IPANetEngineer
Trainer
Trainer
CCR and Internet BGP - survey of user experiences
Tue May 20, 2014 9:33 pm
This question seems to come up a lot in the MikroTIk forums and I'm curious to see what different types of CCR BGP deployments are out there as well as the experience of the end user. Some users seem to have no issues with multiple public feeds and some aren't stable on only one feed.
So....
1) What kind CCR (s) are you using in your network
2) How many BGP feeds / Routes are you taking in
3) Are you stable or do you experience issues - if so, what kind
4) Software version used
We hear so many good/bad stories on CCR BGP, it might be helpful to have all the info in one thread.
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
wulfgard
Re: CCR and Internet BGP - survey of user experiences
Thu May 22, 2014 3:19 pm
Good afternoon
very strange request from you.
don't you have any CCR with BGP in production ?
aren't you "The Largest Carrier-Grade MikroTik Integrator in North America" ?
best regards
Thierry
System and Network Engineer
Mikrotik Trainer - MTCNA MTCRE
Official French Mikrotik Distributor
paulsa
Thu May 22, 2014 4:55 pm
So....
Great post.
We will be switching back from our cisco 7200 to the CCR on Sat morning for BGP.
1) CCR1036
2) 5 Feeds in total (local, international, peeing, a private peer, and Hurricane)
3) Was stable for 5 months on - then instability with random reboots (Tried a different CCR, new config, old config, ROS V6.10, Swapped SFP's, Ran BGP only on one interface)
4) V6.7 and V6.10
We are dedicating a CCR for ONLY BGP now on two SFP's with three vlans for int/local/peering. No queues, no advanced firewall handling etc and watchdog turned off as we suspect its a CPU issue and watchdog rebooting it. Another CCR will be used for the queues/firewall and IGP. We will try V6.13 on our BGP router
Will provide feedback on Monday if it is stable.
IPANetEngineer
Trainer
Trainer
Thu May 22, 2014 5:49 pm
Good afternoon
best regards
Thierry
:) Touche!...you are correct, we ARE the largest Carrier-Grade Integrator in North America and deploy BGP/MPLS solutions to many large wireline/wisp carriers. We work with a lot of CCRs in BGP peering and have seen various issues. We tend to limit full table peerings on CCRs to no more than 2 based on the limitation of a multi-threaded BGP process. Since we are an integrator, most of our customers use Cisco and Juniper still for public BGP peering and are reluctant to migrate. Large carriers don't like being beta testers in general - stability and conservative design is the name of the game.
The intent of the thread is to try and centralize information and experiences on peering with full global BGP tables on CCR and see if there are common issues across software versions and/or types of peering routers.
yogensha
Thu May 22, 2014 8:27 pm
CCR1036-12G-4S. Would really like to see a 12-port SFP version.
One transit provider on the CCR. Other transit providers are on other platforms, but the plan is to move to CCRs, one per provider. Taking full tables.
If things continue to go well, we'll also move edge aggregation to CCR. Core switching will be on other platforms.
Stable since deployment about 2 weeks ago. Most issues are just learning the platform, there are some oddities. Diagnostics are probably the biggest problem: 'show ip route' would be nice.
6.12
joegoldman
Fri May 23, 2014 9:55 am
There is the CCR1016-12S-1S+, only half the cores but unless you are doing lots of data it should still allow it.
Or there is a CCR1072-1G-8S+ on the horizon I believe (Q3 2014), which is 72 cores and 8 (or more) SFP+ ports
Why only 1 CCR per provider? (curious)
There is this, but large tables can take a bit to get the answer, and it will show ever matching route, not just the preferred/taken route:
ros code
[admin@core1.bne1] > /ip route print where 8.8.8.8 in dst-address
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          <hidden>               1
 1 ADb  8.8.8.0/24                         <hidden>            200
NetNotGross
Fri May 23, 2014 3:44 pm
We had problems around the point of 4 full feeds but I don't thing we ran the problem to ground. We were hitting various other CCR limitations at the time so it wasn't the most important item for resolution.
