Trekkie
Routerboard 751U-2HnD Software Question
Mon Jun 23, 2014 7:37 pm
I'm using one of these for the first time, and have it installed. I've been using non-wireless RB433G for a while and it is running 6.14 (or whatever the latest RouterOS is)
When I went to make sure my 751U-2HnD was up to date, i noticed it is on 5.26 from the factory. When I updated it, it said there is no updates available. (Packages -> Check for updates).
I don't see anything that says the 751U-2HnD runs on a different version of software. Can I confirm from someone that 5.26 is the right software version or do I need to update this to the latest via another method besides packages -> check for updates?
Thank you
honzam
Re: Routerboard 751U-2HnD Software Question
Mon Jun 23, 2014 8:34 pm
Copy this file (drag & drop) to files http://download2.mikrotik.com/routeros/ ... e-6.15.npk
then
/system reboot
LAN, FTTx, Wireless. ISP operator
Trekkie
Mon Jun 23, 2014 9:21 pm
OK. So that's a yes then? :)
Thanks. updated without issue, just wanted to make sure that was the right thing to do :)
Users browsing this forum: sckn and 14 guests
