13 (2014-May-15 16:03):
*) console - comments are now accepted where new command can start, that is,
where '/' or ':' characters can be used to start new command, e.g.
/interface { # comment until the end of the line
print
*) backup - backups by default are encrypted now (with user password).
To use backup on older versions, you should disable encryption with dont-encrypt
flag when creating it;
*) files with '.sensitive.' in the filename require 'sensitive'
permission to manipulate;
*) lcd - reduce CPU usage when displaying static screens;
*) l2tp - fixed occasional server lockup;
*) pptp - fixed memory leak;
*) sstp - fixed crashes;
Simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu. If you run v5 or older, download the newest NPK package from our webpage, upload to your router, and reboot: http://www.mikrotik.com/download
NOTE:
We plan to have full release of CAPsMAN for general public in RouterOS v6.14!
Please, make all additional tests and report all persisting problems in wireless-fp package.
rextended
Re: v6.13 released!
Fri May 16, 2014 10:31 am
STILL EXIST ON 6.13
http://forum.mikrotik.com/viewtopic.php ... 88#p416454
BUG SIGNALED FROM 6.10 AND STILL NOT FIXED???
Opened another ticket for that: [Ticket#2014041566000226] 6.12 UNFIXED BUG: user-manager profile limitation
I wait again the fix on 6.14....
I'm Italian, not English. Sorry for my imperfect grammar.
ropeba
Re: v6.13 released!
Fri May 16, 2014 11:19 am
When we can expect solving of bug "IGMP proxy stop working on upstream interface down/up"? Described in: http://forum.mikrotik.com/viewtopic.php ... mp#p412317
janisk
Re: v6.13 released!
Fri May 16, 2014 11:22 am
we are working on this issue. no fix yet.
sergejs
Re: v6.13 released!
Fri May 16, 2014 12:23 pm
rextended, I will check for the issue, and try to find out why it is not fixed yet.
And we will try to fix it at 6.14 version.
sergejs
Re: v6.13 released!
Fri May 16, 2014 12:36 pm
Separate topic is made of OpenVPN bridning.
Please post all your notes there,
http://forum.mikrotik.com/viewtopic.php ... 90#p426390
Thank you very much for the cooperation.
joegoldman
Long time Member
Long time Member
Re: v6.13 released!
Fri May 16, 2014 12:39 pm
Hi Guys,
Just updated 951-2n to 6.13. I use RIP over a PPTP client interface, and as with every update since probably 6.9 or even earlier, after the first upgrade reboot, RIP routes do not become active. Another reboot of the whole board is required to get the routes back active (even tried disabling/enabling RIP before reboot).
I did report this a few versions ago but only on the forums.
Thanks,
Joe
panevdd
Re: v6.13 released!
Fri May 16, 2014 1:42 pm
Just upgraded from 6.12 to 6.13 (x86).
From the Winbox -> Queues -> Simple Queues - the list is empty.
In the terminal/ssh it's ok.
Anybody with the same problem?
congo
Re: v6.13 released!
Fri May 16, 2014 2:17 pm
Does v6.13 contain the fix for [Ticket#2014050866000407] ?
Chupaka
Re: v6.13 released!
Fri May 16, 2014 2:34 pm
[admin@TestPlace] > system clock pr
            time: 14:30:01
            date: may/16/2014
  time-zone-name: Etc/GMT-3
      gmt-offset: +03:00
[admin@TestPlace] >
"-3 is not equal to +3" is still not fixed :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
odge
Re: v6.13 released!
Fri May 16, 2014 2:52 pm
Hey, I see in v6.12 you allow DNS names in a PPTP adapter instead of using a script.
But one thing you should definitely add to the interface, is the ability to select the outgoing interface or route... because in multiple connection scenarios, you still need to update the route/mangle using a script... real bummer, but an easy fix to do it on the interface itself!
slvnet
Re: v6.13 released!
Fri May 16, 2014 3:45 pm
I'm new to MT, so maybe it was somethere on the forum...
I got and installed ROS 6.12RC20.
Now after pressed Download and Upgrade it Download and Reboot. After reboot still 6.13RC20.
Download manualy to Files -> Reboot. Still 6.13RC20.
How to upgrade to ROS 6.13 final ?
Best
uldis
Re: v6.13 released!
Fri May 16, 2014 3:50 pm
Is it happening only on x86 boxes?
Please contact support@mikrotik.com
If you access the Queue Simple from the Webfig do you see all the simple queue rules?
rextended
Re: v6.13 released!
Fri May 16, 2014 4:13 pm
Very thanks!
Chupaka
Re: v6.13 released!
Fri May 16, 2014 4:30 pm
it was described at the same place where RCs are available:
NOTE 2:
In some rare cases it might be impossible to do any package managment
(upgrade/downgrade/enable/disable/uninstall/install) in 6.13rc13+ rc versions,
board will simply reboot itself staying on previous version
This is fixed for the release version of 6.13 (2014-May-15 14:33) and newer:
Please, use Netinstall for upgrade/downgrade
rextended
Re: v6.13 released!
Fri May 16, 2014 5:37 pm
Best
Use netinstall.
rextended
Re: v6.13 released!
Fri May 16, 2014 5:49 pm
THIS PROBLEM DO NOT EXIST IN MY TWO x86 MACHINE.
>>> NETINSTALLED <<<
(because I can not upgrade from 6.13rc23 to 6.13 final)
McTedson
Re: v6.13 released!
Fri May 16, 2014 6:03 pm
Another winbox issue :
rextended
Re: v6.13 released!
Fri May 16, 2014 6:10 pm
And where is the issue?
I not see any issue!
McTedson
Re: v6.13 released!
Fri May 16, 2014 6:13 pm
Here's for comparison what it should look like.
Chupaka
Re: v6.13 released!
Fri May 16, 2014 6:16 pm
plus, 'Unknown' should not be here - it doesn't show up in Terminal :)
McTedson
Re: v6.13 released!
Fri May 16, 2014 6:17 pm
Must be some new link speed on some not yet released hardware :lol:
rextended
Re: v6.13 released!
Fri May 16, 2014 6:21 pm
SFP & SFP+ speed...
McTedson
Re: v6.13 released!
Fri May 16, 2014 6:28 pm
SFP & SFP+ speed...
No, SFP has a separate tab with all infos.
rextended
Re: v6.13 released!
Fri May 16, 2014 6:30 pm
The tab are separate, but the lisnk speed, is speed...
panevdd
Re: v6.13 released!
Fri May 16, 2014 6:49 pm
I'll upgrade some other devices in Monday and will see is the problem still here.
I've contacted support and got Ticket#2014051666000581.
From the Webfig the Queue list is empty, too.
I have some customers with a Cyrillic characters in their names; maybe this is a problem, but in the IP -> Firewall there is no such problem.
McTedson
Re: v6.13 released!
Fri May 16, 2014 6:59 pm
SFP does not have Status tab on my router.
tedkuban
Re: v6.13 released!
Fri May 16, 2014 7:07 pm
The problem described for 6.12 is not solved:
Upgrade from 6.11 cause stop IPSec communications.
dg8ngn
Re: v6.13 released!
Fri May 16, 2014 7:10 pm
it seems BCP bridging (PPP tunnel bridging) did break from 6.12 to 6.13. I used http://wiki.mikrotik.com/wiki/Manual:BC ... _bridging) for implementation. Instead of PPTP I use L2TP.
Using "export" the configuration of 6.12 and 6.13 are identically. Downgrading from 6.13 to 6.12 worked. Only the "Server"-Side is affected... I can provide the configuration if necessary.
Bye,
Jann
lorsungcu
Re: v6.13 released!
Fri May 16, 2014 7:41 pm
dg8ngn - can you go into more detail about what is broken with BCP in 6.13? I need to upgrade (apparently L2TP is broken in 6.12, which is half the reason I upgraded...), but rely pretty heavily on BCP.
slvnet
Re: v6.13 released!
