imediatech
802.11ac tests results and opinions
Fri Jul 11, 2014 2:28 pm
Dear friend,
I open this topic to discuss with yourselves about 802.11ac standard on Mikrotik.
I'm waiting in about 3 estimated weeks my Compex 802.11ac QC 9882 chipset mini-pciExpress cards. Then I will install them into 2 912 OUT boards connected to Mikrotik MAnt antenna and will start the test on 2 - 4 - 6 - 12 km fresnel free links using several data rates in colocated environment 802.11a - 802.11n
Then I will post result.
Please any doing 802.11ac test give results
Regards
djdrastic
Re: 802.11ac tests results and opinions
Fri Jul 11, 2014 5:52 pm
Please do so.
I have quotes for some AirFiber links to a nearby building here on my desk that I would like to reject hehe
rwaters
Sat Jul 12, 2014 2:55 am
I should have Compex 802.11ac QC9882 mini pci-e card Monday. Plan to install in RB912UAG-2HPnD as indoor AP with 3 MT 3dbi antenna. Only client I have is Lenovo laptop with built in Intel ac card. Will report back!
czolo
Sat Jul 12, 2014 2:25 pm
It will be hard to do, because QCA9882 is 2x2 only :D
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
imediatech
Sat Jul 12, 2014 10:39 pm
There should be new product from mikrotik : netbox
http://www.interprojekt.com.pl/mikrotik ... -1624.html
Two of these with mAnt Antenna and Flexguide should be the ideal.
Monday I'll ask availability date
rwaters
Sun Jul 13, 2014 3:58 am
My mistake, I pulled the datasheet for the card and it is QCA9880 v2 3x3
http://www.ispsupplies.com/WLE900VX_DS.pdf
rwaters
Sat Jul 19, 2014 5:56 pm
I finally got around to setting this up. rb912uag-2HPnD with Compex WLE900VX minipci-e. Either this card is not "fully" supported or I have more configuring to do. Running btest client from windows 8 laptop through rb912 to CCR1009. It is strange that rx rate is locked at 6Mps.
gius64
Sat Jul 19, 2014 10:47 pm
Only 215Mbps with 80Mhz bandwidth? It's not a MIMO antenna I see, right?
czolo
Sun Jul 20, 2014 1:49 am
Conntact me at: czolo_NOSPAM@o2.pl
I think I can help you.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
nawas
Sun Jul 20, 2014 10:14 am
Did you connect the 5V pin on the Card?
"5V (compulsory and external)"
"Customers have to connect a 5V power supply to the pin on WLE600V5-23"]
czolo
Mon Jul 21, 2014 11:20 am
We are talking about WLE900VX - there isn't such PIN there.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
rwaters
Tue Jul 22, 2014 3:00 am
Update: new drivers for wlan driver on laptop, now connects a little faster. Maybe next release of routeros will allow for changing HT80 tx power and maybe VHT tab in winbox?
czolo
Fri Jul 25, 2014 6:07 pm
Some tests from our network:
If you like it, give me some Karma points :D
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
gius64
Fri Jul 25, 2014 6:11 pm
Wow!
What card is it? Is an SXT/NetBox? How much distance? How much signal?
Can you post "Status" section? Is it a MIMO? 80MHz?
czolo
Fri Jul 25, 2014 6:24 pm
Wow!
We are still durning tests now. We have 2xRB912 + 2xMiniPciEx. Now we are waiting for NetBox, but they will come after the weekend.
Cards are from Compex, and it works like a charm. Devices are working with MIMO 2x3 (2xTX 3xRX). Signals about 55-60dB.
More results with picture I will put here later.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
gius64
Fri Jul 25, 2014 6:28 pm
It would be great to know exactly which card you used, which antennas and so on :D
Thank you for your feedback!
noyo
Fri Jul 25, 2014 6:33 pm
distance?
telecomunicazioni
Mon Oct 27, 2014 2:07 pm
I really want to know if 802.11ac give better results on PtMP configuration with 3x3 MIMO antennas in real life production environment.
I've read old post regarding some crashes, disconnection and other problems related probably to bugs, but I have notread some new tests in recent months.
Is there any users has done some real test?
Sergio72
Tue Oct 28, 2014 4:00 pm
Hi czolo,
What distance did you have there and which antennas have you used ?
czolo
Mon Nov 03, 2014 1:15 pm
Hi czolo,
Distance about 400m.
I don't want to make any advertise, so priv me.
| --= Czo|_o =--
| http://wifi4eu.pl
| Innovation in WiFi
telecomunicazioni
Thu Nov 13, 2014 3:09 am
Hi czolo,
Hello I would like to receive more information about your test, can you write me in pvt ?
Karvanoppa
Sat Jan 09, 2016 1:40 pm
Sorry this is old thread but wanna know about cpu usage with this card on RB912 or RB922? Are those card enought power to transfer this fast?
h3ll1
Sun Jan 10, 2016 5:18 am
Look at the ASUS rt-AC88U. Delivering 1Gbit @ wireless with ease. IPERF, no small talk.
Users browsing this forum: RIMER and 32 guests
