wispwest
Wireless-fp "Ce, Ceee, eC, eCee, eeCe, and eeeC"
Sun Jul 06, 2014 7:15 am
Whenever I select one of the odd ones aside from eC or Ce, it says its not supported. What are they, wider channels? Exentions for use only with 802.11ac cards???? Anyone know?
Insider
Re: Wireless-fp "Ce, Ceee, eC, eCee, eeCe, and eeeC"
Sun Jul 06, 2014 8:05 am
Yes
Frequency microwave transvertors, design, development, manufacture
http://Pojitko.cz
ste
Sun Jul 06, 2014 9:18 am
C is 20MHz contol channel. In 11n you have Ce and eC with 40MHz. In .ac channels can be wider.
wispwest
Sun Jul 06, 2014 9:23 am
Could someone please post the descriptions of each one of these. I can't find a cheat sheet.
Also if someone could reveal a mini-pci car for 802.11ac that will work with routerboard it'd be appreciated.
dohmniq
Sun Jul 06, 2014 11:26 am
As far as I know there is no 802.11ac product for RouterBoards. The "eeeC", etc. channels are simply support in RouterOS for future 802.11ac products.
In 802.11n mode:
eC = 20/40MHz-ht-below
Ce = 20/40MHz-ht-above
You can see why they needed to rename the values otherwise they'd look a bit like this:
20/40/80MHz-ht-some-above-and-some-below!!
0ldman
Tue Jul 08, 2014 8:48 am
That makes sense. The AP rolls back to 20MHz for compatibility, right?
ste
Tue Jul 08, 2014 9:10 am
Yes. To the "C"-Channel.
angboontiong
Thu Oct 02, 2014 8:50 am
What about (Ce | Ceee | eC | eCee | eeCe | eeeC ) ???
eC mean Extend Channel below : 20Mhz?
eCee mean Extend Extend Channel below : 40Mhz?
eeCe mean Extend Channel below : 80Mhz?
eeeC mean Extend Channel below : 160Mhz?
or how?
and why Ce and Ceee but there is no Cee ?
mishaM
Thu Oct 02, 2014 9:21 am
C- is center of frequency
e - is extension channel
example : frequency is 5100 and in eCee will be see (5080-e,5100-C,5120-e,5140-e)
saintofinternet
Forum Veteran
Forum Veteran
Mon Apr 20, 2015 6:34 am
i have as of now good speeds on the new SXTac using NSTREME...
shifting to NV2 is really bothersome...
by professionals, for professionals....
Don't forget to give KARMA!!!
vitorcsp
Tue May 23, 2017 12:53 am
thank you mishaM , very good explication.
Aufan388
Tue May 23, 2017 3:21 pm
or how?
Each letter denotes a 20MHz channel section.
C: is where the Channel's main frequency is set
e: is where the rest of the spectrum "sub-channel" is distributed
There is no "Cee" because that would equal 3x20MHz combined channels to make a 60Mhz channel, Mikrotik currently only has 20/40/80 channel width available for AC.
If the antenna is has 2 spatial streams (dual-chain) then you will see 2x 80Mhz, not 2x160Mhz, equaling the equivalent of 866Mbps link speed. Single chain (1 spatial stream) = 433Mpbs link speed.
Hope this helps!
Users browsing this forum: No registered users and 42 guests