Fri May 16, 2014 7:53 pm
NOTE 2:
I got only link to 6.13RC20 before,
http://forum.mikrotik.com/viewtopic.php?t=84801#p425567
Thanks a lot. I'll do netinstall
steen
Re: v6.13 released!
Fri May 16, 2014 9:52 pm
Hello Folks!
Sorry to sat that CRS and simple vlans, trunk and access ports still does not work.
I did reset configuration with no defaults and with defaults, result is the same.
I did not to a netboot install, that test remains.
However the CRS does not hang anymore when trying, otherwise it fails exactly like before.
Tested CRS examples (http://wiki.mikrotik.com/wiki/Manual:CRS_examples)
Port based VLAN [FAIL]
Inter VLAN routing [FAIL]
lorsungcu
Re: v6.13 released!
Fri May 16, 2014 10:04 pm
Found more issues with DHCP in BCP bridging in 6.12. Going to open a ticket but dont expect a fast enough response to matter. I dont see anything in the changelogs between 5.26 and 6.12 that would cause DHCP to break as it has, can someone from mikrotik confirm if anything is different?
Rudios
Forum Veteran
Forum Veteran
Re: v6.13 released!
Fri May 16, 2014 10:31 pm
I have experienced DCHP problems with BCP myself but as far as I remember the problems were solved in 6.11 or 6.12.
I don't know what your exact problems are?
I experienced problems where devices never got an IP address from the DCHP server over a PPTP link with BCP. My issue is also mentioned here
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
lorsungcu
Re: v6.13 released!
Fri May 16, 2014 11:20 pm
Yeah that sounds like what I'm seeing, although I'm using L2TP. I need 6.x for IPSec but it breaks all kinds of other stuff. This is maddening.
toni17
Re: v6.13 released!
Sat May 17, 2014 2:45 am
Queue Tree Global Parent still not working till 6... , This is very important for my Business .
I cant see my Huawei K4305 in system ports , so i cant send and receive sms .
Chupaka
Re: v6.13 released!
Sat May 17, 2014 4:05 am
details, please
c0d3rSh3ll
Long time Member
Long time Member
Re: v6.13 released!
Sat May 17, 2014 4:55 am
Hello Folks!
Any other user can confirm this bug?
The next week I need to do port based vlan in crs trunking to a rb but this news is so bad for me...
sent from my mobile phone using tapatalk
nothing
meetriks2
Re: v6.13 released!
Sat May 17, 2014 8:21 am
Well 6.13 seems be the first to have no problem with much higher cpu load compare to v5.6
(or is follow the path of v6.7 and it will show up over a week or so)
http://forum.mikrotik.com/viewtopic.php?f=2&t=84729
stefan803
Re: v6.13 released!
Sat May 17, 2014 9:15 am
since 6.13 I have a really bad sstp-throughput. I tried 6.9 - 6.12 yesterday and it's always been about 1 MB/s (that's about what the line can do). With 6.13 (inkl. the rc-versions) I get a maximum of about 200 kB/s.
The setup:
Lan1 Lan2
MikroTik <-> AVM Router <-> Internet <-> AVM Router <-> Mikrotik
(The AVMs need to be used as phone is voip)
Interesting: When connecting directly in Lan1 to the SSTP server the speed is fine, it's just happeining over the internet ... And did not happen before 6.13.
Do somebody know what might have changed in 6.13 that makes it beeing so slow over internet.. or that makes other components on the path beeing slower as with 6.12?
Thanks!
wichets
Re: v6.13 released!
Sat May 17, 2014 12:25 pm
Hi report bug
i use the 6.3 with aircard 312u it is working properly but after i have upgrade to 6.13 the error massage is occurred
please see error on the attached file
rgds/wichets
Maggiore81
Re: v6.13 released!
Sat May 17, 2014 1:32 pm
me too.
rebooted two times and they are back.
Dott. Elia Spadoni
Network Administrator,
MTCNA, MTCRE, MTCTCE, MTCINE, MTCWE, MTCSE
Spadhausen Internet Provider
Ravenna, ITALY
http://www.spadhausen.com
nicklowe
Re: v6.13 released!
Sat May 17, 2014 6:45 pm
I have noticed that the performance of SSTP is not as great as it could be. I had been hoping that things would improve with 6.13 - we were told that the OpenSSL library was being updated to the latest version.
This latest OpenSSL version implements cipher suites that use the ChaCha20-Poly1305 and AES in GCM.
Mikrotik should offer these in RouterOS with all the TLS dependent features like SSTP and use them in preference where available to drastically improve throughput and security for site-to-site tunnels.
The performance benefits of ChaCha20-Poly1305 are awesome:
http://googleonlinesecurity.blogspot.sg ... https.html
https://www.imperialviolet.org/2013/10/07/chacha20.html
It would be an easy performance win, especially on the lower end, resource constrained hardware.
For security reasons, RC4 should also be completely removed from RouterOS and definitely not used in preference anywhere - it presently is for SSTP. The stream cipher it is no longer considered secure due to biases. It is quickly being deprecated from other platforms such as Windows:
https://technet.microsoft.com/library/security/2868725 (2013)
https://technet.microsoft.com/library/security/2960358 (2014)
skibi82
Re: v6.13 released!
Sat May 17, 2014 7:00 pm
To fix problem use netinstall
Best
skibi82
Re: v6.13 released!
Sat May 17, 2014 7:02 pm
When there are plans to implement Xstp in CRS switch?
BinaryCrash
Re: v6.13 released!
Sat May 17, 2014 9:51 pm
It happened to me also on a CCR-1016-12G.
queue simple just stop updating on winbox, then i reopen winbox and it is empty.
At terminal/ssh i can see the rules there.
In winbox and webfig the list is empty.
If i reboot the router, i can see it again, but seconds after the list get empty.
The queue is working, just the list does not show up.
I have over 1100 simple queue rules.
BinaryCrash
Re: v6.13 released!
Sat May 17, 2014 10:00 pm
Also i would like to report two of my CCR-1016-12G got error: "file operation error" when i try to save any backup or save export file.
Same error show when i try to delete any file.
this happened to 2 routers that have more than 1000 simple queues and store graphs.
The backup on both got 19 MB on the last run, automated.
I did reset the configuration and imported using terminal and it is working again.
Only happened on the routers with over 1000 simple queues.
The other routers with just a few queues didn't have this issue.
All same model, version 6.12. Firmware ok.
Looks like the router stop writing to disk after some amount of data. Like a limit.
I still have the backups if you would like to test it.
I didn't test this problem on version 6.13 as i don't have a spare core router to test it yet.
I also got some problems using export compact and trying to restore some arp entries didn't have interface on it.
Maybe to do this we need to use verbose. Version was 6.12 when i did this.
Chupaka
Re: v6.13 released!
Sun May 18, 2014 1:02 am
please check not only "/queue simple print", but also "/queue simple print stats" - I sometimes have such problem on v6.7 with queue tree, winbox list is empty, and printing stats gets timeout. it sometimes happens when I change queue type on highspeed queue (>1Gbps of traffic)
BinaryCrash
Re: v6.13 released!
Sun May 18, 2014 1:52 am
keep waiting for response and nothing happens, until i press control+C to cancel.
I have two routers.
One with 6.12 and one with 6.13
The one with 6.12 have 1300+ queues.
The other with 6.13 have 1228 queues.
Commands stats, rate, packets, bytes does not work in 6.13 terminal.
6.12 router (A):
ros code
/interface monitor-traffic aggregate
    rx-packets-per-second:     18 962
      rx-drops-per-second:          0
     rx-errors-per-second:          0
       rx-bits-per-second:  109.3Mbps
    tx-packets-per-second:     18 356
      tx-drops-per-second:          0
     tx-errors-per-second:          0
       tx-bits-per-second:  104.5Mbps
6.13 router (B):
ros code
rx-packets-per-second:    17 000
       rx-bits-per-second:  97.5Mbps
    tx-packets-per-second:    16 231
       tx-bits-per-second:  89.9Mbps
steen
Re: v6.13 released!
