cpodimas
RB751G-2HnD + WN722N(AR9271) doesn't work
Wed Jun 04, 2014 10:33 am
Hello.
I use RB751G-2HnD (6.13)
I plug USB WiFi WN722N(chipset AR9271)
Make restart.
It appears in reosurces->USB as 1:2 ATHEROS USB2.0 WLAN 12345 480Mbps.
But there is no interface in wlan interfaces (Just standart wlan0 for builtin wlan).
Please help me.
Thanks a lot!
Kreacher
Re: RB751G-2HnD + WN722N(AR9271) doesn't work
Wed Jun 04, 2014 10:58 am
Hello.
Make restart.
Please help me.
Thanks a lot!
as I am right informed is MikroTik not supporting USB WLAN oder WiFi devices!
It can be might changing but as I know it, they don´t do so.
Kindly regards
Kreacher ♬
Karma points must not be paid by you
mikrostart
Wed Jul 09, 2014 6:21 pm
Hello.
Make restart.
Please help me.
Thanks a lot!
Is there any news on that?!
Can MT support WN722N(chipset AR9271)?
Would be nice to use that thing, surely would reise the hype for USB enabled RBs.
Please, answer if this dream can come true. :)
Or not......
I,ve already ordered WN722N, if it is not going to be supported, I'll send it as a gift to MT's team :)
mikrostart
Thu Jul 10, 2014 3:13 pm
Anyone?
MT?
rextended
Thu Jul 10, 2014 3:24 pm
MikroTik not support WLAN over USB
I'm Italian, not English. Sorry for my imperfect grammar.
honzam
Thu Jul 10, 2014 4:34 pm
Seriously?
http://wiki.mikrotik.com/wiki/Supported ... less_cards
LAN, FTTx, Wireless. ISP operator
mikrostart
Thu Jul 10, 2014 6:47 pm
Seriously?
Exactly this is confusing me.
I've bought an adapter (WN722N), and despite the wiki says that it is supported, it is not working. The behaviour is the same as in the 1st post.
According internet resources, this chipset (AR9271) used to be working although on 54g mode in versions of ROS below 6.0.
Any newer version is not supporting this usb device anymore.
Why MT drop this devices, since thyey are cheap, and used to work in some manner?
which package contains the usb support drivers?
Is it possible to downgrade only that package?
That way I should be able to backport the usb support.
MT should take into consideration the fact that usb wifi dongles ususaly are much cheaper than the minipci, and could be more versatile (using on laptos, desktops if neccesarry).
Even being not so reliable, it is the users' choice to try it out. After all there're a lot minipci cards, that are as much problematic as this one-and-only usb chipset 9271.
Normunds,
say something for christ's sake!
wenasong
Thu Jul 10, 2014 6:56 pm
Seriously?
Normunds,
To let you know, the last supported ROS version for the USB-Wifi is 5.17
rextended
Thu Jul 10, 2014 7:53 pm
Seriously?
Yes, sorry, I omit to not x86 systems.
WN722N are not listed and on 6.x version some drivers are removed... (check forum posts about this...)
honzam
Thu Jul 10, 2014 9:00 pm
Or not......
What routerboard do you use? rb751G-2HnD?
What ROS do you use? Latest 6.15 with latest routerboot? If not, upgrade!
See tplink usb-wifi wn722N work in routerboard with ROS
mikrostart
Thu Jul 10, 2014 11:02 pm
Seriously?
Isn't taht an error in the MT's product phylosophy? Why removing this since the forums are alive about it?
Or not......
I use rb751U-2HnD. ROS 6.15 wih latest firmware for that board: ar7240_3.13.fwf (see attachement)
Where can I see that tplink usb-wifi wn722N work in routerboard with ROS?
It's strange that the system detects the usb device, but can not use it as an interface!
Kreacher
Thu Jul 10, 2014 11:44 pm
This can rally be, because MikroTik is only supporting the entire "Atheros chip set"
and not the whole device! And in normal as I am right informed, only x_86 devices
sorted with RouterOS are able to run them (USB WLAN apadters) if @honzam get it
working on a RouterBoard this might be not a guaranty for your self that it must be
running also at your RouterBoard!
P.S.
Mark thuis thread as a support call and then we will see what MikroTik staff is saying about this
situation!
Kindly regards
Kreacher ♬
mikrostart
Fri Jul 11, 2014 7:51 am
You should be just right, but there are a lot of obvious records in the Web that wn722n used to work on RB like mine.
How to mark it as a support call?
Kreacher
Fri Jul 11, 2014 12:16 pm
Edit the first post in this thread and then click the angle under the subject and safe this again.
Submit this post as a bug report to MikroTik Technical Support:
Kindly regards
Kreacher ♬
kristaps
Fri Jul 11, 2014 4:34 pm
Sorry after RouterOS 5.26 don't support USB wlan because it caused system instability in RouterOS v6
mikrostart
Fri Jul 11, 2014 6:29 pm
done
I believe you, but can you plaese be so kind to provide the source of your information.
Does that mean there will be no support ever for the usb wlan?
mikrostart
Sat Jul 12, 2014 12:26 pm
Up & down. ...
Does somebody knows if the USB wlan devices are working correctly on open wrt?
Kickoleg
Sat Jul 12, 2014 1:30 pm
honzam - I'm very impressed ! Good job ! I will try ...
