frif
prerouting mangle and NAT fails with contains and layer 7
Tue May 20, 2014 12:23 pm
When marking packets in mangle at the prerouting chain the destination NAT filters fail to see the marks.
According to the documentation, in the prerouting chain the mangle happens before the destination NAT
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
And indeed, it works if I use different criteria (protocol, address, etc.) for marking the packets at the Mangle Prerouting filters, but it fails with either contains or layer 7 conditions.
The packets are properly marked, as the counter increases and can also be seen in other chains (for example, at input filters), but in the destination NAT zero packets get marked, even if I put the filter at the top of the list.
This is similar to this post http://forum.mikrotik.com/viewtopic.php?f=2&t=83129
Farhadgh
Re: prerouting mangle and NAT fails with contains and layer
Tue May 20, 2014 11:57 pm
Can you send your config?
Everyday, a better day!
Users browsing this forum: Cablenut9, Google [Bot] and 179 guests