At this point I don't think it is possible to fully "integrate" Mikrotik equipment as part of a "carrier grade" solution. You can certainly interface Mikrotik equipment with carrier grade systems but I certainly would not describe any Mikrotik hardware as "carrier grade". That doesn't mean it isn't useful, good value or the appropriate answer for some applications.
yogensha
Fri May 23, 2014 4:57 pm
For some reason I thought that was all 10 gig. Thanks for the tip!
Redundancy. One failure takes out only one provider. Low cost makes this very practical.
ros code
I really like that it shows the less-specifics. It gives functionality similar to 'show ip [route|bgp] <address> longer-prefixes' in cisco-land. It takes a good 60-90 seconds to do the lookup on a router with a full table though, making troubleshooting time consuming, which is incredibly frustrating in an outage situation.
wulfgard
Sat May 24, 2014 1:34 am
Good afternoon
best regards
Thierry
So with your experience you may know that
1) bgp needs a lot of cpu
2) bgp needs some memory
3) V6.x is not multi thread for BGP
but to help you :)
CCR1036-4G can handle with no problem 2 full table IPV4 + IPV6
if you need a lot of peers use x86 until v7 and 72 tilera cores
for compatibility as you seem not to be able to do testings it works fine with cisco, juniper, quagga, bird, huawey
our network is spread over europe with 9 bgp routers ( x86 ) with about 500 bgp sessions including peering and upstreams
it takes about 1 minute to propagate a full IPV4 table over all the network
you will not be able to do this even with SUP720 3BXL or MX80 ( we have tested in real production )
for public peering if you are connected on a peering point like AMSIX, DECIX, TOPIX, LUCIX ... you will see a lot of Mikrotik routers just with "ip neighbour" but they are not speaking about it
our customers are using CCR for connecting their upstreams and they have no issue but the secret is also about setup :)
regards
Thierry
Luth
Sun May 25, 2014 11:06 am
1) We have 2 CCR1016-12G
2) We have BGP with 2 upstream with 2 session per upstream so, in total, 4 BGP session per router
3) We are stable, no issue at the moment with BGP
4) v6.12
TLCWEB Srl/Baleno Wireless the smaller WISP in south of Italy :-)
Luciano Talarico
TLCWEB Srl - Italy
Visit Mikrotik topics on our Linux by Myself website at linuxbms.com
paulsa
Mon May 26, 2014 3:33 pm
1) CCR1036
4) V6.7 and V6.10
So far, very stable now for 54 hours on V6.13
sguox
Trainer
Trainer
Thu May 29, 2014 6:53 am
we have been using 2x CCR1036-12G-4S since early 6.x without much issue. the catch, daily reboot on the router in off-peak hours.
first unit connected with 3 BGP sessions (2 full route, 1 local route ~80k), total throughput >300mbps
second unit, 2 BGP sessions (1 full route, 1 local route ~10k), total throughput >300mbps
so far so good
NodeMax
Thu May 29, 2014 6:26 pm
2 CCR both – CCR1036-12G-4S
2 feeds each with 2 sessions each feed, dualstack
1 carrier on fibre other on ethernet on each router
2 ipv4 on each with 244k routes and 488K the other
2 ipv6 on each with 15K and 12K on the other
software 6.12
No problems ... :D
joegoldman
Sun Jun 22, 2014 5:34 am
Coming in to say CCR1036-8G-2S+ has been in production for nearly a month. Only taking default route still, but has 30K~ in iBGP/OSPF/IX routes without problem. Probably only about 12k are active routes though (lots of double ups over the IX's)
Peaking at about 600mbit / 100kpps aggregate bandwidth through a 802.3ad LACP trunk.
Have some basic ICMP stuff in the forward/input chain
Have some basic blocking in the input chain for Telnet/SSH
Have about 10 simple queues, with 2 mangle rules per queue (to match input/output traffic) on a VLAN interface that does 100-140mbit traffic at any point.
Mostly, I barely see the CPU above 10% at peak, so very stable and happy with performance so far.
Running ROS6.13
Spinning 2nd one up this week for stateful balance and failover. Will also start receiving full table's from 2 providers soon.
selric
Sun Jul 20, 2014 10:17 pm
Ours have been running for 27 days with ROS 6.15 today and one full feed and a handfull of peers at an IX.
