MUM Europe 2020
mxmxmxmxmx
Dude cant work on 6.15
Wed Jun 25, 2014 1:33 am
I cant see dude package on MT v 6.15 with wireless-FP
mxmxmxmxmx
Re: Dude cant work on 6.15
Wed Jun 25, 2014 1:36 am
Downgraded to 6.13 WORKS: (Checked on two different Routerboards) Disk space is not the problem.
jarda
Wed Jun 25, 2014 8:47 am
I guess mikrotik switched off the ability to install the old dude into newer ros.
normis
Wed Jun 25, 2014 9:29 am
Did not switch off, it is a bug.
jarda
Wed Jun 25, 2014 9:33 am
Even better.
mxmxmxmxmx
Wed Jun 25, 2014 10:52 pm
hope it'll be fixed in next release?
CyberTod
Long time Member
Long time Member
Tue Jul 01, 2014 3:53 pm
I have it installed on 951ui a few versions ago. Now I'm with v6.15 and it is not shown in the package list, but it works.
mxmxmxmxmx
Mon Jul 21, 2014 1:16 pm
Unfortunatelly it is not fixed in 6.17...
normis
Mon Jul 21, 2014 1:17 pm
The Dude package must be fixed, not RouterOS. And as you know, Dude has not seen updates in some while.
wk5h
Thu Aug 07, 2014 3:47 pm
FWIW, dude v4.0beta3 is still working on my x86 machine even after it was upgraded to 6.18
CyberTod
Long time Member
Long time Member
Thu Aug 07, 2014 3:50 pm
It was working for me too on my 951ui at home, but I was having some problems when rebooting the router, so I netinstalled the board - it was no longer visible in the installed packages. No problems since.
elmer
Tue Sep 02, 2014 12:49 am
My DUDE server x86 on AthlonXP 2000+ 512DDR, Soltek MoBo has gone yesterday :(
Update to 6.19 kills all the system packages. After install i`ll see kernel panic
some hashes appeared on the monitor connected to station then...
...system stop loading on "Loading with..." Total crash...
Did it unrecoverable? HLP~!~
THX for help :) Making from beginning... :P
mxmxmxmxmx
Mon Oct 06, 2014 3:01 pm
Normis as you can see ROS package is "fixed". "Fixed", because now i see dude package on the list of packages, but dude doesn't work on 6.20.
normis
Mon Oct 06, 2014 3:03 pm
Nothing has changed. Dude package is not fixed and is not available.
mxmxmxmxmx
Tue Oct 07, 2014 2:23 am
Normis, look at 6. 20 changelog:
What's new in 6.20 (2014-Oct-01 10:06):
*) fixed problem - it was not possible to see & uninstall dude package;
jarda
Tue Oct 07, 2014 8:00 am
And?
CyberTod
Long time Member
Long time Member
Tue Oct 07, 2014 9:14 am
Exactly as described.
In the later v6 version Dude was causing major problems, but starting from around 6.15 it was not visible in packages and there was no way to uninstall it. In 6.20 you can see it in package list so you can uninstall it. That is the fix. The ability to uninstall the not working package.
Users browsing this forum: No registered users and 17 guests
