Pirlet
Remote reboot IP Phones by URL (Cisco & Snom)
Mon Jul 14, 2014 1:11 pm
I have a Dual Gateway failover in place, and I'd like to do the following:
Whenever the route switches from WAN1 to WAN2 (and the other way around). I'd like to reset my SIP phones remotely.
this can be done by browsing to the following URL: http://192.168.xxx.xxx/admin/reboot for Cisco and http://phoneIP/advanced_update.htm?reboot=Reboot (Snom)
How can this be achieved?
rextended
Re: Remote reboot IP Phones by URL (Cisco & Snom)
Mon Jul 14, 2014 2:09 pm
You can not achieve that, because you must authenticate on the phone/ATA before launching that URL.
Pirlet
Mon Jul 14, 2014 2:27 pm
Well, apparently it works without authenticating. Just browsing to that URL would do the trick, since they're not protected with a password.
rextended
Mon Jul 14, 2014 2:29 pm
Cisco & Snom are really so IDIOTS? :shock:
Have you tried wit one device never used for access internal setings?
Pirlet
Mon Jul 14, 2014 2:38 pm
When I browse on my PC to that link of the phone, it just reboots.
So I'd like to know if there's a way I can implement this in somesort of a script.
Kickoleg
Mon Jul 14, 2014 2:49 pm
Disbale -active URL- in configuration of phones. This is popular way to hack IP phone and do fraud trafic.
MTCNA, MTCUME, MTCRE, MTCWE, MTCTCE certified
rextended
Mon Jul 14, 2014 2:53 pm
Very buggy programmers....
Kickoleg
Mon Jul 14, 2014 2:56 pm
It's not BUG :) It's feature :)
Its using in closed network with local IP PBX.
rextended
Mon Jul 14, 2014 3:02 pm
For me is one excuse (the feature) for buggy programmers.
The right way to do that?
deviceip/reset?superuser=supername&superpassword=nowisbetter
or
http://username:password@ipphone/reset
Kickoleg
Mon Jul 14, 2014 3:10 pm
No ! RESET-no ! Reboot-yes for provising services, and feature "direct call" using active URL, using by some PBX.
rextended
Mon Jul 14, 2014 3:13 pm
Ok, on example I put reset, but I really want write reboot...
Kickoleg
Mon Jul 14, 2014 3:26 pm
nothing happen ... only 2-3 command allowed by active url ...
it's using usually for first remote configuration.
As routers ,after set configuration necessary to close all the holes :)
rextended
Mon Jul 14, 2014 3:32 pm
(remove extra "[" on your signature... :roll: )
Kickoleg
Mon Jul 14, 2014 3:36 pm
Senx :)
Pirlet
Mon Jul 14, 2014 6:47 pm
So, is there a way to script this into an RB2011?
I'd like to send these commands to internal IP phones
rextended
Mon Jul 14, 2014 6:54 pm
Use "fetch" command, search on th wiki for syntax
Pirlet
Tue Jul 15, 2014 2:19 pm
So, I got this to work for the Cisco phones with:
/tool fetch mode=http port=80 url=http://192.168.88.xxx/admin/reboot
But I cannot seem to get the Snomphones working, because I cannot type a "?" into the command line as URL...
I should use this:
/tool fetch mode=http port=80 url=http://192.168.88.xxx/advanced_update.htm?reboot=Reboot
But the "?" isn't working. I cannot type it...
How can I fix this?
rextended
Tue Jul 15, 2014 2:23 pm
FAST REPLY:
put \ before ? on command line, but on saved script do not put the \
cdiedrich
Forum Veteran
Forum Veteran
Thu Jul 17, 2014 10:16 am
And in case you have plenty of phones, you might want to add them to an address list (which might come in handy for other stuff as well) and embrace the fetch command in this statement:
ros code
:foreach i in=[/ip firewall address-list find list=ipPhones] do={
#your fetch statement here - replace the address with $[/ip firewall address-list get $i address]
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
rextended
Thu Jul 17, 2014 6:29 pm
:foreach i in=[/ip firewall address-list find where list="ipPhones"] do={
 :local ip value=[/ip firewall address-list get $i value-name=address];
 /tool fetch keep-result=no mode=http port=80 url=("http://".$ip."/admin/reboot");
 /tool fetch keep-result=no mode=http port=80 url=("http://".$ip."/advanced_update.htm?reboot=Reboot");
cdiedrich
Forum Veteran
Forum Veteran
Thu Jul 17, 2014 6:51 pm
Eager beaver :D
Basel, Switzerland
Bremen, Germany
rextended
Thu Jul 17, 2014 6:56 pm
Eager beaver :D
Thanks! :lol:
jspool
Sun Jul 20, 2014 8:45 am
Do you host your own PBX server at another location or do you get your PBX through an outside company? Being an ITSP I ran into that issue many times and successfully implemented seamless transition between WAN connections without call interruption ;) I like it much better then having to do a reboot every time a route changes.
Users browsing this forum: Semrush [Bot] and 5 guests
