normis
v6.14 released
Mon Jun 09, 2014 3:22 pm
Some good changes here, including the new "ip cloud" menu, and general release of CAPsMAN:
What's new in 6.14 (2014-Jun-06 15:34):
*) sntp - 'mode' now is a read-only property, it is set to broadcast if no
server ip address is specified;
*) smb - fixed some SMB1 errors;
*) wireless-fp package is now included in routeros one (disabled by default);
*) webfig - fixed quickset, it didn't work with disabled wireless pacakge;
*) sstp - fixed problem where session was closed every 2min;
*) pptp,l2tp,pppoe - fixed problem where some of the static bindings
become dynamic interfaces;
*) eoip - lowered default MTU to avoid IP packet fragmentation;
*) eoip - added clamp-tcp-mss setting with default=yes for new tunnels to avoid
*) fixed - bridge could sometimes get added without ~running~ flag;
*) fixed - simple queues could sometimes crash router;
*) fixed - simple queue stats freeze (empty winbox queue window);
*) ssh server - allow none cipher;
*) proxy - added 'anonymous' option which will skip adding X-* and Via headers;
*) dhcp server - added option use-framed-as-classless and
added support for DHCP-Classless-Static-Route RADIUS attribute;
*) quickset - fixed problem where address mode selection did not work in
bridge mode;
*) ipv6 address - fixed problem where changing advertise lost ipv6 connected route;
If you already run some RouterOS v6.x version, simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
Others: http://www.mikrotik.com/download
ncd
Re: v6.14 released
Mon Jun 09, 2014 3:46 pm
Does this resolve all the bugs reported with CRS and 6.13?
alfedo
Re: v6.14 released
Mon Jun 09, 2014 3:56 pm
Missed in WEB config.
normis
Re: v6.14 released
Mon Jun 09, 2014 3:57 pm
no, but you might need to clear browser cache, and then hit refresh
rextended
Re: v6.14 released
Mon Jun 09, 2014 4:14 pm
STILL EXIST ON 6.14
http://forum.mikrotik.com/viewtopic.php ... 88#p416454
BUG SIGNALED FROM 6.10 AND STILL NOT FIXED???
Opened another ticket for that: [Ticket#2014041566000226] 6.12 UNFIXED BUG: user-manager profile limitation
I wait again the fix on 6.15... I'm waiting the fix from 6.10...
I'm Italian, not English. Sorry for my imperfect grammar.
WirelessRudy
Re: v6.14 released
Well, nice. But I'd rather wait a bit longer with updating my network to 6.14...
I was just in the process of updating my network to 6.13, that seems to be pretty stable. I have some 85% done.
But now with the new 6.14 I can't use the winbox
/sys
packages
'check For Updates'
Download & Upgrade
sequence any more because it would now download 6.14. which I don't want ... yet.
Can there not an option build in winbox so I can actually pick the version from the server to download & upgrade? So I can use the same procedure but than in the last phase select a previous version to download and install? They are all still on MT's servers I presume. Shouldn't be hard to do?
For the rest of the network not updated to 6.13 yet I now have to fall back on the manual ftp transfer of upgrade packages, which in my experience takes more time but is also a bit more prone to failures.....
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
rextended
Re: v6.14 released
Mon Jun 09, 2014 4:15 pm
rextended, I will check for the issue, and try to find out why it is not fixed yet.
And we will try to fix it at 6.14 version.
http://forum.mikrotik.com/viewtopic.php ... 85#p426403
vovannovig
Re: v6.14 released
Mon Jun 09, 2014 4:54 pm
Как именно включается данная функция?в WinBOX без изменений в разделе Web-Proxy
As it turns this function? WinBOX in no change in the section Web-Proxy
normis
Re: v6.14 released
Mon Jun 09, 2014 4:57 pm
I do see the changes:
ros code
[admin@test] /ip proxy> print
                 enabled: no
             src-address: ::
                    port: 8080
               anonymous: no
            parent-proxy: ::
       parent-proxy-port: 0
     cache-administrator: webmaster
          max-cache-size: unlimited
   max-cache-object-size: 2048KiB
           cache-on-disk: no
  max-client-connections: 600
  max-server-connections: 600
          max-fresh-time: 3d
   serialize-connections: no
       always-from-cache: no
          cache-hit-dscp: 4
vovannovig
Re: v6.14 released
Mon Jun 09, 2014 5:02 pm
[admin@Core] /ip proxy>
.. -- go up to ip
access --
cache --
cache-contents --
clear-cache --
connections -- list all connections
direct --
edit --
export -- Print or save an export script that can be used to restore configuration
get -- Gets value of item's property
inserts --
lookups --
monitor --
print -- Print values of item properties
refreshes --
reset-html --
set -- Change item properties
how to turn on?
