rado3105
Dual nstreme and wireless-fp and v6.15 any changes?
Mon Jul 14, 2014 9:26 pm
Are any improvements in dual-nstreme using wireless-fp or v6.15?
rextended
Re: Dual nstreme and wireless-fp and v6.15 any changes?
Tue Jul 15, 2014 1:40 am
dual nstreme is like one existent but abandoned technology on favour to 802.11n, MIMO and nv2
rado3105
Tue Jul 15, 2014 1:46 pm
but till now none of this is so rock solid as DUAL NSTREME..also in noisy enviroment....
czolo
Tue Jul 15, 2014 8:33 pm
It will be awesome if Mikrotik can repair dual-nstrem. Imagine dual-nstreme link with two 802.11ac separate links and FDX throughput more than 600Mbps full-duplex!!!
Please MT-Team think about it!!!
rextended
Tue Jul 15, 2014 9:42 pm
Remember: on some country (all receiving CEPT regulamentation) is forbidden use 80MHz modulation [exactly more than 20+20], or better is forbidden at all use 5GHz for PTP
bajodel
Long time Member
Long time Member
Tue Jul 15, 2014 10:10 pm
..forbidden at all use 5GHz for PTP
what device/freq/modes are you using for PTP ?
rextended
Wed Jul 16, 2014 12:28 am
strictly ptp 17Ghz, ptmp 5GHz
How use Mikrotik on 17GHZ?.... eheheheh.......
http://www.sicetelecom.it/hiperlink-pre ... mium-17ghz
on that model are present one up/down converter from 5GHz to 17GHz...
At the start I'm sceptic on that, but works...
bajodel
Long time Member
Long time Member
Wed Jul 16, 2014 1:06 am
..POE 48V 802.3 af .. ?!!!!? ..what the hell?? :shock:
Good to know, my MT trainer told me to stay away from up/down converters , so I must change my mind :D
rextended
Wed Jul 16, 2014 1:56 am
If you misunderstand Italian: 802.3af (48Vdc) o 24Vdc
OR model powered by 802.3af by internal on-box power converter from 48 to 18V as usual,
OR model powered by 24V.
Not both.
rextended
Wed Jul 16, 2014 1:58 am
Do not expect verly long range link...
I suggest max 16Km, on 23,5 Km I'm forced to use pure 5GHz... ehm...
For long distance link you need 2mt dish, with pure 17GHz device...
I also have one LigoWave Unity 5 PTP (ok, is another brand, but against mikrotik is one un-competitor...) but is used on parallel of the previous described link of 23,5Km as backup.
Same J&L 30dBi H/V dish, but RB411AH + SR71-15 (6.15 wireless-fp tdma auto on NV2, 20 Ce) have better and stable performance. I force it to stay linked at max to 180Mbps/radio and the only limit are the 100M ethernet... (latency average 4ms, min 2ms, max 6ms on 70Mbps to clients / 30Mbps from clients during real data passing on the link)
rextended
Wed Jul 16, 2014 2:44 am
IF you are interested, follow this:
http://forum.mikrotik.com/viewtopic.php?f=3&t=87054
ste
Wed Jul 16, 2014 8:35 am
There are 17/24GHz Radios which do fdd and dont need conversion. More expensive but reliable <1ms. Modulations up to 1024QAM.
rextended
Wed Jul 16, 2014 9:36 am
Missing on that devices RouterOS... I have one 2m dish 17GHz bridge, but I never used it...
ste
Wed Jul 16, 2014 10:25 am
You have to connect ROS-Devices on both ends then you have the combination of ROS features and Radiofeatures. You cant do everything with one platform. High speed low latency backhaul is where you run into limitations with wifi solutions. You can tune cheap wifi-Radios to an extent but there are limits. This conversion stuff is quite experimental. You might run into 5GHz selfinterference with your 17GHz link.
Yes. Stay away. If you want to use 17GHz use native 17GHz Equipment. We move everything out of 5GHz where possible.
With .ac the band will be crowded so the problems with (self)interference will rise.
Cetalfio
Thu Jul 17, 2014 9:00 am
what device/freq/modes are you using for PTP ?[/quote]
rextended the 17 Ghz hyperlan sicetelecom solution allows to access into routerboard from winbox or only with a partial way by a web interface?
Have you tried the cpe version or the backhaul version?
Have you got to try it with a distance of 16 km during a heavy rain? The link is interrupted?
cetalfio
rextended
Thu Jul 17, 2014 9:12 am
I do not know why you think if can be limited...
Is all the same, inside you do not have any hint about if is working on 17 or 5 GHz.
For do one ptp simply buy 2 CPE version...
I do not have one bridge with that distance, SICE staff suggest me to do not use over that distance,
On near 8Km is never interrupted by rain. I do not know if have any problem with snow or heavy fog,
because on my zone is really rare that...
Cetalfio
Thu Jul 17, 2014 9:55 am
[quote="rextended"]>>>rextended the 17 Ghz hyperlan sicetelecom solution allows to access into routerboard from winbox or only with a partial way by a web interface?
Ok my question was if the sice allows a user with full access permission, or if the kit comes with simplified web management and, so, limited management.
Sure but the cpe version seems to be limited to 30Mbits full duplex while the backhaul version to 85mbits.
This looks like an interesting product to be tested, thanks for your info.
cetalfio
rado3105
Thu Jul 17, 2014 11:32 am
What is the price of: HIPERLINK PREMIUM 17GHZ
If you compare unity, it costs about 1,500 Eur....is that able to get 100Mbit/s traffic in crowded enviroment?
rextended
Thu Jul 17, 2014 6:33 pm
I not talk about price, because we have one arrangment with SICE...
Is the principal source for MikroTik hardware for us.
i do not know that because on "my" zone there do not are other WISP using that frequencies.
kgninfos
Thu Jul 24, 2014 10:30 am
Where is the auto option in NV2??
rextended
Thu Jul 24, 2014 10:48 am
You have enabled wireless-fp and reboot?
kgninfos
Thu Jul 24, 2014 7:23 pm
you think this is improvement
signal -69 distance 3km
InoX
Thu Jul 24, 2014 7:53 pm
There is no such option like Auto for TDMA
CyberTod
Long time Member
Long time Member
Thu Jul 24, 2014 8:32 pm
When you enable wireless-fp you have this triangle right of the value. When you click on it the field becomes with no value and that makes it auto.
InoX
Fri Jul 25, 2014 9:09 pm
This is like voodoo documentation, it might also meant is disabled...and everything else we can imagine.
kgninfos
Sat Jul 26, 2014 12:37 pm
this is confusing also i lost connectivity when i enabled that
log was flooded with "Last connection failed" and the sxt was not trying to connect to ap anymore
after i removed the access list entry(which was disabled) it worked
i guess it's using the access list when it's disabled
rado3105
Wed Jul 30, 2014 12:15 am
using wireless-fp I had to manualy set full duplex 100mbit/s on ethernet ports....because of lost connection, low throughoutput
rextended
Wed Jul 30, 2014 1:40 am
This is the first time I read it, I'm a wisp and I have upgrade more than 100 devices, for now, and no one single problem...
Users browsing this forum: pav5 and 70 guests
