ATROX
BUG was found. IPsec works not stable
Wed Jun 25, 2014 8:45 am
There are several tunnels IPsec. Regardless of time and without changing any settings tunnels stop working.
In the settings you can see that the key exchange in one direction occurs, but the traffic flow is not (IP->IPsec->Installed SAs->some key->Current Bytes=0).
After several reboots tunnel restored. After spending some time again stops working.
Fix please!
Remote office work impossible. Business idle incur losses
RouterOS - v6.15/6.14
HW - CCR1036-12G-4S, RB2011UiAS, RB951G-2HnD, RB2011UiAS-2HnD
ATROX
Re: BUG was found. IPsec works not stable
Wed Jun 25, 2014 9:00 am
I updated every 6.15.
6.15 between the same problem.
jarda
Wed Jun 25, 2014 9:35 am
Duplicate topic? Have you sent message to support?
ATROX
Wed Jun 25, 2014 9:56 am
Sute on a separate issue. I really left the same message in another topic. But it is to discuss the new version. Yes, I sent a message to support.
semakka
Wed Jun 25, 2014 1:31 pm
set a ping script like
/ping <remote private IP> src-address=<local private IP> count=10
and run it every 5 minutes or so...
I've had the same issue when there was no traffic through the tunnels and that sorted it
cheers
ATROX
Wed Jun 25, 2014 1:50 pm
cheers
Thank you. But this is not the solution. Tunnel should work without this script. If the tunnel is too much is not the solution ...
semakka
Wed Jun 25, 2014 1:54 pm
you'll be surprised... I've seen IPsec tunnels behaving the same even with cisco gear...
it might not be "the solution" but it can be "a solution" :)
cheers
onnoossendrijver
Wed Jun 25, 2014 1:57 pm
Well, this is by 'design' and not a bug. You should explicitly take precautions to keep the tunnel up. On Juniper and Cisco you need to do the same thing.
An IPSEC tunnel only stays up when there is traffic.
ATROX
Wed Jun 25, 2014 2:08 pm
Yes, IPsec tunnel stays down if there is no traffic. But he must stays up if traffic starts. And sometimes it does not. That's what I wrote in my problem.
jarda
Wed Jun 25, 2014 4:05 pm
So my problem is different. I have the traffic (netwatch) and the tunnel was down for two days with no evident reason. Suddenly it went up.
mrz
Wed Jun 25, 2014 4:57 pm
What was the ticket number?
ATROX
Thu Jun 26, 2014 8:09 am
Ticket#2014062566000221
ATROX
Mon Jul 07, 2014 9:31 am
Error repeated exactly. Sending log files. The tunnel not up.
Fix please!