Chupaka
Re: v6.14 released
Mon Jun 09, 2014 5:12 pm
/ip proxy set anonymous=yes
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
vovannovig
Re: v6.14 released
Mon Jun 09, 2014 5:15 pm
[admin@Core] > /ip proxy print
                 enabled: yes
             src-address: ::
                    port: 8080
               anonymous: yes
            parent-proxy: 0.0.0.0
          max-cache-size: 256000KiB
   max-cache-object-size: 256KiB
           cache-on-disk: no
  max-server-connections: 800
          max-fresh-time: 3d
   serialize-connections: yes
          cache-hit-dscp: 4
             cache-drive: system
http://2ip.ru
Прокси: Используется
Ваш IP адрес за прокси-сервером: 192.168.100.10
Proxy: Used
Your IP address behind a proxy server: 192.168.100.10
Chupaka
Re: v6.14 released
Mon Jun 09, 2014 5:18 pm
Normis, any chance to have IP Cloud for x86?
jmallari76
Re: v6.14 released
Mon Jun 09, 2014 5:29 pm
Hi
can anyone help om the session time left if this already been fix with this new version ?
JoJo
honzam
Re: v6.14 released
Mon Jun 09, 2014 5:48 pm
Why no line in changelog about OpenSSL bugs?
http://forum.mikrotik.com/viewtopic.php ... 65#p430205
LAN, FTTx, Wireless. ISP operator
Chupaka
Re: v6.14 released
Mon Jun 09, 2014 6:20 pm
because it's OpenSSL bugs, not RouterOS? :)
onnoossendrijver
Re: v6.14 released
Mon Jun 09, 2014 6:34 pm
I really like the wireless-fp package. I had one device that would not even see my AP. Now works fine.
Speeds are much better too.
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
vovannovig
Re: v6.14 released
Mon Jun 09, 2014 6:36 pm
Anonymous proxy does not work?
Or something I have not tested it properly?
planetcaravan
Re: v6.14 released
Mon Jun 09, 2014 6:54 pm
I've upgraded two brand new SXT Lite 5 from 5.26 to 6.14. As I reboot the the device, wireless menu item does not appears on menu.
The package is enabled
As I reboot the device, the menu item show up.
SaLMoN
Re: v6.14 released
Mon Jun 09, 2014 7:04 pm
Here's how my USB 3G dongle (Huawei E169) is identified, but it seems to me that it works properly (my backup link does not exceed 512Kbps) - on RB751U-2HnD.
Test471
Re: v6.14 released
Mon Jun 09, 2014 7:17 pm
What exactly is the point of "ip cloud" when you cannot remember your dns name?
dohmniq
Re: v6.14 released
Mon Jun 09, 2014 7:43 pm
I can't seem to find the "wireless-fp" package - am I missing something here?
  • downloaded all_packages-mipsbe-6.14.zip
  • used FTP to upload all .npk files to SXT G-5HPnD-SA r2
  • reboot to install packages with /sys reboot
  • updated bootloader with /sys routerboard upgrade
  • rebooted again with /sys reset-config skip-backup=yes
/sys package pr produces this:
[admin@MikroTik] > /sys package pr
Flags: X - disabled
 #   NAME                                           VERSION                                           SCHEDULED
 0   system                                         6.14
 1   advanced-tools                                 6.14
 2   calea                                          6.14
 3   dhcp                                           6.14
 4   gps                                            6.14
 5   hotspot                                        6.14
 6   ipv6                                           6.14
 7   lcd                                            6.14
 8   mpls                                           6.14
 9   multicast                                      6.14
10   ntp                                            6.14
11   openflow                                       6.14
12   ppp                                            6.14
13   routing                                        6.14
14   security                                       6.14
15   ups                                            6.14
16   user-manager                                   6.14
17   wireless                                       6.14
[admin@MikroTik] >
Connection to 192.168.88.1 closed.
...also is it me or when I use netinstall to reflash a unit there's an extra package called "routeros"??
npero
Re: v6.14 released
Mon Jun 09, 2014 7:48 pm
Why upgrading device with all package just use upgrade package http://download2.mikrotik.com/routeros/ ... e-6.14.npk download upgrade and you can find regular end fp wireless package.
Flags: X - disabled
 0   system                                         6.14
 2   calea                                          6.14
 3   dhcp                                           6.14
 4   gps                                            6.14
 5   hotspot                                        6.14
 6   ipv6                                           6.14
 7   lcd                                            6.14
 8   mpls                                           6.14
 9   multicast                                      6.14
10   ntp                                            6.14
11   openflow                                       6.14
12   ppp                                            6.14
13   routing                                        6.14
14   security                                       6.14
15   ups                                            6.14
17   wireless                                       6.14
[admin@MikroTik] >
Leto
Re: v6.14 released
Mon Jun 09, 2014 8:06 pm
http://forum.mikrotik.com/viewtopic.php ... 50#p411604
http://forum.mikrotik.com/viewtopic.php?f=14&t=79519
After testing, this bug seems to have been fixed. Awesome!
payday
Re: v6.14 released
Mon Jun 09, 2014 8:08 pm
Read changelog:
kapode
Re: v6.14 released
Mon Jun 09, 2014 8:43 pm
I have strange problem since 6.9 (also in 6.13, 6.14)
If more than 3000 simple queues on CCR1016 - www graphing does not work.
If I delete some queues... for example there will be 2990 - www graphing is working.
Could you fix that?
