speaksandeep
Support require for design WDS Mesh Network
Mon Jul 14, 2014 10:19 pm
We are using four RB433 with dual Omni Anteena, configured in Mesh WDS,
but we are not getting the good performance.
We decided to change all RB433 either with GrooveA 52HPN or Ubiquiti BulletM2 with 12dbi Omni Anteena,
Please tell which product is better and should give better performance
Regards,
Regards,
Sandeep Baral
speaksandeep
Re: Support require for design WDS Mesh Network
Mon Jul 14, 2014 11:39 pm
PLEASE TELL WHICH ONE IS BETTER
Regards,
Sandeep Baral
plisken
Tue Jul 15, 2014 12:45 am
I go for the groove is more powerfull and more versatile
Ubiquiti bullet works fine but you can not work with virtual accesspoint with Original software
If you use DDWRT on bullet you can use virtual accesspoint
Users browsing this forum: Google [Bot], StephenL and 16 guests
