mapunda
Metal 9HPn
Tue Jun 17, 2014 12:33 am
1. What is the frequency range
2. Which antenna is recomended
3. As per your spec sheet it is quoted as follows "Metal9HPn is compatible only with another Metal9HPn" Does this means that if I take routerboard with XR9 card...there will be no conection!
4. When are we going to see routerboard with 900mhz card integrated?
rextended
Re: Metal 9HPn
Tue Jun 17, 2014 11:47 am
!!! 900MHz???
Is licensed only on US market...
I'm Italian, not English. Sorry for my imperfect grammar.
normis
Re: Metal 9HPn
Tue Jun 17, 2014 12:14 pm
1. 902-927MHz (Selectable center frequencies 907 to 922)
2. Any 900MHz antenna that is designed for the above range
3. It will not work with XR9 just like it says
4. Isn't this it?
Not sure about "only", but as with anything, use it according to local law and regulations.
rextended
Re: Metal 9HPn
Tue Jun 17, 2014 1:53 pm
:lol:
One day I want see Metal 4HPn and QRT-4HPn for 4000-4999 MHz... ;)
And on this way I can BUY frequencies and other competitor do not trash the balls...
digitexwireless
Re: Metal 9HPn
Thu Jun 19, 2014 10:49 pm
Normis,
So not compatible with an RB411 using an XR9? Please say it isn't so. We have a number of 900 POP's using XR9's and Xagl cards.
honzam
Re: Metal 9HPn
Thu Jun 19, 2014 11:20 pm
Metal9HPn is compatible only with another Metal9HPn, and available only with US type power plug. It will not work with any other 900MHz manufacturer product.
LAN, FTTx, Wireless. ISP operator
0ldman
Re: Metal 9HPn
Tue Jun 24, 2014 1:06 am
Anyone got their hands on one yet?
If they have decent filtering on them, I may start pushing 900MHz in other locations.
I've got a Xagyl 900MHz right now, much better than the XR9, but it still has it's issues.
edit: I guess that could just be asked here of Mikrotik.
How is the out of band filtering? Decent amplifier? I'd love to get some more information.
Atnevon
Re: Metal 9HPn
Wed Jun 25, 2014 4:34 pm
I started another thread on this, but apparently I missed this one. Sadly, it doesn't seem there's an answer in either of them.
Does anyone know what channel widths are available on these, and how flexible the channel selection is? For example, it would be fantastic if we could do something like 921.6 as a center, with a 2mhz wide channel.
Atnevon
Re: Metal 9HPn
Wed Jun 25, 2014 5:35 pm
I found this, and it gets me closer to where I want to be. Maybe this will help me ask the question in the right way:
http://wiki.mikrotik.com/wiki/Manual:Wi ... d_Channels
With the chipset in the Metal 9HPn (AR9283), what is the step, the width range, and the width step?
Atnevon
Re: Metal 9HPn
Wed Jun 25, 2014 6:07 pm
Wooohooo, they replied back to me. Here's the info so far, thanks to Kristaps:
Regarding metal 9 using Advanced Channels with metal you can use channel width
minimum 2.5mhz and steppings 0.5mhz
0 list=one name="ch1" frequency=913.5 width=2.5 band=2ghz-b/g/n
extension-channel=eC
but it will only connect to metal9 because how this product generates frequency.
I'm double checking on max channel width to make sure I have all the facts straight, but given the center ranges they gave, I'm guessing that it would probably be 10mhz.
ptoribiop
Re: Metal 9HPn
Tue Jul 01, 2014 5:17 am
Hello Normis ... wanted to know more about Metal 9HPn - MikroTik, I have much interest in using them in a project, and I think many Latinos to use this frequency range countries have to seek permission from the government ... but our interest is more in the use and range of channels to be used with the Metal 9HPn - MikroTik, also what kind of antenna recommended for better performance 9HPn Metal - MikroTik.
I will appreciate all the information.
Greetings ... Pedro Alejandro
****excuse my English
@redcamaleon
normis
Re: Metal 9HPn
Tue Jul 01, 2014 8:30 am
MikroTik doesn't offer any 900MHz antennas, so any antenna that is designed for 902-927MHz will work just fine.