Works great so far!
paulsa
Tue Jul 22, 2014 7:18 pm
Since we split our routing, i.e ospf/firewall rules/queues etc on one router and BGP on another CCR it has been running great.
system resource print
uptime: 8w3d9h14m22s
version: 6.13
rcwmoab
Sun Jul 27, 2014 12:35 am
Been running our CCR1036-12g-4s since they were available as a preproduction product with full bgp coming from two upstream providers totaling 730k routes passing 400mbps of traffic with no problems what so ever. This router only runs BGP on it though, no ospf or anything else. Currently running v6.9
randvegeta
Mon Jul 28, 2014 10:15 am
How long ago was that?
Good to hear. May I ask if you have done any reboots? Or table rebuilds? Interested in knowing how long it took to build the routing table.
lz1dsb
Thu Aug 21, 2014 5:17 pm
two CCR-1036-12G
above 500k. One of the routers has 4 BGP peering sessions, the other has 5. At the moment we're peering with 2 ISPs, in the next month another two ISP peering sessions are planned.
twice, the issue was that all of the configured bridge interfaces were somehow wiped out from the running config. But I do not attribute this to BGP as it happen once long before BGP was deployed. In general - I haven't had any issues with it.
6.17
IPANetEngineer
Trainer
Trainer
Tue Aug 26, 2014 5:11 pm
Glad to see this thread has been useful...i've seen it linked in multiple other forum posts.
@Mikrotik - what is the status on balancing BGP across multiple cores?
lz1dsb
Tue Aug 26, 2014 5:26 pm
That's something I would like to see too! This is something that bothers me, because it turns out that as far as routing is concerned - there's such a waste in capacity! So many cores stay idle while one of them is utilized to its limits.
I think I read somewhere that core load balancing is planned for version 7.0 but I'm not sure...
joegoldman
Wed Aug 27, 2014 2:37 am
As above poster said, I think this is being held off for v7.
There is a thread on here somewhere in relation to v7 where normis says they're alpha test builds are loading 15 million routes in 15 minutes, a million routes a minute is pretty darn good. You'd have to imagine this efficiency is being achieved with multi-core.
Hopefully filtering/adding/removing routes from a big route-table will be vastly improved too. Still running 6.13 on my main BGP routers but hell they are slow to add routes and filter looking for things.
bigcw
Mon Sep 08, 2014 3:13 pm
My current setup:
3 x CCR1036-12G-4S running v6.18:
- London: 2 x full BGP transit, iBGP to Frankfurt, Madrid and London
- Frankfurt: 1x full BGP transit, iBGP to London
- Madrid: 1x full BGP transit, iBGP to London
1 x 1100AHx2 v5.26 (yes, it's old, but it's stable!):
- Dubin: Approx 20 peering sessions (INEX exchange), iBGP to London
The setup has been stable other than an issue where BGP 'disappears' in Frankfurt. At present I suspect a hardware issue - there is a thread about this issue that I have just written and is awaiting approval. (ETA: http://forum.mikrotik.com/viewtopic.php?f=14&t=88912)
My only criticism of BGP on RouterOS is the speed. It takes a good 5 minutes at present to do a ~500k route converge on a 1036. Fingers crossed that v7 will speed this up, then I will have no reason not to deploy more CCR's!
Chris
Ecom International Network - Operators of AS61337 with POPs in Europe and North America - www.ecomltd.co.uk
Colocker Data Centre - The data centre with a difference! - www.colocker.com
hashbang
Sat Sep 13, 2014 11:11 am
i found a minor bug in bgp filters. I dont know whether it was display or it was really the config. Router ccr 1036 8g version 6.15
BGP with 3 peers
2 peers to isp - isp1 and isp2
1 peer to client - c1
yesternight I added c1 to peers and added his subnet on filters accept. Strangely the IPs which were being advertised to isp1 and isp2 earlier, one of the subnet got the as path for c1. No as-path was altered in any of the filters. I removed the subnet of c1, the as path of that subnet got ok and other subnet got the as path. Then i disabled the advertising of that subnet and enable after few minutes the as path was empty now. If anyone wants the graphical representation I'll post it later on.
rootemin
Wed Feb 24, 2016 12:30 pm
Which are use stable RouterOS version with CCR1072 ?
Users browsing this forum: Google [Bot] and 6 guests