I`ve check this on other CCR - 1036, the same problem. Obviously software problem.
dohmniq
Re: v6.14 released
Mon Jun 09, 2014 8:53 pm
I use the "all packages" file because as it comes with "all features including less used ones" - in my case this is the NTP server feature. I upload them all the RouterBOARD and then uninstall packages I don't need.
Read changelog:
I guess I don't really understand what this actually means. So there's some extra "routeros" package that's not in "all packages" (despite the name)?
So I uploaded the "upgrade" package but now the list looks like this:
[admin@MikroTik] /system package> pr
Flags: X - disabled
 0   calea                                          6.14
 1   lcd                                            6.14
 2   routeros-mipsbe                                6.14
 3   system                                         6.14
 4 X wireless-fp                                    6.14
 5   ipv6                                           6.14
 6   wireless                                       6.14
 7   hotspot                                        6.14
 8   dhcp                                           6.14
 9   mpls                                           6.14
10   routing                                        6.14
11   ppp                                            6.14
12   security                                       6.14
13   advanced-tools                                 6.14
14   user-manager                                   6.14
15   advanced-tools                                 6.14
16   openflow                                       6.14
17   ipv6                                           6.14
18   ups                                            6.14
19   ntp                                            6.14
20   hotspot                                        6.14
21   security                                       6.14
22   multicast                                      6.14
23   system                                         6.14
24   gps                                            6.14
25   routing                                        6.14
26   dhcp                                           6.14
27   mpls                                           6.14
28   wireless                                       6.14
29   ppp                                            6.14
I can see "wireless-fp" now but I have duplicate packages of "ppp", "dhcp", etc... :?:
Also I see the "routeros-mipsbe" package has appeared - what does it even do?
I'm just so confused...
biomesh
Re: v6.14 released
Mon Jun 09, 2014 9:17 pm
If you have your own domain, just create cname records that point to your serial number dynamic dns records hosted by mikrotik.
Trema
Re: v6.14 released
Mon Jun 09, 2014 10:50 pm
DHCPv6 client still doesn't update DNS servers correctly, when lease is renewed:
payday
Re: v6.14 released
This is how it looks on my RB2011 after upgrade:
[admin@test] /system package> print
Flags: X - disabled
 0   routeros-mipsbe         6.14
 1   system                  6.14
 2   wireless-fp             6.14
 3 X ipv6                    6.14
 4 X wireless                6.14
 5   hotspot                 6.14
 6   dhcp                    6.14
 7   mpls                    6.14
 8   routing                 6.14
 9   ppp                     6.14
10   security                6.14
11   advanced-tools          6.14
Definitely, something is wrong with your packages. Try to downgrade, upgrade, uninstall packages, NetInstall...
honzam
Re: v6.14 released
Mon Jun 09, 2014 11:20 pm
You can download it separately http://download2.mikrotik.com/routeros/ ... mipsbe.npk
rextended
Re: v6.14 released
Tue Jun 10, 2014 5:09 am
Please add on winbox (and webfig?) missing functionalities like:
clamp-tcp-mss
web-proxy anonymous
disable-runnin-check
cable-test
reset-mac-address
and all the other options/functions presents on CLI and not on winbox or webfig.
Also add the possibility on CLI to save always the output of a command to a file, like "ping" or better add the "do={}" like flood ping
0ldman
Re: v6.14 released
Tue Jun 10, 2014 7:46 am
/sys
packages
'check For Updates'
Download & Upgrade
I've got a web server set up with various tools for my customers and myself. I keep a manual mirror of most ROS versions since 3.24 or so. I have a txt file with a quick copy and paste command line that I can put into terminal/telnet/ssh and it will download, then just tell it to reboot. I have a much higher success rate than over FTP or through Winbox itself.
/tool fetch address=www.yourwebsite.net src-path=/MT/6.13/routeros-mipsbe-6.13.npk mode=http
janisk
Re: v6.14 released
Tue Jun 10, 2014 8:43 am
Just bookmark it.
rextended cable-test is here - open ethernet interface details on device that supports that. There on the right side (with extra buttons) is cable test button.
npero
Re: v6.14 released
Tue Jun 10, 2014 9:02 am
x86 UPS package not working, also try to uninstall UPS package and install again now log say package exist but I not see in package list, and in 6.14 on x86 don't have monitoring UPS now on 750UP is working.
Also OpenVPN bridge bug not resolved.
EDIT: Install fresh from CD image in Virtual Machine UPS package working, downgrading real machine to 6.13 UPS package is back in menu of course old behavior using usb to serial convertor on ups lost all setting on reset old bug with usb to serial, back to 6.14 some thing no UPS in winbox or console UPS package is installed.
normis
Re: v6.14 released
Tue Jun 10, 2014 9:21 am
The point of the cloud DNS name is not to remember it, but to solve a changing IP address problem. You can just bookmark this DNS name that you received.
The DNS is assigned to valid serial numbers, for X86, we have no way of reliably identify the hardware.
bepix83
Re: v6.14 released
Tue Jun 10, 2014 9:37 am
Hi, I've just upgrade routerOS to version 6.14 and after that I can't see Hotspot menu'.
The package "Hotspot" is still inside and upgraded.
Is that menu move or is there some problem?