Sun May 18, 2014 7:07 pm
Hello Folks!
We now also tested netinstall, result is exactly the same as before, the device does not work with this very basic vlan configuration.
Is there anybody out there who have got this switch work with vlans and trunk, if so please share how you did it ?
IPANetEngineer
Trainer
Trainer
Re: v6.13 released!
Sun May 18, 2014 11:55 pm
Thanks for 6.13 MikroTik....looking forward to testing in our Data Centers
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
normis
Re: v6.13 released!
Mon May 19, 2014 8:46 am
            time: 14:30:01
            date: may/16/2014
      gmt-offset: +03:00
[admin@TestPlace] >
That this is not a bug, you should be using the "manual" menu, not changing the timezone name. Apparently there is a international timezone called "GMT-3" which sets your offset to +3. Don't touch the name, only set offset if you want custom offset. We use the timezone names from the official list: http://www.iana.org/time-zones
JanJoh
Re: v6.13 released!
Mon May 19, 2014 10:11 am
I may be doing something silly, but it would appear that the "Hey, look at me guys, I am now a hub!"-behaviour of my CRS125 has returned after upgrading to 6.13
But the previous fix command (/interface ethernet switch port set [find] learn-restricted-unknown-sa=yes) does not seem to be accepted anymore?
So, what may i be missing?
rextended
Re: v6.13 released!
Mon May 19, 2014 10:20 am
            time: 14:30:01
            date: may/16/2014
      gmt-offset: +03:00
[admin@TestPlace] >
# These entries are mostly present for historical reasons, so that
# people in areas not otherwise covered by the tz files could "zic -l"
# to a time zone that was right for their area. These days, the
# tz files cover almost all the inhabited world, and the only practical
# need now for the entries that are not on UTC are for ships at sea
# that cannot use POSIX TZ settings
# We use POSIX-style signs in the Zone names and the output abbreviations,
# even though this is the opposite of what many people expect.
# POSIX has positive signs west of Greenwich, but many people expect
# positive signs east of Greenwich. For example, TZ='Etc/GMT+4' uses
# the abbreviation "GMT+4" and corresponds to 4 hours behind (-4) UT
# (i.e. west of Greenwich) even though many people would expect it to
# mean 4 hours ahead (+4) of UT (i.e. east of Greenwich).
Zone	Etc/GMT-14	+14	-	GMT-14	# 14 hours ahead of GMT
Zone	Etc/GMT-13	+13	-	GMT-13
Zone	Etc/GMT-12	+12	-	GMT-12
Zone	Etc/GMT-11	+11	-	GMT-11
Zone	Etc/GMT-10	+10	-	GMT-10
Zone	Etc/GMT-9 	+9 	-	GMT-9
Zone	Etc/GMT-8 	+8 	-	GMT-8
Zone	Etc/GMT-7 	+7 	-	GMT-7
Zone	Etc/GMT-6 	+6 	-	GMT-6
Zone	Etc/GMT-5 	+5 	-	GMT-5
Zone	Etc/GMT-4 	+4 	-	GMT-4
Zone	Etc/GMT-3 	+3 	-	GMT-3
Zone	Etc/GMT-2 	+2 	-	GMT-2
Zone	Etc/GMT-1 	+1 	-	GMT-1
Zone	Etc/GMT+1 	-1 	-	GMT+1
Zone	Etc/GMT+2 	-2 	-	GMT+2
Zone	Etc/GMT+3 	-3 	-	GMT+3
Zone	Etc/GMT+4 	-4 	-	GMT+4
Zone	Etc/GMT+5 	-5 	-	GMT+5
Zone	Etc/GMT+6 	-6 	-	GMT+6
Zone	Etc/GMT+7 	-7 	-	GMT+7
Zone	Etc/GMT+8 	-8 	-	GMT+8
Zone	Etc/GMT+9 	-9 	-	GMT+9
Zone	Etc/GMT+10	-10	-	GMT+10
Zone	Etc/GMT+11	-11	-	GMT+11
Zone	Etc/GMT+12	-12	-	GMT+12
I hope this clarifies everything permanently.
skillful
Trainer
Trainer
Re: v6.13 released!
Mon May 19, 2014 10:47 am
I confirm this issue on RB1200.
Simple queues are gone in both winbox and webfig. Sometimes the queue are there but frozen in time. After a reboot, simple queues display properly in winbox for sometime before freezing or disappearing. This appears to be a display issue because the simple queues are still functional and limiting clients though.
wolfeyes
Re: v6.13 released!
Mon May 19, 2014 11:52 am
Has anyone noticed any port flapping issue with this release on the CRS125?
samotoka
Re: v6.13 released!
Mon May 19, 2014 11:57 am
winbox still crash when conected via pptp
Proud owner of a RB2011UAS-2HnD-IN with ROS 6.19,
pc i586 2004 Mhz Athlon XP with ROS 3.30,
pc i586 330 Mhz Pentium II with ROS 3.30,
old pc 233 Mhz Cirix with ROS 2.9.27
bysard
Re: v6.13 released!
Mon May 19, 2014 12:27 pm
Same here.
_saik0
Re: v6.13 released!
Mon May 19, 2014 3:37 pm
Don't know if there should be a separate topic, but here goes.
I'm running a L2TP/IPSec/OSPF VPN between multiple MikroTik 2011UAS routers.
I'm having issues on 6.13 where I have to frequently flush SAs to reconnect dropping L2TP connections.
On 6.10 this happened from time to time, but on 6.13 it's now happening during the first 30minutes of established L2TP connection.
I can only see the message
ipsec,debug <peer-ip> give up to get IPsec-SA due to time up to wait.
The DPDs seem to be exchanged (successfully!) even after this happens, but it doesn't try to flush the old SA and establish a new one.
Only manual flush helps, and this is needed only on one side of the VPN.
This is from the side with "send initial contact" option enabled.
On the other side, there's ROS 6.6 for one tunnel and 5.14 for the other.
I've seen so many issues with l2tp/ipsec in the 6.x release (including the buffer and complete loss of connectivity) that i don't even know which version to use as a safe starting point :(
tedkuban
Re: v6.13 released!
Mon May 19, 2014 4:19 pm
6.11 can connect with 5.26 through IPSec, however some days later there is an error of "No buffer space available". 6.12 and 6.13 don't connect neither with 6.11, nor with 5.26. In this regard a question - Can I downgrade the CRS125 to version 5.26?
visalink
Re: v6.13 released!
Mon May 19, 2014 5:14 pm
            time: 14:30:01
            date: may/16/2014
      gmt-offset: +03:00
[admin@TestPlace] >
Normis, and the following is a bug in the log or not?
Chupaka
Re: v6.13 released!
Mon May 19, 2014 5:17 pm
ha-ha, thanks, guys! at last, after years, I got an answer :D
"In order to conform with the POSIX style, those zone names beginning with "Etc/GMT" have their sign reversed from what most people expect."
visalink
Re: v6.13 released!
Mon May 19, 2014 5:34 pm
I'm always testing the RouterOS on a large distance, mikrotik made ​​a mess in version 6.13rc20.
There is an alternative solution to upgrade the version 6.13rc20 except with netinstal?
rextended
Re: v6.13 released!
Mon May 19, 2014 7:13 pm
NO.
It's not a good idea to test on large distance...
If you read the WARNING already present on 6.13rc20 download page, you know this problem.
But you have read the WARNING, true?
rextended
Re: v6.13 released!
Mon May 19, 2014 7:15 pm
Follow exactly this passage:
Set timezone to manual,
click apply,
DO NOT USE "UNDO"
set the right time zone,
reboot,
done.
[this problem appear only if the 6.8+ are installed by updating old RouterOS and not appear if you use netinstall to install directly 6.8+]
rextended
Re: v6.13 released!
Mon May 19, 2014 7:20 pm
Oh, finally ;)
wa4zlw
Re: v6.13 released!
