HaPe
Subnet mask and swos
Sat Jun 14, 2014 10:53 pm
which subnet mask does swos use(/8, /24, /16 ...)?
In anticipation on new The Dude release.
dimnik
Re: Subnet mask and swos
Tue Feb 17, 2015 4:19 pm
http://wiki.mikrotik.com/wiki/SwOS#System_Tab
"Note: SwOS uses a simple algorithm to ensure TCP/IP communication - it just replies to the same IP and MAC address packet came from. This way there is no need for Default Gateway on the device itself."
Hotz1
Mon Mar 23, 2015 9:28 pm
Oh, there is definitely a need for them; it's just that it works in a lot of places without them.
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
ZeroByte
Mon Mar 23, 2015 10:48 pm
:lol: :lol:
What a hilarious response! So true, too. :)
When given a spoon,
you should not cling to your fork.
The soup will get cold.
chechito
Fri May 08, 2015 12:51 am
no need???
no way to manage it remotely using vlans and accessing from a remote VPN
Hotz1
Wed Jun 10, 2015 3:40 pm
no need??? no way to manage it remotely using vlans and accessing from a remote VPN
What they're saying is that it replies via Layer 2. A device connected to the switch hands the switch a packet. When the switch builds its reply, it still sets the Dst IP to the Src IP of the original message, but then it sets the Dst MAC to the original Src MAC, regardless of the Dst IP. That means replies always get handed back to the same neighbor that forwarded the original packet. So, as long as the switch is on a network managed by a router, you can reach it in any way the router supports--including VLANs, PPTP, etc.
The switch does answer to its own IP on whatever VLAN you use to reach it, so it doesn't truly support the "management vlan" concept; but as long as your router assigns the management address space to the appropriate VLAN, it will work as though it did. (But if you force its address onto a different VLAN, it will still reply.)
* If you mean the switch should be able to establish its own tunnel to the NOC, you're going to need a more expensive ($$$$) switch.
Gloucester, MA, USA
chechito
Wed Jun 10, 2015 3:59 pm
thanks for your reply
i only want the sw os to have a default gateway only that.
because with the actual functionality i cannot manage it from a different subnet, the only way i found to manage it from a different subnet was using local router as a web proxy
bpwl
Thu Jan 28, 2021 2:20 pm
There should be no need for the web proxy. The SwOS will answer with the original src IP as dst IP, and the MAC address of the router (the src MAC address in the received request) . The router will forward according its routing tables.
k6ccc
Long time Member
Long time Member
Sun Jan 31, 2021 8:26 pm
I have not found a situation where I could not access any of my switches. At the very least, the computer is on a different VLAN than the switch is listening on, so traffic is going through a router or two to get there and it always finds its way back. This computer has an IP on my .101 LAN. Although it is plugged directly into my family room switch, the switch IP is on my .201 LAN, and the switch is set to only accept traffic on the 201 VLAN. So to get to the switch from this PC is as follows: PC on .101 VLAN > [through switch 1 and switch 2] > router 1 > router 2 [through switch 2] > Switch 1
C:\windows\system32>tracert 192.168.201.1
Tracing route to 192.168.201.1 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.101.251 (Router 1)
2 <1 ms <1 ms <1 ms 192.168.211.252 (Router 2)
3 <1 ms <1 ms <1 ms 192.168.201.1 (Switch 1)
Trace complete.
I often get to the switches from remote locations via the internet (yes, there is some serious firewalling in the routers on that).
Never failed.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
bpwl
Sun Jan 31, 2021 10:25 pm
The only thing with this "answer with src IP and src MAC as destination" mechanism is that the switch cannot initiate a connection to something outside the own subnet, as it does not have a clue on the gateway to use. But I see no process that initiates a connection from the switch (like SNMP trigger, syslog send, SNTP request, DNS request....).
If the return-path is correct in the router/gateway, there should be no problem to answer, respond to, or maintain a remotely initiated connection.
k6ccc
Long time Member
Long time Member
Sun Jan 31, 2021 11:17 pm
Check for System Upgrade - and that, for me always works...
Jim
bpwl
Mon Feb 01, 2021 1:24 am
I admit the "upgrade" check puzzled me too. (Maybe the switch had router discovery methods ?)
But as you stated it , I started having a little check.
There is no IP session originating from the switch at my edge gateway/firewall. (There should have been an open NAT session)
So where does it come from ? There is traffic from my PC. So let's check the browser page. (Chrome has the developers tools built in).
And the browser is checking upgrade.microsoft .com to fill in this page. The switch is not initiating a request.
k6ccc
Long time Member
Long time Member
Mon Feb 01, 2021 4:33 am
Ain't that interesting...
Jim
Users browsing this forum: No registered users and 4 guests
