Abdock
TE Tunnels
Wed Jun 04, 2014 8:50 pm
Hello Experts,
I am trying to create some TE tunnels for traffic management, to be able to use all our backup links, I configured a manual path and it showed running, when i assigned dynamic as to the secondary path, it could not run. Then i tried various other route, and some showed running and some did not show. No matter what i do.
Has anybody any experience, using 6.13 OS.
Many thanks.
wulfgard
Re: TE Tunnels
Thu Jun 05, 2014 1:52 pm
Hello
1) check that ospf mpls feature is enabled on all routers participating to mpls
2) ensure all ospf routers have a loopback with a /32 ip address advertised in the network
3) check that all interface ( not loopback ) have rsvp bandwidth configure
4) all ospf network must be in same ospf area
5) confiure TE path as cspf
6) configure all tunnels with a path between loopback address ( use 0 for bandwidth to avoid bandwidth constrain )
this is it
PS : there is no need of LDP is you are using TE Tunnels
a+
Thierry
System and Network Engineer
Mikrotik Trainer - MTCNA MTCRE
Official French Mikrotik Distributor
Abdock
Re: TE Tunnels
Thu Jun 05, 2014 8:05 pm
Thanks Wulfgard.
I have ospf, and mpls running, which will need LDP, TE tunnels for traffic direction.
Following this wiki, http://wiki.mikrotik.com/wiki/Manual:Simple_TE I have setup loopback /32 and configured rsvp bandwidth on all interfaces participating on TE route.
But I cant get the tunnel running if i choose, cspf, unless i specify path on some areas and some areas it would not just come up no matter what i try.
This one i did not understand, configure all tunnels with a path between loopback address ( use 0 for bandwidth to avoid bandwidth constrain )
Would there be a bug on 6.13 ?
Thanks,
wulfgard
Re: TE Tunnels
Tue Jun 10, 2014 12:02 am
Hi
seem you forget to activate mpls support on all ospf instance
a+
thierry
Abdock
Re: TE Tunnels
Tue Jun 10, 2014 6:22 pm
MPLS is working, but the TE does not seem to work as expected.
wulfgard
Re: TE Tunnels
Tue Jun 10, 2014 6:27 pm
hello
can you give more details of the issue and may be configuration examples
a+
Thierry
Abdock
Re: TE Tunnels
Tue Jun 10, 2014 7:33 pm
I have a routed network, which connects us to our ISP, having main link and backup links.
=====R1--------- R2-----------R3 --------- HQ
R4----------R5---------- R6------------
OSPF and MPLS are working on this one, my main link is R1, R2, R3 to HQ
I want to route traffic to R1,R2,R5,R6, R3 to HQ using TE.
I have set, Loopback addresses on all Routers, and tried to create a path for TE, so the alternate route is taken, but does not work. I cannot ping the TE interfaces on each side, R1 and HQ. As they dont show running. Any idea on what could be issue here ?
Am i missing anything in understanding the TE.
Users browsing this forum: No registered users and 7 guests