Mon May 19, 2014 7:31 pm
hi folks...I was running 6.12 and switched to 6.13 and I think that was a mistake. I am using IPSec tunnels to my other sites and it seems OSPF no longer propagates across the tunnels. I have a Watchguard XTM520 running latest released code which is my hub for all tunnels.
Anyone else having similar issues? I also noticed that you have to flush manually; if a rekey comes in itjust adds them to the list and doesnt get rid of the old ones.
I need this working.
Mikrotik really needs to stop adding "features" and needs to concentrate on fixing bugs.
Leon
_saik0
Re: v6.13 released!
Mon May 19, 2014 7:38 pm
OSPF failing for me is just the result of L2TP tunnel terminating again as a result of IPSec failing.
Anyhow, as i described above, similar issues - IPSec indeed seems very unstable in the whole 6.x release. In fact it's getting worse with every new version.
Fully support you on that one mate, MT stop adding new stuff, fix CORE issues.
visalink
Re: v6.13 released!
Mon May 19, 2014 9:17 pm
click apply,
DO NOT USE "UNDO"
reboot,
done.
rextended
The correct procedure would be:
Set manual time zone to +00:00,
click apply,
no reboot necessary,
done.
Regards,
Dzieva.
rextended
Re: v6.13 released!
Tue May 20, 2014 1:57 am
click apply,
DO NOT USE "UNDO"
reboot,
done.
rextended
click apply,
done.
Regards,
Dzieva.
I'm happy to have hinted you ;)
Trema
Re: v6.13 released!
Tue May 20, 2014 10:42 am
I think there is a bug in the DHCPv6 client, that was introduced in 6.12. I observed this behaviour on both a 2011UiAS-2HnD and a 750GL.
When the option "Use Peer DNS" in the DHCPv6 client is checked, the v6 DNS addresses are added to the list of DNS servers, instead of being refreshed, each time the lease is renewed.
This results in an ever growing list of (v6) DNS servers:
Beeski
Re: v6.13 released!
Tue May 20, 2014 12:06 pm
Are the wireless improvements in 6.13rc23 included in the official 6.13 release?
Can you give us a description of these improvements?
thanks,
Mike
normis
Re: v6.13 released!
Tue May 20, 2014 12:21 pm
thanks,
Mike
Everything in the last RC is included in the final release.
Which wireless improvements do you mean? This is the official changelog:
print
Beeski
Re: v6.13 released!
Tue May 20, 2014 12:35 pm
Looking good with first tests
Please contact the support@mikrotik.com <mailto:support@mikrotik.com> to
get access to the v6.13rc versions so you could try out the new test
RouterOS version which has some improvements for the wireless driver
including the new wireless-fp package
bobxiao
Re: v6.13 released!
Tue May 20, 2014 12:36 pm
routing mark can not use
klaparp
Re: v6.13 released!
Tue May 20, 2014 1:40 pm
After upgrade to 6.13 i get "ERROR: Internal Server Error" when trying to log in.
I have tested on 2 different routers. one 750 and onte 2011 with same result. '
Suggestions?
rextended
Re: v6.13 released!
Tue May 20, 2014 1:48 pm
Login from where?
jsahoka
Re: v6.13 released!
Tue May 20, 2014 3:08 pm
Maybe its just me,
I am on 6.13 and every time I click Quick Set in winbox it shows my passwords in plain text even though the "Hide Passwords" option is checked in winbox, the "hide" box next to the WiFi Passwords keeps getting unchecked and the password is shown in plaintext.
bartjoo
Re: v6.13 released!
Tue May 20, 2014 3:38 pm
Hello, is there a release list (features, fixes, bues) for Capsman to?
normis
Re: v6.13 released!
Tue May 20, 2014 3:49 pm
Maybe its just me,
Looks like a bug, I can repeat
jsahoka
Re: v6.13 released!
Tue May 20, 2014 4:00 pm
Maybe its just me,
Hey Normis,
Thanks for the reply, do i need to submit an official bug report to try and get it fixed or is this sufficient?
normis
Re: v6.13 released!
Tue May 20, 2014 4:01 pm
Maybe its just me,
Hey Normis,
I have already submitted a bug report, so you don't need to do that :)
jsahoka
Re: v6.13 released!
Tue May 20, 2014 4:07 pm
Thanks !
wa4zlw
Re: v6.13 released!
Tue May 20, 2014 4:24 pm
what about the OSPF/IPSec issues which also seem to be in 5.26?
klaparp
Re: v6.13 released!
Tue May 20, 2014 5:50 pm
Suggestions?
Get same problem with both webgui and winbox.
2-3 restarts solved the problem on my testing router, I´ll get back later tonight if it works for the production router.
/HW
Beeski
Re: v6.13 released!
Tue May 20, 2014 7:13 pm
print
is wireless-fp included in the official 6.13 release?
I am guessing no based on comments in the thread below:
http://forum.mikrotik.com/viewtopic.php ... ireless+fp
jarda
Re: v6.13 released!
Tue May 20, 2014 10:21 pm
No it isn't. You have to download it separately. But it is obvious on download webpage...
jondavy
Re: v6.13 released!
Wed May 21, 2014 2:58 am
I did upgrade from the menu /system upgrade and were not installed some packages defaults as MPLS, then I had to manually reinstall the MPLS package
patrickmkt
Re: v6.13 released!
Wed May 21, 2014 7:53 am
Something I just noticed after updating two routers to 6.13:
When I connect via SSTP from one ROS client to one ROS Server, the firewall rule associated with this SSTP connection stays red on the server after connection.
It was working before on previous versions. Is there a new parameter that I didn't see in the update that I need to change or is it a regression?
rextended
Re: v6.13 released!
Wed May 21, 2014 9:17 am
I know that is off-topic but please someone of MikroTik staff, or another one ingeneer, reply on this post:
http://forum.mikrotik.com/viewtopic.php ... 95#p427295
brosky
Re: v6.13 released!
Wed May 21, 2014 11:28 am
Same here, 6.13 on RB1100AHx2, queues are not displayed and if I restore from backup they are displayed for a while and then they are missing again.
How can I downgrade to a previous version ? Where is a repository with older versions ?
Chupaka
Re: v6.13 released!
Wed May 21, 2014 12:13 pm
check /log
DjM
Re: v6.13 released!
Wed May 21, 2014 1:15 pm
Try to double-click on firewall rule, reselect again the same sstp-server interface, clisk OK and it should be fine. It seems that there were some changes in sstp-server interface indexing in 6.13 .
klaparp
Re: v6.13 released!
Wed May 21, 2014 1:44 pm
Suggestions?
/HW
Didnt help on the production router so I downgraded to 5.26. Also noticed that BCP wont work on 6.12 or 6.13 so its pretty useless. Something major is broken I think.
dg8ngn
Re: v6.13 released!
Wed May 21, 2014 3:49 pm
Yes, on the L2TP-Server side the packets are not bridged anymore. Downgrade to 6.12 fixed it.
rdhw
Re: v6.13 released!
Wed May 21, 2014 6:11 pm
Yes, I see the same server-side BCP failure over PPTP. Client-side BCP OK on 6.13, but server-side BCP did not work at 6.13 and required to be down-graded to 6.12.
Clauu
Re: v6.13 released!
Wed May 21, 2014 6:29 pm
Same here.
Same..
Having fun with RB850Gx2, RB2011UiAS-2HnD, RB260GSP, RB751U-2HnD, CRS112, RB3011UiAS, hAP ac, cAP ac and hAP ac². More others on the way :-)
patrickmkt
Re: v6.13 released!
Wed May 21, 2014 7:45 pm
I already did that but still same behavior on the next reconnection. The firewall rule stays red and I have to reselect it manually again.
DjM
Re: v6.13 released!
Wed May 21, 2014 11:19 pm
In this case I can see two options:
1) Wait for 6.14 release, there are also some SSTP bug fixes
2) Generate support file and send it to MK support
The third possible option can be selecting a different interface in firewall rule, apply configuration, then select back the sstp-server interface and apply configuration. I haven't tested this step so I'm not sure if it will help, but you can share you experience :-)
skibi82
Re: v6.13 released!