Thanks for any helps
Bye
Beppe
normis
Re: v6.14 released
Tue Jun 10, 2014 9:38 am
Could you fix that?
for 3000 queues, I suggest using the SNMP for graphs.
p1p1p1
Re: v6.14 released
Tue Jun 10, 2014 9:55 am
winbox: SNTP client -> unicast :) not working ... ?!?
bepix83
Re: v6.14 released
Tue Jun 10, 2014 9:58 am
Bye
Beppe
I solved the problem,
I had to reboot few time my x86 and all menù are back.
Thank anyway
Bye
Beppe
normis
Re: v6.14 released
Tue Jun 10, 2014 10:17 am
Flags: X - disabled
 1   system                  6.14
 2   wireless-fp             6.14
 3 X ipv6                    6.14
 4 X wireless                6.14
 5   hotspot                 6.14
 6   dhcp                    6.14
 7   mpls                    6.14
 8   routing                 6.14
 9   ppp                     6.14
10   security                6.14
What's exactly wrong here? The big routeros package is normal.
janisk
Re: v6.14 released
Tue Jun 10, 2014 10:39 am
For SNTP you only have to set up an NTP server address​and it will switch to unicast mode for you. If no addresses are set SNTP will use broadcast mode, that does not require any configuration adjustments other than to enable it.
also from changelog:
tomaskir
Trainer
Trainer
Re: v6.14 released
Tue Jun 10, 2014 10:45 am
Except when you receive a dynamic NTP server from DHCP, it will NOT switch to unicast mode, and it just doesnt work - Ticket#2014060966000636
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
vadimbn
Re: v6.14 released
Tue Jun 10, 2014 11:16 am
Normis, please, pay attention to this bug. Also i created Ticket#2014061066000277 for this... Please, fix this issue, it very strange that the bug was not fixed since version 6.8 was released...
Veni. Vidi. Feci.
RBSXTLTE3-7, CRS326-24G-2S+RM, RB850Gx2, RBMRTG, RB1100AHx4, RB750Gr3, RBD52G-5HacD2HnD-TC, Woobm-USB
MAYAKNET
Re: v6.14 released
Tue Jun 10, 2014 2:04 pm
Доброго дня!
Хотел сказать что в Mikrotik Routerboard 750GL с прошивкой 6.14 возникла такая проблема: Я не могу найти такое
IP - DHCP-client ?????????
Где оно? Это какой то баг? Или Вы в нём куда то спрятали его???
payday
Re: v6.14 released
Tue Jun 10, 2014 2:15 pm
Flags: X - disabled
 1   system                  6.14
 2   wireless-fp             6.14
 3 X ipv6                    6.14
 4 X wireless                6.14
 5   hotspot                 6.14
 6   dhcp                    6.14
 7   mpls                    6.14
 8   routing                 6.14
 9   ppp                     6.14
10   security                6.14
This is my list of packages that is fine - I pasted it for comparison only. I say that something is wrong with his packages (dohmniq) from this post: http://forum.mikrotik.com/viewtopic.php ... 09#p430700 - he has double packages.
Chupaka
Re: v6.14 released
Tue Jun 10, 2014 2:43 pm
Доброго дня!
проверяйте System -> Packages, есть ли там пакет dhcp и активен ли он
MAYAKNET
Re: v6.14 released
Tue Jun 10, 2014 2:57 pm
Доброго дня!
Заметил такое... Я перепрошивал 2 Routerboard 750GL - и в обоих случаях такое встретилось... Но вот какой интересный момент: Я вернулся к старой (6.13) прошивке... и не знаю что меня потянуло опять залить прошивку 6.14, но уже на 3-ем Routerboard 750GL..... И эти пункты появились. Кстати - не было так же и DHCP-server и DHCP-relay.
И то что Вы посоветовали я тоже проверил, ещё до написания письма - System -> Packages, оно БЫЛО АКТИВНО!
Здесь явно что то не так.... Если Вы конечно не верите в ВОЛШЕБСТВА, и у меня 2-жды глаза закрылись волшебной пеленой )))
Спасибо!
rextended
Re: v6.14 released
Tue Jun 10, 2014 3:35 pm
STILL EXIST ON 6.14
Any mikrotik staff reply about this?
rextended
Re: v6.14 released
Just bookmark it.
Nice, thanks ;)
banneduser
Re: v6.14 released
Tue Jun 10, 2014 4:34 pm
STILL EXIST ON 6.14
Just chill already please.
wildbill442
Re: v6.14 released
Tue Jun 10, 2014 7:24 pm
Had an issue with 3 of the 4 devices I upgraded to 6.14 from 5.26.
All of them were mipsbe devices, and after upgrading they did not reconnect. Connecting locally to the ethernet interface showed no wireless interfaces listed. A firmware upgrade had to be completed prior to the wireless interfaces being displayed.
I would advise against an over the air upgrade, this seems to have effected only devices upgrading from 5.x, I'll test further to confirm.
The reason I suspect 5.x is the 4th device I upgraded was MIPSBE and running 6.12. It came back online fine after the upgrade with all interfaces.