MTCNA, MTCUME, MTCRE, MTCWE, MTCTCE certified
honzam
Sat Jul 12, 2014 2:06 pm
mikrostart:
Can you try ROS 5.24 or older?
http://download2.mikrotik.com/routeros/ ... e-5.24.npk
jnygard
Sat Jul 12, 2014 2:32 pm
I have a RB951G-2HnD on ROS 5.26 and it works with the WN772N. 6.XX branch drops the functionality...
mikrostart
Sat Jul 12, 2014 2:44 pm
mikrostart:
I can try to downgrade but will this destroy my license in any manner?
I can try with 5.26.
honzam
Sat Jul 12, 2014 3:36 pm
mikrostart:
license will remain
mikrostart
Sat Jul 12, 2014 7:49 pm
I've just installed ROS 5.26. So far so good-it works. I'm having some dificulties with the configuration, wchich are not problematic because of the usb adapter.
The thing I noticed is the usb adapter is getting too hot, while using it. I tried to decrease the txpower, but I'm about to evaluate that.
UPDATE 20.7.2014:
Ok it's working! I had to simplify the settings and not to toush the sensitive ones.
It can't reach some dramaticly high speeds but for me is more than welcome (6$ USB device instead 60$ for a minipci)!
I'll keep testing.....
mikrostart
Wed Jul 23, 2014 10:23 pm
does the USB power reset imitates ejecting and pluging in the usb device?
Is it possible to make a script which to reset the USB power in case of ping loss?
So far I can not see any problems with WN722N, but I'm asking in case of a reset precausions :)
mikrostart
Sat Aug 02, 2014 11:23 pm
Another problem occured:
whatever settings I do the speed can't get higher than 1 megabit/s :(
Any ideas?
mikrostart
Sat Aug 16, 2014 7:09 pm
Why actually MT decided to develop USB drivers only for the AR9271
rextended
Sat Aug 16, 2014 8:26 pm
Do not develop any USB driver, simply AR9271 is already one driver supported...
mikrostart
Sat Aug 16, 2014 8:34 pm
ok, so why no more drivers are supported?
Other chipsets, like Ralink, or other atheros...
rextended
Sat Aug 16, 2014 8:59 pm
Because MikroTik develop his driver only for some atheros chipsets.
The same chipset presents on R52, R52n, R52Hn R53n-M, etc. etc. etc.
Other reqirement are: the USB hardware must "expose" directly the Atheros chipset, no one "softwlan" is working on this way...
mikrostart
Sat Aug 16, 2014 9:12 pm
Does that mean that the ar9271 is not "exposed"?
rextended
Sun Aug 17, 2014 12:51 am
Not knowing how is made that device, I do not know.
mikrostart
Wed Sep 03, 2014 3:51 pm
ok, I just want to upgrade that part of MT OS, which will not mess up my wireless (and keeping the usb wifi working).
Is it possible to do this by iploading all new packages in "files", except the wireless.ipk and rebooting?
Now I'm with 5.26, but need some of the functionality of 6.19, so is it possible to leave wireless.ipk with 5,26, and upgrade anything else with 6,19?
And will it work?
honzam
Wed Sep 03, 2014 11:09 pm
And will it work?
No
mikrostart
Thu Sep 04, 2014 12:29 am
Have you tried this?
ekoslav
Fri Oct 10, 2014 1:47 am
Hi, I have similar problem with Alpha AWUS036NHA USB card (on the HCL):
I works out of the box on my RB2011UAS-2HnD running 6.16, but on the RB751U-2HnD does not show up.
751 was originally running 6.13, so I've upgraded it to 6.20 but the card did not showed up.
Since both routers are running the same software ( both are mipsbe) my guess is maybe there is difference between power on the USB port ?
ekoslav
Sat Oct 11, 2014 5:08 am
Update:
I've upgraded the firmware from 2.7x (original) to 3.17, and now the card is recognized in the list of USB devices.
It even occasionally shows up in the list of interfaces, but when I scan for wlans, it does not finds anything.
Same card works without a glitch on the 2011 router.
I'll try to find an powered USB hub to see if that will help, since adding better power (19V 3.42 A) to RB751 did not helped.
Occasionally when USB card is plugged in it knocks out integrated wifi, or reboots the router - I'm guessing that the internal 5v line is overloaded.
ekoslav
Sun Oct 26, 2014 3:52 am
Update 2:
Powered USB hub did not quite worked: MT did not reboot, but the card did not showed up in the devices, while it was listed under USB devices ...
mikrostart
Sun Nov 02, 2014 1:20 am
Just downgrade the MT OS to 5.26 and you well be able to start the Alfa. I used tplink 722n and it is working but can not get more than 1mbs. Also the link is working only when no encryption is enabled. Read the whole topic.
ekoslav
Sun Nov 02, 2014 4:43 pm
Just downgraded, and it worked like a charm!
Now I can use it for wireless vacation hub :)
Thanks!
P.S.: On the first try I got connected @ 11Mbps ...
mikrostart
Sun Nov 02, 2014 6:51 pm
Congrats!
Obviously with the Alfa the things looks better.
From where did you bought it?
I may try to change my tplink :)
mikrostart
Sun Nov 09, 2014 1:36 pm
Thanks!
Can you share the settings in MT?
Only for the AR9271 adapter.
BR
Users browsing this forum: No registered users and 32 guests