Wed May 21, 2014 11:26 pm
I think 6.13 is as good firmware.
1. Do Not hangs when l2tp/sstp/pptp all versions greater than 6.7 unfortunately had fucked implementations of these tunnels (with 200 tunnels and a large movement of the device had to August reboot using the watchdog)
Apart from the odd behavior of a process and a higher load mgnt far knock on wood work
2. IPSEC for me is ok about 300 tunnels after the upgrade works correct
I can honestly say I see a light in the tunnel
gl4ck
Re: v6.13 released!
Wed May 21, 2014 11:34 pm
Got the same problem with L2TP interfaces, unfortunately changing the rule and changing it back to the l2tp-interface did solve the problem only until the next reconnect.
For the time being I went back to 6.12...
patrickmkt
Re: v6.13 released!
Thu May 22, 2014 12:07 am
Option 3 does not work either. The only way so far was to disable/enable the rule again.
I can maybe write an ugly workaround script to check the status of the sstp and then enable the firewall rules, but that's really a waste of resources.
DjM
Re: v6.13 released!
Thu May 22, 2014 9:40 am
Workaround with script is not a good option, I think. Ask for 6.14rc version, where are sstp-server interface bindings fixed (related to another SSTP issue), and if the issue will be active also in the RC version, then the last step is to generate support file and send it to MK, I think. For me are the interface bindings working fine in firewall rules (ROS 6.13), but it doesn't mean that there is no other issue.
nick3dos
Re: v6.13 released!
Thu May 22, 2014 10:05 am
I just recieved my new CCR1009-8G-1S
Upadate to 6.12 -> OK
Upadate to 6.13 -> Problem !!!
soulflyhigh
Re: v6.13 released!
Thu May 22, 2014 10:22 am
A "cosmetic" bug in winbox, "full duplex" value isn't shown :
MTCRE, MTCTCE, MTCSE
mangust
Re: v6.13 released!
Thu May 22, 2014 11:13 am
PPC package for CCR box ?
normis
Re: v6.13 released!
Thu May 22, 2014 11:17 am
No, you must use the Tile packge for CCR
nick3dos
Re: v6.13 released!
Thu May 22, 2014 11:21 am
I downloaded Tile package
I tried to updated again.
with the second try, all is ok now...
I don't know what happened the first time (imported the same files !!!)
Rudios
Forum Veteran
Forum Veteran
Re: v6.13 released!
Thu May 22, 2014 1:04 pm
There is a second entry of "Full Duplex" in the available columns. Also there is a "Speed" column which is blank.
But the "Rate", as you see, is filled. If you choose the other "Full Duplex" column, it will also be filled.
morf
Re: v6.13 released!
Fri May 23, 2014 5:43 pm
After the broadcast storm, stop working Vlan on CCR.
Please check.
bartjoo
Re: v6.13 released!
Fri May 23, 2014 9:32 pm
Hello everyone, i use al lot off hotspots in my network.
but when i upgrade my routers to the latest version, the upgrade have some problems.
The ip addresses are active the bridge and change after the upgrade to a WLAN connection
OR
The dhcp server was active on the bridge and after the upgrade its on a WLAN connection.
So after the upgrade, some functions didnt work well anymore. I had to change it by meself.
Erastus
Re: v6.13 released!
Sat May 24, 2014 5:18 am
Upgraded 5 493 two are hanging. Need to drive to reboot.
The old ways are bagain.
Carefull before you upgrade. Systems do hang when you upgrading to Ver 13
steen
Re: v6.13 released!
Sat May 24, 2014 12:33 pm
Hello Folks!
At RoS6.7 L2TP was working properly, after RoS6.7 L2TP stops transferring data after anything between 70Kb to 13MB.
The same goes for V6.13.
It is for all RB platforms, RB411, RB433, RB333, RB600, RB2011UAS, RB750 and so on.
Anyone else who had experiense of problem with L2TP ?
I will put a supout and make ticket to MT about it, we are now stuck to RoS6.7 and have to rollback entire environment, nothing works...
bartjoo
Re: v6.13 released!
Sat May 24, 2014 12:36 pm
Hello Folks!
Its look like, i have the same problem, but with PPTP. Yesterday i upgraded my hotspots from 6.7 to 6.13 but the connections were bad. So i downgrade everything to 6.7 again and no problems anymore.
steen
Re: v6.13 released!
Sat May 24, 2014 1:17 pm
Hello Folks!
I put a supout file to Support, and did a test transfering a file in the tunnel and at same time I was logged in to the target without tunnel making that supout and took some screenshots on what is going on there.
I saw the rb device become "busy" for some time right after traffic stopped, and it simply throws out the tunneled winbox session.
I did downgrade the device to RoS6.7 again but left firmware to 3.14, it then stabilized. Shortly after whole l2tp infrastructure collapsed and I did downgrade all of them.
pcunite
Re: v6.13 released!
Sun May 25, 2014 4:13 pm
v6.13 has been good for me so far, ping replies for example are 10ms quicker. Overall seems to be a faster release.
theprism
Re: v6.13 released!
Mon May 26, 2014 3:19 am
6.13 BAD in my case!
firewall rules that are written for an inactive L2TP are not active - red, which is normal.
But once L2TP became connected the firewall rule isn't activated, so it remains red and logs are filled with input errors on the l2tp interface.
If I recreate the same rule, the old one became active now - until the next reboot.
Downgrading...
6.12 was bad for my RB951G-2HnD. It just keeps crashing the kernel on the Routerboard for unknown reasons. Even access to the routerboard dissapears and any accesses outside it became dead. 6.12 works just fine on my RB751G-2HnD and RB751U-2HnD.
Won't try 6.13 there.
Haven't tried 6.11-6.2.
6.1 was a nightmare for L2TP+IPSEC.
Downgrading back to stable 6.0 (for me).
CStrauch
Re: v6.13 released!
Mon May 26, 2014 3:51 pm
Anyone tried 802.3ad (trunk) on CRS?
With 2 CRS-125 it worked fine but when trying to connect with a HP V1910 (Link Aggregation / Dynamic) I can't get the ports to sync using the new "trunk" option on CRS.
Also I tried to sync CRS's trunk with CCR's bond with no luck.
The BOND feature syncs up with V1910 Link Aggregation, but on CRS-125 it maxes the CPU up.
machack
Re: v6.13 released!
Mon May 26, 2014 4:27 pm
In Winbox, interface shows traffic intermittently. from snmp has the same problem.
Cesar Javier Robles
www.windnet.com.ar
MTCNA - MTCTCE - MTCRE - MTCWE
Belgarion186
Re: v6.13 released!
Mon May 26, 2014 4:30 pm
You'll need to set it to Static Link Aggregation. Dynamic doesn't work with non MT devices (tested with Cisco & Intel).
CStrauch
Re: v6.13 released!
Mon May 26, 2014 8:23 pm
So, the trunk is NOT 802.3ad.
BTW, I have a Dynamic Link Aggregation from a HP V1910 and a Planet Switch working just fine... And V1910 and MT Bond.
Thanks!
mmc1800
Re: v6.13 released!
Mon May 26, 2014 8:50 pm
Problem: After upgrade to 6.13 WinBox session will not stay open.
After upgrading an OmniTIK from I think it was 5.19 that I access over an L2TP VPN I cannot keep a WinBox session open.
It drops the session and disconnects after a few seconds. I did a firmware upgrade after I did the 6.13 upgrade, so now it is at firmware 3.13.
I can keep connected to the OmniTIK just fine with SSH, and I do not lose connections to older versions of winbox that are connected through that OmnitTIK, so there is no problem with the link, or the VPN or anything connection related, the problem is only with keeping a WinBox session active to the newly upgraded device.