B0g4r7
Re: Metal 9HPn
Sun Dec 14, 2014 4:52 am
I realize I'm replying to an old thread, but I have not seen any more recent discussion of the issue.
I just wanted to say that we have 2 Metal-9HPn CPEs connecting to an RB411AH/XR9 AP, and it works just fine.
This is using NV2 on a 10MHz channel. I have not tried other configurations.
syadnom
Re: Metal 9HPn
Fri Feb 20, 2015 2:11 am
can anyone else confirm the XR9 or for that matter the SR9 working as an AP with 9HPn clients?
0ldman
Re: Metal 9HPn
Fri Jul 31, 2015 5:26 pm
I just stumbled across this old post...
B0g4r7, any further details?
jordantrx
Long time Member
Long time Member
Re: Metal 9HPn
Thu Jan 21, 2016 4:53 pm
Yes the Metal 9HpN will work with XR9 Ubiquiti, You probably cant get the N speeds out of it because your limited to what the XR9 can do. I have only done limited tests not sure how well it will work, either way I am going to get more and do some more testing. Would like to move away from canopy to these and use H pol sectors to clean noise up.
~Agricultural WISP "ZONE"~ Beware of oncoming cattle and dont hit the farmer!!! I need to ask him about using his silo for an AP first"~
*Automated Billing Installer* http://wiki.mikrotik.com/wiki/AutomatedBilling Built by Krige ;-)
0ldman
Re: Metal 9HPn
Thu Jan 21, 2016 10:05 pm
I don't know why Normis says it isn't then.
I'd have been buying them for quite some time now if I knew it wasn't a complete platform change.
syadnom
Re: Metal 9HPn
Thu Jan 21, 2016 11:39 pm
maybe mikrotik just doesn't want to deal with potential compatability issues...
mducharme
Trainer
Trainer
Re: Metal 9HPn
Mon Jun 19, 2017 5:39 am
We have metal 9 working successfully with ubiquiti m900 nanostation and rocket. This gives us a migration path from ubiquiti.
syadnom
Re: Metal 9HPn
Mon Jun 19, 2017 5:45 am
@mducharme how well is the m900 working for you compared to ubiquiti m900 radios? what antennas are you using? I could put these to use if they were decent.
mducharme
Trainer
Trainer
Re: Metal 9HPn
Mon Jun 19, 2017 6:01 am
We used 8dbi omni antennas with our rocket 900 units and were lucky to get 8 Mbps. Mikrotik gets a lower noise floor by 12 dB in the same environment, and seemingly over twice the throughput. Ubiquiti changed their rocket m900 antenna gain setting in newer firmware to a drop down list with 13 and 15dB the only options. Our signals were reduced significantly since it is an 8dbi omni at our sites. This combined with the fact that Ubiquiti seems to not care about the 900mhz space led us to migrate.
The coexistance requires the ubiquiti to be an access point with AirMax turned off. We have worked around this by using virtual station wds interfaces on the mikrotik ap side after reconfiguring customer m900 loco su's as ap's on the same frequency and channel size as the metal 9 AP. It is a bizarre workaround but it works.
syadnom
Re: Metal 9HPn
Mon Jun 19, 2017 6:11 am
I pulled all my ubiquiti 900Mhz gear out, so I'm not needing to integrate with them. m900 radios only passing 1-2Mbps when the math says it should do 12Mbps, and old old canopy gear is doing 6Mbps+. I have a few areas that are heavily treed. I can push m2 gear through but can't get above 1-2Mbps, 900Mhz should be able to do 2-3x that speed based on propagation through trees.
mducharme
Trainer
Trainer
Re: Metal 9HPn
Mon Jun 19, 2017 6:17 am
Yeah the m900 performance drops significantly esp with lots of customers. We have 25 customers on one overloaded AP and only getting 3.5Mbps throughput total. Pretty terrible... mikrotik seems much better.
Users browsing this forum: No registered users and 36 guests