William Burnett
Network Engineer
rpingar
Long time Member
Long time Member
Re: v6.14 released
Tue Jun 10, 2014 8:17 pm
still getting tx drops on VLAN where we run ospf+mpls
The only way to cure it is to change the queue to ethernet default.
When will it work in regular way using the default queue?????
Regards
Ros
Nemoo
Re: v6.14 released
Tue Jun 10, 2014 8:19 pm
Could you fix that?
I think come back old bug with queues. I don't remember with version this problem was (5.X or 4.X).
I write how retest this problem:
1. Mangle packets in firewall.
2. Create example simple queues
                               |-serviceA1
                               |-serviceA2
         |-----group1-service--|-serviceA3
main-----|
         |-----group2-service--|-serviceB1
                               |-serviceB2
                               |-serviceB3
3. In winbox check simple queues.
3.1. Works queues for serviceAX from group1-service.
3.2 Don't works queues for serviceBX from group2-service.
4. In winbox move group2-service above group1-service.
4.1. Starting works queues for serviceBX from group2-service.
4.2. Stopping works queues for serviceAX from group1-service.
Of course in points 3.2 , 4.2 don't work graphs.
Please check it.
jfrater
Re: v6.14 released
Tue Jun 10, 2014 8:41 pm
Upgrading from 5.x to 6.14 will remove wireless config so DON'T! :shock:
If you want you can upgrade to 6.13 AND THEN to 6.14, that works fine. 8)
Prodigy
Re: v6.14 released
Tue Jun 10, 2014 8:51 pm
Зачем???
For what???
wildbill442
Re: v6.14 released
Tue Jun 10, 2014 9:09 pm
Yes found that out the hard way! Mikrotik may want to put a warning on the download page.
William Burnett
Network Engineer
rextended
Re: v6.14 released
Tue Jun 10, 2014 9:24 pm
soulflyhigh
Re: v6.14 released
Tue Jun 10, 2014 9:34 pm
Tried upgrade from 5.11 to 6.14 on RB411AH as a test for this bug.
After first reboot there were no wireless interfaces at all (probably missing wireless package,
I didn't look in system packages at the time) and after second reboot (without firmware upgrade, just reboot)
wireless interface was there again but it had been reseted to defaults and disabled.
This is starting to looks like serious issue.
MTCRE, MTCTCE, MTCSE
rextended
Re: v6.14 released
Tue Jun 10, 2014 9:37 pm
I confirm this:
netsinstall routeros-mipsbe-5.26.npk (with netinstall 6.14 or other version not matter)
on SXT Lite5 (or another device not matter)
After reboot, drag routeros-mipsle-6.14.npk
reboot.
the wireless package is installed but no "/interface wireless" or wireless on winbox appear
SOLUTION: on CLI or Winbox enable wireless-fp and reboot.
on reboot wireless-fp are active, and wireless menu come back, without any config.
This is repeatable.
Tested also on 5.25. The only way to not forget wireless are to use 6.7, 6.10 or 6.13 to upgrade, i do not have at the moment other version to try.
Also install 6.13, 6.10 or 6.7 on 5.25/26 do not lose the config or wireless package.
BUG ON 6.14 ONLY: INSTALL 6.14 ON 5.x VERSION DISABLE WIRELESS PACKAGE AND CLEAN ALL THE WIRELESS CONFIG.
I HAVE UPDATED MORE THAN 40 DEVICES, AP AND PTP, FROM 6.10 TO 6.14 AND I HAVE NOT ONE SINGLE PROBLEM. The only two problem are the first two CPE I have upgraded from 5.25 / 5.26 to 6.14
(but my pppoe-server with mrru 1614 and MPPE encryption, over EoIP, still on 6.7 because routerboard still crash with kernel failure on 6.8+, another problem with two or more tickets open but never solved.)
Lupin
Re: v6.14 released
Tue Jun 10, 2014 10:01 pm
Hi rextended!
Hai un contatto skype che vorrei chiederti un po di robette da wisp?
Ciao
rextended
Re: v6.14 released
Tue Jun 10, 2014 10:09 pm
Hi rextended!
Ciao
Salve,
no, non ho ne Skype ne altri.
Se hai problemi o domande, apri un nuovo topic sul forum in modo che tutti ne traggano vantaggio.
Grazie.
Not, i do not have Skype or others.
If you have problems or questions, open new topic on the forum, on this way all user can have profit.
docmarius
Re: v6.14 released
Tue Jun 10, 2014 11:39 pm
In winbox, one can not set the SNTP servers for the SNTP client.
I use broadcast mode anyway, but the server fields are read-only.
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
rextended
Re: v6.14 released
Tue Jun 10, 2014 11:48 pm
mmm.....
you can set it from cli, after that winbox unlock the fileds.
rextended
Re: v6.14 released
Tue Jun 10, 2014 11:51 pm
SECONDARY BUG ON 6.14 ONLY: IS IMPOSSIBLE TO SET THE SNTP SERVER(S) ON WINBOX IF IS SET TO THE DEFAULT 0.0.0.0
Secondary because you can set it on CLI and this unlock the fileds on Winbox.
NTP separate package not affected.
Aug
Re: v6.14 released
Wed Jun 11, 2014 12:30 am
Upgraded RB411AH from 5.25 to 6.14. No problems.