This is not mission critical as I can manage the OmniTIK through the ssh interface, but it is annoying, and I am not going to upgrade anything else until I can figure out how to resolve this issue.
Thanks for any ideas!
--MMc
Access the dharma and give me some karma!
Belgarion186
Re: v6.13 released!
Tue May 27, 2014 3:30 am
Thanks!
I believe 802.3ad specs cover both SLA and dynamic. Took me quite a while of trial and error before I got my Teaming on my Intel Pro/1000 PT Dual Port to work with the CRS226.
BTW, setting the Intel to 802.3ad Dynamic will literally crash the CRS226 needing a reboot. Setting Cisco SG200 switch to Dynamic will not crash CRS226 but the link doesn't pass traffic.
I'm just surprised why Interface-Bonding is 802.3ad Dynamic but Port-Trunking is static. :shock:
kei888
Re: v6.13 released!
Tue May 27, 2014 4:48 am
Hi folks!
Can someone teach me how I can convert one Ethernet port of Mikrotik 1100AH PPC router to be a TRUNK port and pass tagged VLANS?
Desired set-up is:
1100AH's ether2 --- trunk ---- Cisco switch.
Thank you.
onnoossendrijver
Re: v6.13 released!
Tue May 27, 2014 11:18 am
You can add a 'vlan interface' to a physical port and give that interface a specific vlan tag.
Then you can do whatever you want with that interface. All traffic from that interface will have the specified vlan tag on the underlying physical interface.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
kei888
Re: v6.13 released!
Tue May 27, 2014 11:53 am
So it's not anymore necessary to create a bridge interface then add the port of ether2(trunk) and the vlans?
Thanks.
SwissWISP
Re: v6.13 released!
Tue May 27, 2014 12:35 pm
It depends on what you want to do. In general, this isn't necessary and it wasn't before.
CStrauch
Re: v6.13 released!
Tue May 27, 2014 5:18 pm
Thanks!
I actually tried setting the V1910 for static and it seemed to work. The problem is when it's static and something happens you loose conectivity (at least in my case, since the interfaces are not directly connected to each other).
I think the port trunking still needs a little work....
rextended
Re: v6.13 released!
Tue May 27, 2014 8:36 pm
PLEASE ADD THIS FEATURE ON ROUTEROS:
STOP (by option on/off) TO SEND THESE F(self-censored) HTTP HEADERS FROM WEB-PROXY:
HTTP_VIA 1.1 <public_ip_on_mikrotik_wan> (Mikrotik HttpProxy)
HTTP_X_PROXY_ID <routerboard_serial_number>
HTTP_X_FORWARDED_FOR <true_ip_of_the_computer>
OR EVERYTIME WE GET THIS ON ALL COMPUTER OF ALL USERS:
rextended
Re: v6.13 released!
Tue May 27, 2014 9:12 pm
OHHHHHHHHHHHHHHHHHHHHHHH!!!!
YOU READ ON MY MIND???
*) proxy - added 'anonymous' option which will skip adding X-* and Via headers;
RouterOS +100
THANKS!!!
dohmniq
Re: v6.13 released!
Tue May 27, 2014 10:39 pm
Anyone else using SNMP to query registration table entries?
I've raised Ticket#2014051566000304 asking for tx-ccq, rx-ccq and distance to be made available (ap would be nice too). Not sure what the procedure is for people to add support to a new feature but here's at least a ticket number you can quote.
Also, some SNMP responses, specifically MAC addresses in strings, could be normalized to reduce coding/processing load:
MIKROTIK-MIB::mtxrWlApBssid.2 = STRING: 0:c:42:f1:c4:95
It would help me if this had leading zeros like %02d:
MIKROTIK-MIB::mtxrWlApBssid.2 = STRING: 00:0c:42:f1:c4:95
Case conversion isn't an issue but parsing mac-addresses just to pad with leading zeros is more code I could do without writing - especially if it just mean editing a printf-style format string by MikroTik. Would this be of any use to anyone else OR would this actually BREAK anyone's existing production setup? (I'd guess not)
Chupaka
Re: v6.13 released!
Tue May 27, 2014 10:59 pm
how do those headers affect that behaviour? we don't use proxy, but some users face this situation if there are many users NATted behind one ip address
rextended
Re: v6.13 released!
Tue May 27, 2014 11:27 pm
I have behind nat some "low profile" users, ~200 user, never have this problem, but when I use web-proxy only for 10, 20 users, this problem come out, because Google not like proxy... is assuming that are bots if see HTTP_VIA header...
rextended
Re: v6.13 released!
Tue May 27, 2014 11:29 pm
In my opinion the right behavior must be: all you can obtain (read) from API or script, you must also able to read from OID...
Not only some specific set of values.
dohmniq
Re: v6.13 released!
Wed May 28, 2014 12:36 am
That would be the ideal situation, I agree!
Ignore my above rubbish - the formatting was done by snmpwalk using the SNMPv2-TC MIB but when I actually get the data it's an octet string so I can format it how I like - d'oh! :oops:
skibi82
Re: v6.13 released!
Wed May 28, 2014 10:16 am
Request a positive one variable informing about the configuration sequence number.
This variable should be automatically updated eg enum or something similar, gets called reconfiguration. It was applicable to the case of automatic copy.
Very useful for synchronizing devices in the cluster.
enc
Re: v6.13 released!
Wed May 28, 2014 12:47 pm
@MikroTik: is this fixed in 6.14?
DjM
Re: v6.13 released!
Thu May 29, 2014 12:09 pm
@enc:
I was able to replicate the issue with firewall rules only in case that sstp-client binded into sstp-server interface and sstp-interface used in firewall rule was ROS in versions range 6.8 - 6.13 (including). SSTP clients 6.7, 5.26, 6.14rc10 are working fine for me, SSTP server used in testing environment was 6.13 and 6.14rc10. Based on this it seems that it should be connected to confirmed SSTP bug in versions 6.8 - 6.13 (including).
Which ROS version are your SSTP clients using?
enc
Re: v6.13 released!
Thu May 29, 2014 1:16 pm
@enc:
ROS 6.13
the situation is even worst with the stability of my windows sstp clients. the connection drops after some 2-5min.
we use our ccr since 4 month in production now and i have to say the vpn impl is absolutely crap. bugs over bugs an no stable release in sight. how can this be...
DjM
Re: v6.13 released!
Thu May 29, 2014 1:49 pm
@enc:
ROS 6.13
@enc:
Try to use SSTP client with version out of range 6.8 - 6.13 (included) if the issue will still persist on SSTP server, where the firewall rules are implemented.
Just to give a full information, I'm providing you my test environment results:
sstp-server1 - 6.14rc10, firewall rules with sstp-server interface binding used
sstp-server2 - 6.13, firewall rules with sstp-server interface binding used
sstp-client1 - 6.14rc10
sstp-client2 - 6.13
sstp-client3 - 6.7
I have recorded issue with invalid firewall rules only in case, that one or more sstp-server interfaces was used with client 6.13, other firewall rules, where sstp-server interfaces with clients 6.14rc10 and 6.7 were used I haven't seen the issue. Reported issue with Windows 7 SSTP client I'm not able to replicate as I don't have Windows 7 test client at this moment.
Neilson
Re: v6.13 released!
Thu May 29, 2014 2:37 pm
Is anyone else seeing their Winbox crash when they double click to open the WLAN1 interface on the interfaces tab on the first tab of the Wireless window?
I have noticed this on some Sextant G models when updated to ROS6.13 and with the latest firmware for it.
Looking to see if others have experienced it or if not I will submit some supouts to try trace it down.
I have experienced it on radios doing both 802.11 and NV2.
I don't experience the crash when I am looking at individual radio connection details by double clicking on the registered clients.
This has been tried both on Mac under latest wine 1.7.19 and also on a windows 7 VM (up to date) with winbox running.
Under wine it locks up the window totally, on windows it just crashed the whole winbox and drops you back to the desktop.
Regards
Alexander
DjM
Re: v6.13 released!
