mauricioisp
The Dude x86 4beta3
Tue Jun 17, 2014 4:47 am
Does anyone has The Dude 4.0-beta3 for x86?
The dude for x86 or routerboards is no longer available here: http://www.mikrotik.com/thedude
ptt
Re: The Dude x86 4beta3
Wed Jun 18, 2014 4:08 am
Are you sure ?
normis
Wed Jun 18, 2014 11:17 am
He was asking for the RouterOS package. Yes, we removed them, because they had major problems and people were risking with their config.
ptt
Wed Jun 18, 2014 11:24 pm
Ok, my bad.
crodler
Sun Sep 14, 2014 12:13 am
Send me a PM.
anaktos
Fri Nov 28, 2014 9:04 pm
I installed dude4.0beta3 on x86(routeros v6.21.1) but not work.
Appears as package installed and I see this in execution, but I can not enter from the web or from the client
______
MTCNA
Norman
Mon Dec 29, 2014 6:25 am
The Dude doesnt work on RouterOS 6.x .
This is due to how execution has changed slightly in newer versions.
Dude works fine on RouterOS 5.x .
I could probably fix so it works on RouterOS but Id probably violate some licenses repackaging the dude x86 npk .. So not taking any risks. Unless Mikrotik would let me ;)
Hotz1
Mon Mar 30, 2015 8:30 pm
I have it running under ROS 6.19/x86. Since we can't get it running beyond that version (Upgrade to 6.20 --> No response from The Dude; revert to 6.19 --> configuration lost, time to rebuild the map.), we are stuck keeping this one rack-mount server spinning just for The Dude. :?
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
Hotz1
Thu Apr 02, 2015 2:31 am
As an alternative to keeping that ROS/x86 server running just for The Dude, I was thinking about putting it in a VM. Can someone please direct me to basic instructions (my VM expertise is limited) on how to load the RouterOS ISO image into either Xen or KVM?
Gloucester, MA, USA
Users browsing this forum: No registered users and 8 guests
