MUM Europe 2020
lz1dsb
Qemu RouterOS image in GNS3
Sat Jul 05, 2014 11:19 pm
Here's the situation. i was able to create an qemu image of RouterOS and I successfully started it in GNS3. Connecting it to other routers works, and it's amazing that I can simulate different vendors on one common platform where I can interconnect the way I like.
My question is more or less about... licencing.
As you all know, there are licences. I've never used them, because the MikroTik router's I've used - they come with a preinstalled licenses.
And because the demo license is for 24 hours and I'll need a lot of simulation hours, I think it would be more practical to install a licence on my quemu image.
I realized though that I have a L4 license that I earned with my MTCNA, and I can use it. As I'm not quite experienced with quemu in GNS3 I was wondering - do I have to configure different licences on every device I use in my topology? My understanding is that I don't have to, as all of the virtual RouterOS devices in my GNS3 topology will use the same quemu image. Is that correct?
lz1dsb
Re: Qemu RouterOS image in GNS3
Wed Jul 16, 2014 6:41 pm
I just wanted to post what was my experience so far.
1. Creating a QEMU image of RouterOS turned out to be quite an easy task. I followed the description in mum.mikrotik.com/presentations/ID13/rofiq.pdf
2. Putting the RouterOS image in GNS3 is also a matter of setting a path to the QEMU image and setting some parameters. it's great that I could put as many interfaces I need.
3. Licensing of the image also works. I just tested it.
What I still haven't figured out yet is how to keep the license. Every time I create a new topology I have to enter the license...
Other than that - it all works great ;)
leonset
Mon Sep 22, 2014 3:10 pm
Hello!
I'm planning on using GNS3 too but I'm not sure if I understood this statement:
Does that means that every time you power up a qemu VM you have to put the license?
Or every time you add a qemu VM to a proyect and start it for the first time you have to put the license?
Thanks!
boen_robot
Mon Sep 22, 2014 4:22 pm
The license is attached to the HDD, so every time you create a new HDD (Qemu or not...), you'd need a different license.
AFAIK, you could copy the Qemu HDD, and thus run several routers using a single license. I haven't actually tried doing that though (as I don't have a spare license to potentially sacrifice).
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
leonset
Tue Sep 23, 2014 9:48 am
I already knew that HD/lincense relation, but thanks for the clarification regarding QEMU.
Thats why it would be very nice if OP could update us with his experience :) The problem is that I need to test different squemes with lot's of devices and it becomes impractical to use routerboars, connect them, etc.
Thanks!
Zorro
Long time Member
Long time Member
Tue Sep 23, 2014 2:46 pm
bunch of cheap L2/L3 lincenses, bough "with discount" ? :) as solution.
QEMU was cool. just lack of management tools, imo.
hardly can say same about majority of his TiVo-ized forks, sadly.
lz1dsb
Wed Jan 14, 2015 10:37 pm
Sorry guys, I've just seen that you've replied... several months later :D
Well, I'm using a single license. It's exactly like this, I have created one QUEMU HDD and I've generated a license for it. The first time I've even put the wrong system ID, so I had to generate the license once again.
Anyway - this does work, you only need one license.
leonset
Thu Jan 15, 2015 11:35 am
Hello!
Yes, I can use only one license too... I should have updated this thread before!
Thank you!
lz1dsb
Sun Jan 18, 2015 12:06 pm
I haven't mentioned one thing though... I still haven't found a way to overcome it. Each time I start the topology - I have to manually enter the configuration, it's not saved in GNS3.
boen_robot
Sun Jan 18, 2015 2:20 pm
Have you tried gracefully shutting down the router by issuing "/system shutdown" from it, and then do "Stop" only after the shutdown has already happened?
lz1dsb
Mon Jan 19, 2015 6:47 pm
I did. But I think there's probably something not entirely correct with the way I build the topology in GNS3.
I read somewhere that there's an additional option ot set, in order to have the configuration saved for the QUEMU hosts. Hopefully I'll find the time these days to play around with it. It's a big advantage to have a kind of a "test lab" where one can test some nasty configs, before executing them in a production network :)
boen_robot
Mon Jan 19, 2015 9:34 pm
The only remaining problem I can think of is if the HDD file is not writable... I've never even heard of this before (and I use VirtualBox, so I haven't experienced it either...).
lz1dsb
Wed Jan 21, 2015 2:20 pm
What do you mean by "not writeable"?
Users browsing this forum: No registered users and 79 guests
