MUM Europe 2020
speaksandeep
Connect 2.4Ghz Grid Antenna to 5Ghz RB433
Sat Jul 12, 2014 1:07 pm
I was using RB433 with 2.4Ghz Grid antenna, now I have to use the same hardware in other location as p2p in 5Ghz,
Can I use same 2.4Ghz Antenna with RB433, for point to point 5Ghz link
Regards,
Regards,
Sandeep Baral
rextended
Re: Connect 2.4Ghz Grid Antenna to 5Ghz RB433
Mon Jul 14, 2014 3:12 pm
why is called 2.4GHz antenna and not dual band antenna?
I'm Italian, not English. Sorry for my imperfect grammar.
speaksandeep
Mon Jul 14, 2014 3:52 pm
It is not dual band, Its 2.4Ghz Grid Anteena,
we want to use it for 5 Ghz p2p link
Regards,
Sandeep Baral
rextended
Mon Jul 14, 2014 6:13 pm
...It is not dual band...
With my question I have forced you to answer yourself...
jarda
Mon Jul 14, 2014 7:02 pm
Just to be clear: no. Use 5GHz antenna for that.
rextended
Mon Jul 14, 2014 7:08 pm
Why you are everytime so clear? :lol:
troy
Mon Jul 14, 2014 9:28 pm
FWIW, I had a tower climber do this on accident. The signal was was considerably lower than expected, but the link did work.
Electrically speaking, the antenna will work (it puts the appropriate load on the transmitter), but you will never get the performance you would otherwise expect to get, as it's not tuned for that frequency.
jarda
Mon Jul 14, 2014 11:26 pm
Rextended : not so many times I would like.
Troy : utp is also wire but using it for ac high voltage is not recommended. Everyone has to count with others also, at least not to make unnecessary noise and deal with local regulations if any. Therefore my NO.
plisken
Tue Jul 15, 2014 12:52 am
If you do that this blow up your radio card.
SWR (standing wave ratio) is to high and that can blow up your radio card
And you have not the full performance from the antenna.
The antenna is built according to the frequency properties.Otherwise it does not work well
speaksandeep
Tue Jul 15, 2014 12:58 am
In that case, shall I use 2.4Ghz for my new p2p link as I want to use the existing infrastructure.
distance of the p2p links are 1 km and 2 km
Regards,
Sandeep Baral
plisken
Tue Jul 15, 2014 8:14 am
May i ask why 2.4 GHz?
I give you advice use 5 GHz Point to point links the results in better performance.
speaksandeep
Tue Jul 15, 2014 9:31 am
I know that 5Ghz is best option, but I need to utilize my spare 2.4Ghz Grid Antennas.
In case of 5Ghz link, I have to procure new antennas,
Regards,
Sandeep Baral
plisken
Tue Jul 15, 2014 9:50 am
I also grids, I use this only for site survey.
No longer able to build point to point links.
The grids are old, there are better things available.
Goodluck
CyberTod
Long time Member
Long time Member
Tue Jul 15, 2014 11:30 am
@speaksandeep so many people told you this is not a good idea and you still insist on doing it.
rextended
Tue Jul 15, 2014 12:31 pm
Let make his steps.
troy
Tue Jul 15, 2014 6:27 pm
@Jarda, I never said I would recommend it, just that it would work (however poorly).
@plisken, you're right, the SWR is too high, but didn't not consider that this would damage the radio, was only thinking from a tuning aspect.
jarda
Tue Jul 15, 2014 6:33 pm
I also didn't say that utp could not lead high voltage. We all know that it could, especially in the cases we don't want to ☺. Everyone has his destiny in his hands.
rextended
Tue Jul 15, 2014 7:58 pm
eMro batmoK oT meoK...
MrBarakat
Tue Jul 15, 2014 8:30 pm
Sit i think understand ur Q if u want make ptp with 5.8 u must use Antenna 5.8 not 2.4
and u have 433RB just want xr5 card + Antenna 5.8 and every thing will be ok
my regards
0ldman
Wed Jul 16, 2014 5:52 pm
I've got a lot of dual band cards on single band antennas.
The only thing I've been able to do with them is scan to see what the rx strength is from my other devices on the tower. In my experience they won't even connect.
If you really have to make use of antennas that you have rather than antennas that were made to do the job no one is going to stop you.
You also won't get much help from the forum when the link doesn't behave as you think it should.
Petzl
Sun Jul 20, 2014 2:55 am
i have a 5 ubnt device connected to a 2.4 ghz rubber duck, still working after 8 years ... distance is 25 meters .... and on the other side a nanostation loco ....
now i know better and wil alway's use the better solution ... in that time 5 ghz rubberduck antenna's where not so common ...
Users browsing this forum: No registered users and 22 guests