I downloaded all packages and installed the packages that I needed, including the wireless package. Reboot....tada.
I assume the problem is with the upgrade package.
Aug
wildbill442
Re: v6.14 released
Wed Jun 11, 2014 1:18 am
Yeah must be, I used the all-in-one package.
William Burnett
Network Engineer
jarda
Re: v6.14 released
Wed Jun 11, 2014 8:37 am
I used update package once very long time ago and had problems then with selective removing of its parts. Dince then there is only one way for me: download all packages and copy-paste selected, reboot. This worked everytimes and I have version archive for the case I decide to install some older version. Not tried with 6.14 yet.
azendre
Re: v6.14 released
Wed Jun 11, 2014 10:08 am
RouterBoard 433AH 6.14 update will restart every 5-10 minutes the log it says that the kernel fail
expected to correct this error?
normis
Re: v6.14 released
Wed Jun 11, 2014 10:20 am
please make supout.rif file after it reboots, and send to support@mikrotik.com
normis
Re: v6.14 released
Wed Jun 11, 2014 11:07 am
It looks like there can be issues with DHCP and Wireless packages after upgrade from v5 to v6.14. We are working on a fix now.
What you might see is that DHCP and Wireless menus are gone after upgrade. After a reboot, the menus appear, but the config is lost. Reconfiguration is needed. We will try to release a fix soon.
rextended
Re: v6.14 released
Wed Jun 11, 2014 11:25 am
Thanks,
after some test, the problem is on the wireless-fp package.
Upgrading from 5.25 or 5.26 to 6.14 by single packages, the same as contained in routeros-xxxx-6.14.npk omit wireless-fp, this never happen.
And again thanks because wireless-fp package on 23,5Km link NV2 CH0+1 H/V 20+20 has lowered the latency of 4/5ms also on high traffic...
(RB433AH + SR71-15 ---> RB433AH+R52Hn, and on the future RB912UAG-5HPnD + R11e-5HnD on both side)
Well done.
Caci99
Re: v6.14 released
Wed Jun 11, 2014 11:44 am
The ip cloud is a nice feature, but trickier than I would have expected. It would be nice if in the future the user can specify it's own domain name so that it can be remembered.
-Toni-
Don't crash the ambulance, whatever you do
Test471
Re: v6.14 released
Wed Jun 11, 2014 12:00 pm
If I have my own doman than I would not need this useless feature since I would then have script which would check for IP changes and update my domain records.
miro
Trainer
Trainer
Re: v6.14 released
Wed Jun 11, 2014 12:06 pm
Could you tell us, when are you planning to implement loop prevention in CRS series switches?
tomaskir
Trainer
Trainer
Re: v6.14 released
Wed Jun 11, 2014 12:11 pm
Good luck scripting this your own way.
This feature is great since you click one button, create one CNAME record in your DNS, and you get functioning DynDNS.
Your way, you would have to script all this on RouterOS, then on BIND, create an interface for RouterOS to talk to BIND somehow, secure it all, and many other things.
Not to mention, if you domain in hosted somewhere, you dont even have control over BIND, cant script, etc, etc...
The IP>Cloud functionality is a great addition.
Test471
Re: v6.14 released
Wed Jun 11, 2014 12:29 pm
http://wiki.mikrotik.com/wiki/Dynamic_D ... for_dynDNS
The easy way :)
Wasted 2 minutes to register free domain on ChangeIP (or DynDNS) and have "A record" I can remember.
normis
Re: v6.14 released
Wed Jun 11, 2014 12:34 pm
The easy way :)
Easy for you. For other people, they don't even know such scipting menu exists :)
Sander
Re: v6.14 released
Wed Jun 11, 2014 12:38 pm
Verify Server Certificate on SSTP doesn't work
6.14 SSTP client to 5.26 SSTP server doesn't work.
SSTP client log: handsharke failed (6)
SSTP server log: tls shutdown
6.13 SSTP client to 5.26 SSTP server works.
boen_robot
Re: v6.14 released
Wed Jun 11, 2014 12:39 pm
Why not use the License's "Software-ID" instead? It's available on all RouterOS platforms, including x86, it has a DNS compatible alphabet, and it's supposedly unique for each distinct device, isn't it?
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
Sander
Re: v6.14 released
Wed Jun 11, 2014 12:51 pm
Log data and time does not sync to NTP server after reboot.
diode
Re: v6.14 released
Wed Jun 11, 2014 1:05 pm
I had the same issues with upgradeing 5.x -> 6.14, BUT I also had this issue from 6.13 -> 6.14 on one device out of 200. I'm frigthened to upgrade the rest of the 100 devices ...
the positive sides: nstreme is extremly fast with the wireless-fp package, it also speeds up nv2 links (but not all). still no help on heavily interfered sectors.
thanks from vienna
kapode
Re: v6.14 released
Wed Jun 11, 2014 1:59 pm
Could you fix that?
Is there any way to solve this?
