MUM Europe 2020
safiullahtariq
VoIP/SIP help with QoS
Thu Jun 19, 2014 9:05 pm
Hello All,
I need some advices and also some help.
I have 2 sites, remotely connected to each via ptp wireless link. I have also attached the screenshot of the network diagram. The IP of the SIP server is 192.168.0.150.
The Routers I am using are RB750GL
What I want is, I want to priorities the VoIP traffic so that the voice quality can increase. Can anyone please help me on how to do it? Any advice, anything will be helpful as I dont know how to do it.
Best Regards,
Safiullah
awacenter
Re: VoIP/SIP help with QoS
Fri Jun 20, 2014 10:30 am
Yuo have to use firewall mangle rules and queues.
First of all, identify the type of traffic using magle. but import the SSL7 signs fromhttp://www.mikrotik.com/download/l7-protos.rsc
In this example, My output interface is WLAN and my LAN is in interface ether1.
ros code
/ip firewall mangle
add action=mark-connection chain=forward comment=DNS disabled=no dst-port=53 \
    new-connection-mark=dns passthrough=yes protocol=udp
add action=mark-connection chain=forward disabled=no layer7-protocol=dns \
add action=mark-packet chain=forward connection-mark=dns disabled=no \
    new-packet-mark=dnsP passthrough=no
add action=mark-connection chain=forward comment="VoIP (SIP)" disabled=no \
    layer7-protocol=sip new-connection-mark=voip passthrough=yes
add action=mark-connection chain=forward comment="VoIP (Skype)" disabled=no \
    layer7-protocol=skypetoskype new-connection-mark=voip passthrough=yes
add action=mark-connection chain=forward disabled=no layer7-protocol=skypeout \
add action=mark-connection chain=forward disabled=no layer7-protocol=h323 \
add action=mark-connection chain=forward disabled=no dscp=46 new-connection-mark=voip passthrough=yes
add action=mark-packet chain=forward connection-mark=voip disabled=no \
    new-packet-mark=voipP passthrough=no
add action=mark-connection chain=forward comment="Other traffic" disabled=no \
    new-connection-mark=otros passthrough=yes
add action=mark-packet chain=forward connection-mark=otros disabled=no \
    new-packet-mark=otrosP passthrough=no
add action=mark-connection chain=forward disabled=yes new-connection-mark=\
    desconocido packet-mark=no-mark passthrough=yes
Basicaly, I differenciate three types of traffic:
  • Routing protocols
    VoIP
    Other Traffic
ros code
/queue type
add kind=pcq name=PCQ pcq-classifier=src-address pcq-limit=50 pcq-rate=0 \
    pcq-total-limit=2000
add kind=pcq name=DOWN pcq-classifier=dst-address pcq-limit=50 pcq-rate=0 \
add kind=pcq name=UP pcq-classifier=src-address pcq-limit=50 pcq-rate=0 \
Then I create two queue type: UP AND DOWN of type PCQ.
Finally, I create the queue tree for the traffic priorization:
ros code
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
max-limit=750k name=UPLOAD packet-mark="" parent=wlan1 priority=2
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=200k \
max-limit=500k name=VOIP-UP packet-mark=voipP parent=UPLOAD priority=5 \
queue=UP
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=100k \
max-limit=150k name=ROUTING-UP packet-mark=dnsP parent=UPLOAD priority=3 queue=\
UP
max-limit=0 name=OTRO-UP packet-mark=otrosP parent=UPLOAD priority=8 queue=\
UP
max-limit=0 name=DOWNLOAD packet-mark="" parent=ether1 priority=2
max-limit=150k name=ROUTING-DOWN packet-mark=dnsP parent=DOWNLOAD priority=3 \
queue=DOWN
max-limit=0 name=OTRO-DOWN packet-mark=otrosP parent=DOWNLOAD priority=8 \
queue=DOWN
max-limit=500k name=VOIP-DOWN packet-mark=voipP parent=DOWNLOAD priority=\
5 queue=DOWN
I hope this explanation is satisfactory for you and I increase my karma.
amperex
Wed Apr 08, 2015 9:44 am
Hello and sorry for answer in a old topic. I would like to apply this solution to my case.
I have a rb750 that have the ether3 as wan port to internet and have two ppoe servers in ether4 and ether5 where the computers are connected. I would like to priorize voip.
safiullahtariq
Wed Apr 08, 2015 11:49 am
I am on way to somewhere. As soon as im free ill help you.
Ive successfully prioritised my voip traffic. Ill write a detail answer later
amperex
Wed Apr 08, 2015 2:52 pm
Ok, thank you I will wait. :)
safiullahtariq
Thu Apr 09, 2015 4:05 pm
I apologize for the delay
I guess your VoIP is directly connected to one of the ethernet ports of RB750
Go to IP>>Firewall>>Mangle
Create a new mangle rule.
In General Tab:
Chain: prerouting
Src Address: YOUR VoIP IP ADDRESS
In Action Tab:
Action: Mark connection
New connection Mark: VOIP
Passthrough : Yes (check)
Create Another Rule:
In General Tab:
Chain: prerouting
destination Address: YOUR VoIP IP ADDRESS
In Action Tab:
In General Tab:
Chain: prerouting
Connection Mark: VOIP
In Action Tab:
Action: Mark packet
New packet Mark: VOIP
Passthrough : No (uncheck)
Now Go to Queues
Create a new Simple Queue
In General Tab:
Target: 0.0.0.0/0
Target Upload
Max limit: I have given 1M - you can give more or less depending on the bandwidth you want for you VoIP.
Target Download
Advanced Tab
Packet Mark : VOIP
Target Upload: unlimited
Priority: 1
Target Download: unlimited
Priority: 1
Parent None.
Now create another Simple Queue.
In General Tab:
Name: All other Traffic
Target: 0.0.0.0/0
Target Upload
Max limit: I have given 5M - you can give more or less depending on the bandwidth you want for you VoIP.
Target Download
Advanced Tab
Packet Mark : no-mark
Priority: 8
Priority: 8
Parent None.
This is all you got to do. Do reply if you need any more help. And do tell the results.
Users browsing this forum: Google [Bot] and 63 guests