Thu May 29, 2014 2:45 pm
Regards
Alexander
Winbox -> Wireless -> Interfaces -> wlan1 => no issue, no crash
ROS 6.13, RB433UAH, Windows XP
Try to connect without "Load Previous Session" checked in winbox login dialog.
Chupaka
Re: v6.13 released!
Thu May 29, 2014 2:51 pm
ROS 6.13
seems like it's known problem:
What's new in 6.14rc10 (2014-May-26 14:52):
*) sstp - fixed problem where session was closed every 2min;
Neilson
Re: v6.13 released!
Thu May 29, 2014 2:52 pm
Thanks, that helped when loading directly through winbox, do I need to open and close it successfully a few times to clear the "last session" information from loading it in the dude?
I am getting this as the error when in Wine:
ACCESS VIOLATION EXCEPTION at address: 6249cfda
eip=6249cfda eflags=210202
edi=0 esi=adcde0 ebp=adcdb8 esp=adcd80
eax=adcde0 ebx=adcd98 ecx=0 edx=0
backtrace:
6249d035 624a72ab 624ac3f0 624ade46 624a4907 624508cf 624b077b 6252adaf 6249b396 6249b47a 624592ad 62498c5e 6246d5cb 6246eb1a 6246ee26 426b207a 426b32db 426b3493 42682d98 6246af63 6246afcc 624cc6ca 5037ca
stack:
8 0 0 0 2 240000 0 0 adcdf8 16e7240 adcdc8 adcde0 6258664c 16e7240 adcdc8 6249d035
linked to KERNEL32!
modules:
400000 dude.exe
7bc10000 ntdll.dll
7b810000 KERNEL32.dll
68dc0000 libcairo-2.dll
64f80000 libfontconfig-1.dll
68f40000 libexpat-1.dll
42410000 msvcrt.dll
64880000 libfreetype-6.dll
65300000 libpixman-1-0.dll
69c80000 libpng12-0.dll
424b0000 gdi32.dll
425b0000 advapi32.dll
404f0000 msimg32.dll
42620000 user32.dll
420d0000 version.dll
65340000 libgdk_pixbuf-2.0-0.dll
6d580000 libgio-2.0-0.dll
685c0000 libglib-2.0-0.dll
43010000 ole32.dll
42770000 rpcrt4.dll
43130000 shell32.dll
43370000 shlwapi.dll
43510000 ws2_32.dll
6dd00000 libgmodule-2.0-0.dll
63a40000 libgobject-2.0-0.dll
6c240000 libjpeg-62.dll
6d140000 libnetsnmp-15.dll
68e40000 librsvg-2-2.dll
66440000 libcroco-0.6-3.dll
70f40000 libxml2-2.dll
65580000 libpango-1.0-0.dll
6d4c0000 libpangocairo-1.0-0.dll
6d700000 libpangoft2-1.0-0.dll
6b280000 libpangowin32-1.0-0.dll
43540000 comctl32.dll
43640000 comdlg32.dll
43740000 winspool.drv
43780000 iphlpapi.dll
437b0000 winmm.dll
43860000 msacm32.dll
43b40000 winemac.drv
452a0000 uxtheme.dll
62440000 roteros.dll
46370000 wininet.dll
467e0000 mpr.dll
65f80000 advtool.dll
6ac40000 dhcp.dll
67180000 ipv6.dll
69040000 mpls.dll
6e0c00
local msgs:
wnd=1101cc msg=203, wParam=1, lParam=4a003e
wnd=1101cc msg=20, wParam=1101cc, lParam=2010001
wnd=40206 msg=21, wParam=40206, lParam=2010001
wnd=201a2 msg=21, wParam=40206, lParam=2010001
wnd=1501ca msg=21, wParam=40206, lParam=2010001
wnd=1101cc msg=21, wParam=40206, lParam=2010001
wnd=40206 msg=210, wParam=201, lParam=de00cb
wnd=201a2 msg=210, wParam=201, lParam=c20043
wnd=1501ca msg=210, wParam=201, lParam=970043
wnd=1101cc msg=84, wParam=0, lParam=10b00cf
wnd=40206 msg=f, wParam=0, lParam=0
wnd=20166 msg=113, wParam=121, lParam=0
wnd=1101cc msg=215, wParam=0, lParam=0
wnd=1101cc msg=202, wParam=0, lParam=4a003e
wnd=24019a msg=d, wParam=10, lParam=ccb348
wnd=24019a msg=e, wParam=0, lParam=0
code:
8b 07 89 5c 24 04 89 14 24 ff 50 0c 50 50 8b 45
DjM
Re: v6.13 released!
Thu May 29, 2014 3:13 pm
ROS 6.13
Yes, it's confirmed bug - SSTP is broken in ROS 6.8 - 6.13 (including), if there is sstp-server interface binding used. Some details are in http://forum.mikrotik.com/viewtopic.php?f=2&t=82578
DjM
Re: v6.13 released!
Thu May 29, 2014 3:20 pm
K+1? :-)
For loading from Dude I'm not sure how is the winbox internally called from this inteface, but you can try :-) Another option can be to delete temporary files for winbox stored "Application Data" directory (try to find folder with name "Mikrotik" on system drive in Windows) and delete everything except winbox.cfg to do not lost configured hosts. Option "last session" is probably deleting data on ROS side, second described option on client's side. If anything of this will not help, then try to get in contact with MK support how to clean the session data on both sides.
TymeWyse
Re: v6.13 released!
Fri May 30, 2014 12:03 am
Yes, after updating (x86) to 6.13, simple queues disappear. Re-boot, they show up and slowley disappear again.
Jeff
TymeWyse Internet
P.O.Box 84 - 110 Ecklund St., Canyonville, OR 97417
tel: (541) 839-6027 - info@tymewyse.com
Chupaka
Re: v6.13 released!
Fri May 30, 2014 10:00 am
also known problem:
*) fixed - simple queues could sometimes crash router;
*) fixed - simple queue stats freeze (empty winbox queue window);
kapode
Re: v6.13 released!
Fri May 30, 2014 10:30 am
The same problem with queues on my CCR router.
They r invisible.
Vitokhv
Re: v6.13 released!
Fri May 30, 2014 4:09 pm
How to split speed client access to the global network and local resources provider:
http://asp24.com.ua/blog/mikrotik-queue ... lno-video/
http://asp24.com.ua/blog/kak-razdelit-s ... rovajdera/
It works on version 5 why does not work on version 6 :-x
I need to divide the network speed from 0 to 100 Mbps and a separate share of internet traffic from 0 to 5 Mbit
Internet to 5Mbit (0.0.0.0/0)
Local resources to 100Mbps (10.0.0.0/8; 172.0.0.0/21)
Mikrotik RB751U
gondim
Re: v6.13 released!
Fri May 30, 2014 4:29 pm
also known problem:
Can you send a link for download?
Thanks and best regards
normis
Re: v6.13 released!
Fri May 30, 2014 4:30 pm
this version only available to developer testing program members
Spirch
Re: v6.13 released!
Fri May 30, 2014 7:05 pm
is it possible to get current changelog of 6.14, all rc?
patrikg
Re: v6.13 released!
Fri May 30, 2014 7:12 pm
Spirch
Re: v6.13 released!
Fri May 30, 2014 8:29 pm
ndbjorne
Re: v6.13 released!
Fri May 30, 2014 11:02 pm
what about adding a
Known Issues:
section to the
What's new in x.yy (%Y-%b-%d %H:%M):
release log just to make not waste time to upgrade systems that would surely require an almost immediate downgrade?
And to avoid all the "still exists..." posts, too?
Regards
Andrea
Erastus
Re: v6.13 released!
Sat May 31, 2014 8:12 am
Had the same problem
Shiro
Re: v6.13 released!
Sat May 31, 2014 11:17 pm
Is it normal for PPP/L2TP/SSTP connection to drop and reconnect after adding a comment to the interface? can't remember seeing this behavior on older version of routeros.
rextended
Re: v6.13 released!