When trying opening MT graphing it takes about 30-40 sec. After that - only Int, res, graphs are visible.
rextended
Re: v6.14 released
Wed Jun 11, 2014 2:11 pm
you find the solution on 6.13 topic, or netinstall and import again the config by .rsc (not .backup)
Test471
Re: v6.14 released
Wed Jun 11, 2014 2:29 pm
The easy way :)
Oh, is that so? In that case I understand the purpose of "ip cloud" feature.
I was just thinking that MT target group are people with significant IT education/experience. My mistake :)
normis
Re: v6.14 released
Wed Jun 11, 2014 2:32 pm
The easy way :)
we have many great home access points, and quickset + default config makes it easy for people to use them, without even configuring anything
jarda
Re: v6.14 released
Wed Jun 11, 2014 2:42 pm
I shall correct my oppinion. Now I think that we can expect torrent client in 6.17, because mikrotik is now targeting such market area...
normis
Re: v6.14 released
Wed Jun 11, 2014 2:44 pm
yes, why not
patrick7
Re: v6.14 released
Wed Jun 11, 2014 2:47 pm
I see massive higher load after upgrading to 6.14 on RB2011UAS. RB951G-2HnD is fine.
Anyone else?
Regards
normis
Re: v6.14 released
Wed Jun 11, 2014 2:50 pm
Anyone else?
Regards
check "/tool profile" to see what is causing it
patrick7
Re: v6.14 released
Wed Jun 11, 2014 2:56 pm
I think it's ipsec. There are 2 devices with the problem. Disabled ipsec on one and load became normal again. I now disabled ipsec also on the second one. Lets see...
McTedson
Re: v6.14 released
Wed Jun 11, 2014 3:23 pm
Probably not necessarily a 6.14 issue, but have updated a rb2011UAS from 5.24 to 6.14 which used an Atheros USB adapter (AR9271 chipset).
After upgrade, the adapter is not recognized anymore. Tried it on a x86 6.14 router and no go either.
Did Mikrotik remove the Atheros USB aliases/drivers for USB dongles in 6.x ?
Raf
Re: v6.14 released
Wed Jun 11, 2014 4:29 pm
Yes. Cacti for example.
Rafał Wójcik from AWB-NET
High Definition enthusiast
tomaskir
Trainer
Trainer
Re: v6.14 released
Wed Jun 11, 2014 4:38 pm
yes, why not
Fixing bugs is MUCH MORE important to your CORE user community, then adding useless things like Torrent client.
If there were no long standing bugs in RouterOS, then I'm all for it, add all the functionality you want.
But PLEASE fix serious bugs and needed features in IPv6, IPSec, PPPoE and other areas before doing that.
I mean, you want to add a Torrent client, but not client tools for VMWare or HyperV? How does that make sense?
With VMWare client tools and VXLAN support for example, MikroTik could break into a whole new network market ... what will a Torrent Client accomplish?
End users have hunder possible vendors to choose from, which are much easier to use and much more feature rich for their market, and you want to compete there?
You have a good and serious position in professional-grade networking, why not strengten and improve your position there?
Your core community and your core target market is ISPs, and now Enterprise and Carriers with CCRs. Features needed for this core community/market should receive priority, and fixing bugs should receive priority.
This are the things that should be important to you, not adding a Torrent Client for home users, which are a minor percentage of your users.
Test471
Re: v6.14 released
Wed Jun 11, 2014 5:00 pm
Apple style :)
yes, why not
Why? Because you need to implement udp on ovpn first.
Aveyer
Re: v6.14 released
Wed Jun 11, 2014 5:02 pm
I agree with Tomaskir, wasting time with torrent clients is crazy, Mikrotik is mainly for ISPs.
Focus on bug fixes and stability, and then update The Dude instead :)
theprism
Re: v6.14 released
Wed Jun 11, 2014 5:11 pm
Totally agree with tomaskir, Test471 and Aveyer
vflorin
Re: v6.14 released
Wed Jun 11, 2014 6:25 pm
+++ Totally agree. Weeks of nightmares with VLANs management with CRS125 here.
Vincent Florin - HeapSys (France).
yes, why not
jarda
Re: v6.14 released
Wed Jun 11, 2014 6:31 pm
Maybe we are all wrong. Maybe home end consumer market has ability to provide much bigger profitability for the mikrotik than all ISPs of the world together. Dollars vote, not your karma here...
com2com
Re: v6.14 released
Wed Jun 11, 2014 6:37 pm
With 2 pppoe connections have a bug since 6.13.
ECMP balancing
ip firewall nat add action=masquerade chain=srcnat src-address=localnet /
ip route add distance=1 gateway=inet1 routing-mark=wan1
add distance=1 gateway=inet2 routing-mark=wan2
add distance=1 gateway=inet1,inet1,inet1,inet2
Only active second route.
Before 6.13 all work.
roadracer96
Forum Veteran
Forum Veteran
Re: v6.14 released
Wed Jun 11, 2014 7:03 pm
LOL.. That made me chuckle a bit..
IHRMax
Re: v6.14 released
Wed Jun 11, 2014 9:09 pm
Problem with
If you create tunnel with Winbox the MTU is 1500.
If you create tunnel with Terminal the MTU is 1458
_saik0
Re: v6.14 released
Wed Jun 11, 2014 10:16 pm
I seriously hope that torrent comment "yes why not" way sarcastic...
Any improvements on IPSec in 6.14?
Since 6.13 SAs keep dying and only flush every few hours helps.
Quindor
Re: v6.14 released
Thu Jun 12, 2014 1:28 am
Agreed with the torrents remarks. If MikroTik would seriously introduce a torrent client other then maybe downloading updates (also not quite worth the effort) it would seriously make me think about the product twice. :(
Buy some kind of ARM (Android) stick and put linux on it, a Asus/HP Chromebox or whatever other cheap hardware and attach an USB disk if you want a torrent client, but putting one in a router is horrible idea....
So I agree, work on fixing bugs and improving and providing useful features towards what the devices are intended for. Not useless gimmick crap other consumer routers might come up with.
http://www.campzone.nl World's Largest Outdoor LANParty, http://intermit.tech Intermittend Technology blog, My blog about the ESP8266, IP Camera's and other tech related subjects!
paoloaga
Re: v6.14 released
Thu Jun 12, 2014 4:09 am
I agree about fixing/working on more important things. There are no IPv6 filters for OSPF. No "set priority" in IPv6 mangle. IPv6 native loopbacks (/128) are not propagated correctly within OSPF. There is no BGP IPv6 recursive lookup, no conntrackd-like to achieve firewall HA among multiple/redundant devices, routing crashes when a PPPoE client reconnects with an IP address included into a BGP aggregated net, (next one is tested only on CCR1009) after about one day, flash becomes read-only (fixed at reboot, for anoter ~24 hours), weird behaviour when two identical ip addresses are used inside two separate VRFs, and a few more ones.
It would be interesting to fix/include these options before adding exotic functionality.
We're running out of IPv4 addresses, so having a stable and full featured IPv6 is becoming a must.
If you have resources to work on other new features (like the torrent client) that's welcome, but please keep an eye on those topics...
[edit: fixed a few typos]
bajodel
Long time Member
Long time Member
Re: v6.14 released
Thu Jun 12, 2014 9:20 am
I agree about fixing/working on more important things....
idem..
m4rk0
Re: v6.14 released
Thu Jun 12, 2014 11:43 am
Hello, this is my quick report.
After upgrading RB433AH to ROS 6.14, all wlan cards disabled and restarted to default, after first boot PPP and some other packages were missing from Winbox menu, after second reboot they come back.
Second, after upgrading RB2011LS, missing IP>DHCP package, after second reboot RB bricked, I had to manually reset it with Reset button.
:shock:
http://www.mreza-wisp.ba/
Please, give Karma if I fix your problem
Certified MTCNA
honzam
Re: v6.14 released
Thu Jun 12, 2014 11:57 am
:shock:
From download page:
Note: Upgrading from RouterOS v5 to v6.14 can cause configuration loss for DHCP and Wireless. Please refrain from upgrading your v5 installation until a fixed version has been released
rextended
Re: v6.14 released
Thu Jun 12, 2014 12:12 pm
I'm testing 6.15 "last-before-release" now.
One moment and I check if the wireless/dhcp problem and the SNTP field are fixed...
SNTP still not working on winbox: both server fields readonly, must be first set on terminal to unlock.
Glitch: removing the possibility to specify broadcast or unicast, the fields still not active.
about user-manager profile limitation still not working: I know this are secondary from release one 6.15 then upgrade correctly 5.x
normis
Re: v6.14 released
Thu Jun 12, 2014 12:35 pm
SNTP fixed too. We didn't put the correct version up yet
User Manager will not be fixed in v6.15
rextended
Re: v6.14 released
Thu Jun 12, 2014 12:44 pm
Yes, thanks, I understand:
rextended
Re: v6.14 released
Thu Jun 12, 2014 12:56 pm
SOLVED: 6.15 (2014/06/12 09:51:16) DO NOT CORRUPT WIRELESS OR DHCP CONFIGURATION AFTER DIRECT UPGRADE FROM 5.25 OR 5.26 (and I think all the other 5.x versions)
using drag & reboot routeros-xxxxxx-6.15.npk package
lashguti
Re: v6.14 released
Thu Jun 12, 2014 1:03 pm
is this your sntp remake?
who needed such useless modification, and sntp unicast mode is not working, input fields are read-only
rextended
Re: v6.14 released
Thu Jun 12, 2014 1:06 pm
This is already (!) fixed on outcoming 6.15, do not post more complain about this.
-1 karma for your hurting method of writing. [The tone used on the post is very hurting.]
lashguti
Re: v6.14 released
Thu Jun 12, 2014 1:19 pm
you'd better to not make such "hurting" mistake again, understand?
rextended
Re: v6.14 released
Thu Jun 12, 2014 1:28 pm
You think I'm a developer?
And if also I had been one developer, how much you are rude? This is the way to "talk" to someone?
This is user forum, are you able to read?
Notice: For support from Mikrotik staff, write to support@mikrotik.com - Mikrotik does not generally offer support on the forum, this is a user forum
and about your "understand", you can put this on your pride.
This is the last post on reply of you. I do not want start one "flame".
Users browsing this forum: Baidu [Spider], ckl88, cmdelossantos, rioven, tdw, Zacharias and 210 guests