Sun Jun 01, 2014 12:50 am
STILL EXIST ON 6.13
Still no fixed on 6.14rc25
Chupaka
Re: v6.13 released!
Sun Jun 01, 2014 1:56 pm
'target' value is now mandatory, set it at least to your LAN interface, and then add 'Dst' with 10.0.0.0/8 and 172.0.0.0/21 values
theprism
Re: v6.13 released!
Sun Jun 01, 2014 8:19 pm
Format USB doesn't work in v6.13 through GUI. Through CLI is OK.
paoloaga
Re: v6.13 released!
Sun Jun 01, 2014 8:45 pm
Is it normal that users can connect with MPPE even if it's not enabled in the PPP profile?
> /ppp profile export
# jun/01/2014 19:42:38 by RouterOS 6.13
/ppp profile
add change-tcp-mss=yes dns-server=***.***.***.***,***.***.***.*** local-address=\
***.***.***.*** name=pppoe-data only-one=yes remote-address=intercom-data \
use-compression=no use-encryption=no use-ipv6=no use-mpls=no \
use-vj-compression=no
> /interface pppoe-server print detail where user="*******"
Flags: X - disabled, D - dynamic, R - running
21 DR name="<pppoe-********>" user="********" service="intercom-broadband" mtu=1492 mru=1500
remote-address="**:**:**:**:**:**" encoding="MPPE128 stateless/none" uptime=5m57s
It happens with v6.13, didn't try with earlier versions. If it is a bug, should I open a ticket or is this post enough?
Thanks.
yozz
Re: v6.13 released!
Sun Jun 01, 2014 10:20 pm
hello!
not working ROUTING-BGP-PEERS-TCP MD5 KEY
payday
Re: v6.13 released!
Mon Jun 02, 2014 8:03 pm
Unfortunately yes, it's normal. It happens also on other interfaces (i. e. wireless disconnects all clients when you change it's comment).
morf
Re: v6.13 released!
Mon Jun 02, 2014 9:12 pm
Hello! Have CCR 1036.
Unexpectedly lost all BGP settings.
Helped restart. Ticket # 2014060266000809
napismizpravu
Re: v6.14rc10 released!
Mon Jun 02, 2014 9:37 pm
Problém se zobrazením address listu ve WinBoxu při záznamu více jak 166 000 IP adres z několikadenního DDoS útoku, CPU 100%. Taky je problém s exportem toho seznamu na USB. (RB433UAH RouterOS 6.14rc10). Poslední funkční export a zobrazení byl při 144 000 záznamech. (czech).
WinBox problem with displaying big Address List 166 000 records - CPU 100%, export address list to USB CPU 100% (graf)
rextended
Re: v6.13 released!
Fri Jun 06, 2014 1:00 am
Tomorrow when 6.14 go out, i add again this on the new topic about 6.14:
STILL EXIST ON 6.14
I wait again the fix on 6.15... I'm waiting the fix from 6.10...
steen
Re: v6.13 released!
Fri Jun 06, 2014 8:46 am
Hello Folks!
We successfully updated whole wireless infrastructure today containing of RB411, RB600, SXT and SEXTANT.
No problems observed so far, also routing tags etc. is working.
Yet we have fully failed to upgrade our VPN routers and VPN infrastructure which is using L2TP, devices does not matter.
L2TP tunnels simply stop passing traffic after some few megabytes has passed through tunnels. It was working till RoS6.7 after that not working anymore. We have put supout files to MT, and got some advices doing more logging, yet no time to do that experiment due to the badwill it caused among customers last time.
CRS using vlans and trunks is now working to a satisfaction level, we have a minor notification that mt has fixed in some pre-release, autosupout file is generated when you reboot :-) so we will wait put them in production till the fix is official in nextcoming RoS version.
nicklowe
Re: v6.13 released!
Fri Jun 06, 2014 10:25 am
Please do not release 6.14 with SSTP still broken. 6.13 has terrible performance/throughput compared to 6.12 and this issue has persisted to the pre-releases of 6.14.
http://forum.mikrotik.com/viewtopic.php?f=1&t=85568
It would also make an abundance of sense to update OpenSSL to fix the recently disclosed vulnerabilities.
voxframe
Re: v6.13 released!
Fri Jun 06, 2014 4:01 pm
Agreed!
DO NOT RELEASE 6.14 UNTIL THE ISSUES IN THIS THREAD ARE FIXED!!!!!!
Take as much time as you need to test and sort these issues, do not make US the testers!
fernandolcx
Re: v6.13 released!
Fri Jun 06, 2014 5:28 pm
Found a problem with Proxy ARP.
RouterOS is delivering his own MAC Address to clients even when it does not know the route to the destination.
Issue described here: http://forum.mikrotik.com/viewtopic.php?f=13&t=85054
kobuki
Re: v6.13 released!
Fri Jun 06, 2014 10:30 pm
I've upgraded an RB2011L-IN to 6.13 a few days ago, and I' observing a strange CPU behaviour. The average CPU usage is higher by about 2-3% and there are randomly repeating very short 100% usage spikes, without any significant traffic or other measurable activity (in the middle of the night for example).
I'm not very concerned about the 2-3% additional average load, but the spikes are weird. Did anyone experience anything similar?
yozz
Re: v6.13 released!
Sat Jun 07, 2014 7:51 pm
yesterday when i came home, my ros was be destroyed!!! statisic on usb flash drive was removed from 1 yer!!!! and menu ppp was removed form winbox! when i do system restore from backup it was not worked. than i do system hardware reset - out reset button and power on. but also menu ppp not resored! fucK!
yozz
Sat Jun 07, 2014 11:49 pm
people its not DDOS maby on my royter in was DNS attack..and after then was crashed firmware and stat form 1 YEARS!!!! drop all tcp and udp traffik on inbound interface (from inet) on 53 port.!!!
yozz
Re: v6.13 released!
Sat Jun 07, 2014 11:54 pm
What is new at 6.13
What's new in 6.13 (2014-May-15 16:03):
*) console - comments are now accepted where new command can start, that is,
where '/' or ':' characters can be used to start new command, e.g.
/interface { # comment until the end of the line
print
*) backup - backups by default are encrypted now (with user password).
To use backup on older versions, you should disable encryption with dont-encrypt
flag when creating it;
*) files with '.sensitive.' in the filename require 'sensitive'
permission to manipulate;
*) lcd - reduce CPU usage when displaying static screens;
*) l2tp - fixed occasional server lockup;
*) pptp - fixed memory leak;
*) sstp - fixed crashes;
Simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu. If you run v5 or older, download the newest NPK package from our webpage, upload to your router, and reboot: http://www.mikrotik.com/download
NOTE:
We plan to have full release of CAPsMAN for general public in RouterOS v6.14!
Please, make all additional tests and report all persisting problems in wireless-fp package.
people why my message killed???? I WAS WROTE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! that TCP MD 5 KEYS in ROUTING -BGP NOT WORKING!!!!!!!!!!!!!!!!!!
rextended
Re: v6.13 released!
Sun Jun 08, 2014 1:17 am
hello!
I see the message, the post are not deleted.
Are you blind?
Stop writing on this hurting way.
I'm Italian, not English. Sorry for my imperfect grammar.
jishanali
Re: v6.13 released!
Mon Jun 09, 2014 2:18 pm
Best
Its very simple first download your ROS 6.13 from http://mikrotik.com/download whatever device u are using. then open your router using winbox>file. and just copy your download .npk file and paste in file tab.
How ever there are variuos ways to upgrade of ROS.
Hope it will help you.
IT Consultant
Telekraft Network
New Delhi
India
https://facebook.com/telekraftnetwork
rextended
Re: v6.13 released!
Mon Jun 09, 2014 4:03 pm
Best
You suggest wrong solution, and this user already have received one answer with correct procedure:
NOTE 2:
Users browsing this forum: Bing [Bot], fs0c13ty, Google Feedfetcher, neutronlaser, tdw and 58 guests
